Question about Hoover HDC7FM Dryer
Hoover ppc160 2 felt belts found inside dryer
My wife when unloading the dry washing has on 2 occasions found a circular felt belt or seal
Where did they come from and can I re-fit them
  • number9score Dec 02, 2008
    same problem with our hoover hsc170 condensing dryer...
    felt belt came out with wash.
    dryer is 2yrs and 2 weeks old.
    2 yr warranty!!
  • Hoover Master
  • 2,536 Answers
Those are the drum seals,they should be glued onto each end of the drum where it rides on the front and rear of frame,they're not belts.
Posted on Jan 04, 2018
    Scholar:
  • 30 Answers
Let me ask you one question. Are either of you having any problems as far as performance with your dryers? If not, do you still have your owner's manual that came with the dryer? There is a possibility that an extra was inside, all this time; and worked its way into the tumbler. I have known on occasion where there is a factory defect causing the wear to happen much more quickly so an extra part, in this instance an extra belt; would be given inside the owner's manual or the dryer cabinet itself. I'd check my manual first. Then, if I wasn't having any problems I wouldn't look for any. Neither of you mentioned any problems with the way the dryer worked or sounded. On the one with 2 wks. over warranty, I would at least contact the place where it was purchased if you ARE having a problem. If they are reputatable, Hoover is good about honoring their warranties within a few days. The store may take care of it, if they want your business again. Good luck to both of you. It'll be OK. Get back with me if there is a problem you didn't mention, OK? Keep smiling & have a Good One.
Posted on Jan 13, 2009
I changed the belt, it sounds like it works now but drum does not roll????
Hi and welcome to FixYa. I am Kelly.
Things to check..
1. Belt and ilder pulley properly positioned?
Use this link to make sure you have it correct:
http://www.repairclinic.com/Dryer-Belt-Diagrams
2. Make sure the drum felt seals are not rolled / folded over. If it is folded / rolled slide the shanke of a screwdriver under the felt and rotate the drum 360 deg until it straightens out. (Front and rear seals.)
3. Make sure the drum rollers are resting in the drum groove and not behind the drum
These manuals will be a big help: (page 25)
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/4829abde74a34d7f85256ab000620794
and
(Page 10 below link)
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/3ffad75038c96fe4852571ca006cb80a/$FILE/L-58.pdf
Thanks for choosing FixYa,
Kelly
Apr 01, 2011 | Whirlpool Dryers
My beko condenser tumble dryer is drying fine but is making a loud scraping noise. When I took out the clothes there was a strip of white felt in the washing
Looks daunting to start with but just done mine,
remove top and all rear covers and rear panel after removing drum split washer, pump hoses, belt and elec connection, remove the drum and you will see where the felt seal goes. i had some felt i cut to 12mm wide and siliconed it in place, left to dry for 6 hrs, now runs fine.
Feb 07, 2011 | Dryers
The felt/cloth seal on the back of the interior of the dryer has come out. It is a large circular "belt/seal". How do i reattach?
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
If you have a front loading machine,
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer.
Be REAL CAREFUL not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the dryer. This will expose the drum,felt seal and belt. You now can repair/replace the felt seal, but I would advise that you go a little farther and maybe save some problems in the future.
Remove the drum and belt and this will expose the drum rollers, idler arm pulley and motor.
Now is a good time to check the belt condition for wear.
Be sure to note the route of the belt, this will come in handy when you go to reinstall the belt.
Check your drum rollers for flat spots or wear, if they have flat spots or wear on them replace them.
If the drum rollers don't have flat spots or wear on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in.
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good Luck,
I hope this helps
Nov 15, 2009 | Maytag PYE2300AY Electric Dryer
We have a problem with our frigidaire dryer FEQB4000FS0 snaps, zippers and buttons are getting caught in the gap between ther inside of the dryer and the drum, as a result all the clothes are getting...
Sounds like the felt seal is missing,shifted, or broken.
The felt seal is what keeps the zippers,buttons,etc from catching in the door and causing problems.
If you plan to do the repairs yourself, then make sure you unplug the dryer before starting any repairs.
Remove the electrical box that holds the timer switch, start switch, etc. from the top of the dryer. Be real careful not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the machine, this will expose the belt and drum and felt seal.
You can now inspect the seal to see if it is faulty. Replace it if it is needed.
If you remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley. Pay attention to the route of the belt, this will come in handy when you go to reinstall the belt and drum.
While you have the drum out, I would recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you a problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a noise like a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.
Good luck,
I hope this helps
Oct 28, 2009 | Frigidaire FEQ1442ES Electric Dryer
The felt seal on my Hoover HNC175 tumble dryer come off.
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Remove the front of the machine, this will expose the belt and drum, and the felt seal.
You may be able to replace the felt seal at this time, or you may have to buy a new one and install it.
I would also recommend that you do the following while you have gone this far.
Remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley. Be sure to pay attention to the route of the belt, this will come in handy later when you go to reinstall the belt and drum
Good luck,
I hope this helps
Oct 18, 2009 | Hoover Dryers
Whirlpool duet dryer felt seal replacement
The drum may to be removed to install the new felt gasket but the old drum can then be reinstalled. The felt gasket seals the joint where the drum rotates at the inside back panel. It is likely that the inside back panel can be removed when the dryer is placed front-down and the outside back panel is removed. In that case the drum does not have to come out.
Jul 08, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Frigidaire electric dryer catches clothes at the edge of the drum
If the clothes catch on the drum edge the felt seal is worn out , and the squeak could be the bearing the drum rest on or the belt tentioner , it may need oiled , you can buy the felt seal replacement kits online and they are not hard to install.
Hope this helps.
Phil
Apr 10, 2009 | Frigidaire FDE436RE Dryer
Hoover Washer/Dryer WM120 : Dryer function - drum not turning
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
treru
Jan 25, 2009 | Hoover H120M Front Load Washer / Dryer
Kenmore Series 80 Dryer. Heats doesn't spin clothing. Imagine its a belt or spin motor. Need a schematic
No need for a schematic, there are two kenmore dryer belts, 'full size' or 'apartment size', if it is a belt you will be able to here the motor racing unloaded, turn heat to cold before testing, dont want to blow a thermal fuse.
Kenmore dryer comes apart from the front,
  • UNPLUG dryer 220V is not fun
  • remove the lint screen
  • remove the screws under the lint screen holding the case top to the screen holder
  • with a putty knife or other blunt blade release the catches at the front corners of the top and raise top
  • remove screws holding front of case on, from inside the dryer
  • remove door switch cables
  • lift front of case off and set aside,
  • can reach motor, belt, felts and rollers.
  • broken belt will be obvious, lying on the floor
If belt is broken, examine rollers and felt bearings for wear, stuck rollers or no felt left, is the most common cause of belts breaking, extra tension is required to spin the drum, If damaged replace them, they are cheap and easy to do, and it woud be no fun if another belt broke quickly
reasemble after repair in reverse order.
Aug 25, 2008 | Dryers
Hoover HDC7FM Dryer Logo
147 people viewed this question
Top Hoover Dryers Experts
Tim Whalen
John Tripp
John Tripp
Are you a Hoover Dryer Expert? Answer questions, earn points and help others
