Question about Legacy LA2098 Car Audio Amplifier
Legaxy LA2098 2400 watt 2 channel amp
I have 2 audiobahn 15's that ive had for 3 years and theyve worked fine with other amps and I wanted to go up in watts for my amp so I bought this amp. I connected all of the wires and the "ICE" symbol on the front of the amp will illuminate but the power indicator on the amp and on the bass boost control will not turn on. So it is getting power but it just wont turn on. Can someone help me on this one?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 155 Answers
Humm.. Have you check your remote wire? If you know the amp is getting power for sure, diconnect your subs from the amp leave only the + - and remote hooked up. Check again if still same thing nothing, try taking a jumper wire to the batt terminal over to the remote terminal. This should let your amp kick on, IF SO your remote wire has a short some where. IF NO i would check your ground wire again and make sure its good and along with all your fuses. IF NO still might have internal damage. BUT if it did work dont leave it hooked up like that, it WILL stay on untill u remove the jumper wire. I just use this lil trick to help save time with trouble shooting. Hope this was helpful i had the same prob with my amp remote wire was bad
Posted on May 26, 2010
I have a 12 inch auduobahn 400 watt that is a special edition d jones. what is the best and most efficient way to install it with a jensen 400 watt 2 or4 channel mosfit power amp.
Is it a 2 or 4 channel amp???? Does it have a lpf (low pass filter)??? If its a four channel it prolly wont sound too great. If its a 2 channel you need to bridge sub to amp. Usually its the 2 outside terminals on the amp. Might have a diagram on the bottom of amp
Feb 27, 2012 | AudioBahn Car Audio & Video
How do i get the most watts possible from this amp, with out overheating the amp.
you can run your amp at 1 ohm you would need to to have the right ohm subwoofer wired in parralle to get 1 ohm at amp ...... the put a 12 volt fan in the area to keep the amp cool so it doesnt over heat if you plane to
Audiobahn A2X400HQ 2 Ch Amp
1600w x 1 @ 1ohm - 800w x 1 @ 2ohm
600w x 2 @ 1ohm - 400w x 2 @ 2ohm
2-Channel High Current Amplifier -- Ideal for use with all Audiobahn Rack Mount Products
http://www.tintingbyfredjohnson.com
Dec 27, 2010 | AudioBahn A2X400HQ Car Audio Amplifier
I want to buy a AUDIOBAHN A2200HCT amp i have a kicker 17 15 inches this amp works with this woofer thanks
will work, ive heard mixed reports about those audiobahns though, i think personaly i would stick to phenox gold,rockford fosgate,or another well known power brand. what box is it in?
Feb 04, 2010 | AudioBahn A2200HCT Car Audio Amplifier
Audiobahn 1800 watt amp has an error of LO and isn't working righ
you are not getting your amp enough volts try checking your ground or power cable
May 19, 2009 | AudioBahn A18001DQ Car Audio Amplifier
I HAVE A A2300HCT AUDIOBAHN I WANT TO CONECTED TO 6 12 INCH CROSSFIRE ALL 6 GIVE ME 1 OHM DO YOU THINK I CUOLD LOWER THE AMP TO 1 OHM IF NOT WHATS MY BEST CHOICE
Hello VICENTEMULGA,
According to Audiobahn's specifications, the amp is stable at 1ohm, either with the channels driven separately or in bridged mode. With the channels driven separately, the rated output is 1,200 watts at 1 ohm. In bridged mode, the rated output is 2,400 watts.
You'll need an absolute minimum of 2gauge power and ground, and preferably 1/0gauge and a really good alternator to provide enough current for the beast.
Hope this helps.
May 05, 2009 | AudioBahn A2300HCT Car Audio Amplifier
Amp makes noise. I am purchaseing a new amp
Hello termite440,
A mono amp will generally provide more power for subs. And for those Audiobahn's, you'll want something that will provide a minimum of 500-600 watts RMS to each, a least a 1000 watt amp. At the low end, something like the Alpine MRP-M1000 or the Orion HCCA-D2400 will provide 1000-1200 watts. I'd recommend the Alpine. For more power, and another $100, look at the Alpine M2000, or for another $250, the Rockford-Fosgate T1500-1bd.
Hope this helps.
Apr 28, 2009 | JVC KS-AX5500 Car Audio Amplifier
550x2 subs....SPL z2x-820 Amp
The 230 watt amp is a little small for your subs. They'll work, but if you are looking for max SPL, you won't get it. To push those Audiobahn's to their potential pavement shaking max, I would recommend an amp in the range of 500-600 rms (2-channel bridged) or 1000 watts rms monoblock.
Hope this helps.
Mar 28, 2009 | SPL Dynamics Z2X-820 Car Audio Amplifier
Help me with my system
More information is required to start solving your problem. (ie. your make and model of "1500W amp", the voicecoil configuration of the kicker and Audiobahn 15's, and why you want to encorprate 2 crossovers in your system)
Seems as If you have a system without a plan.
Head unit?
More info necessary to give you the best use of your components.
Jan 14, 2009 | KEF Audio PSW 2150 Speaker
Legacy LA2098 Car Audio Amplifier Logo
138 people viewed this question
Top Legacy Car Audio & Video Experts
Tygh Duval
Tygh Duval
Putter71
Level 1 Expert
Robert Little
Level 1 Expert
Are you a Legacy Car Audio and Video Expert? Answer questions, earn points and help others
