Question about Plumbing
New kitchen faucet ''jerks''
When you turn on the water, it kicks/jerks/sputters about every 15 seconds. We've already ruled out air in the lines. Could a diverter do this? It has nothing to do with the sprayer.
  • tripphenry Feb 01, 2009
    I have the same problem with a brand-new Price Pfister Classic Series faucet (double handle). We just installed yesterday. The sprayer is leaking around the handle constantly, and the spout "jerks" everytime you turn on the water and then about every 15 seconds. If you turn on the hot and cold at the same time, the frequency of the **** increases. If we remove the aerator, the jerking stops while the water is on, but still jerks when you first turn the water on. We are planning to remove the faucet believing it is defective, and take back to Lowe's for a replacement of the same faucet as I presume it is a faucet issue, since we never had a problem with our old faucet.
  • phil_m7 May 11, 2010
    City water or well?? Is this the only faucet in the home doing this??
    Phil
It's neither you nor an unusual problem. It's the faucet. We just installed a similar 2 handle $168 Pfister and had numerous similar and other problems. After 2 hours of expletive laden sweat, bruises, and continuous dumbfoundedness over the incredibly poor design of the cheap plastic pipe fittings and the poor english instructions, we turned it on and immediately had many problems.
1. It jerks the pipes every time you turn it on.
2. It sputters with irregular flow.
3. Pressure is 50% of our corroded 18 year old faucet.
4. When you turn it off, it drips for 10 seconds.
5. The flow out the spout is uneven and dribbles.
These problems are from its chinsy fittings and poor piping design.
1. The fittings are unstable plastic snaps held together only by pressure, O-rings, and cotter pins. No screw fittings at all. This is also dangerous since simply pulling the hoses and pipes such as when stuffing things under the sink could break the seals and cause a flood.
2. The flow diverter block that mixes the hot/cold and side feeds the separate sprayer is nothing more than a small block of plastic with very tiny holes infeeding the hot/cold lines and outfeeding the spout and sprayer. In other wrods, a 2 in, 2 out distributor.
3. The hoses that feed the hot/cold to the diverter take their feed from circular collar that seal the water with plastic-on-plastic pressure, held in place by more cotter pins. The holes in these collars that feed the hoses that lead to the diverter block in the center are also very small so they reduce pressure drastically and cause intermittent and sporatic flow.
4. Due to the very tiny holes in the diverter block, the feed collars, and the spray hose at the diverter block, any sediment or minerals in the water will soon render the faucet completely dysfunctional.
5. The design of the unit makes uninstalling very difficult. The sprayer feeder hose, for example, is made to push in without threads or pins so it has to be ripped out. The large thin ring washers with no gripping edges that hold the hot/cold faucet stems were very difficult to tighten and will be twice as hard to remove. The plain old wind nut style nylon washer-nuts used on l\more utilitarian econoical units are far superior. Shame on Pfister.
Answer: Due to all the above, the answer to your problem, unfortuntely, is the same as for us. To wit: There is no solution other than switching to another brand that doesn't place all its design effort in its looks at the expense of proper function. We feel ripped off. There is nothing uglier than a pig with lipstick.
Bottom line: These Pfister units are all show and no go. Return them if possible and choose another brand whose piping is hopefully more evolved and rugged rather than this plastic toy with only good looks.
Posted on Sep 08, 2009
  • stocktonmark
    stocktonmark Mar 05, 2013
    same problems with a price p. the diverter block holes on mine became jammed with a piece of calcium, causing the unit to leak. Cleaned it, reinstalled with no leaks....until i realized the cotter pin had worked itself lose on the cold side fitting. MAJOR WATER.
    Habit-Forming:
  • 84 Answers
I do apartment make ready, I've to install countless faucets, bathroom and kitchen. Only recently have I had the same problem.
After installing your faucet and you turn the water back on under the sink, did you open the lines completely? In my case it was low flowing water.after completely opened up both lines, worked fine, the stuttering quit.
Start simple,
Posted on Aug 14, 2016
    New Friend:
I just fixed my jerking/kicking/sputtering GROHE faucet by increasing the hot water line's pressure.
The installation video appropriate to my faucet helped me understand its inner workings, and enabled me to diagnose the problem and fix it:
http://www.grohe.com/us/21532/services-for-you/installation-videos/
Posted on Jul 21, 2016
    Scholar:
  • 127 Answers
If it's a single handle Delta faucet with sprayer, the diverter can cause this. It's unusual in a new fixture, but it's possible that some debris may have gotten into it during installation. Disassemble and check. Carefully flush the lines with the valve seats and springs and diverter removed.
Delta also makes parts for Peerless and some import brands.
Posted on Dec 23, 2008
Installed new kitchen faucet. When water is first turned on, fill lines jerk and make noise. Also when water turned off, it takes several seconds for water to stop running. What is our problem?
tis more than likely a defective diverter. diverter if you have a side sprayer. If you don't have a side sprayer, check the technical info to see if your faucet has a diverter anyway.
wherever you bought it tell them and ask for a replacement.
Does it do it with only cold? hot?
Feb 16, 2018 | Plumbing
Brand new faucet thumps when turning on
you have air in line
1. turn off water under sink
2 turn faucet on full
3. turn on valves under sink water will sputter then run solid
Hope this helps mike
Nov 28, 2013 | Globe Union Glacier Bay 8 In Double Handle...
Tuscany kitchen faucet
The hose is always filled with water when not in use. The longer that water remains stagnant in that line, the more it will absorb that smell. Try running the water for 10-15 seconds before filling your glass. If that doesn't solve the problem, purchase a new hose.
Oct 20, 2013 | Plumbing
Danze faucet jerks
being a new faucet it does that because you still have air in the line. turn the faucet on and let it run for a while, if that doesn't work take it back and get a better quality faucet like a delta, because they make them so cheap that the seal could be loose inside.
Sep 10, 2017 | Danze Home
Price Pfister hot water runs slow
Check the supply line and valve to see if any dirt or foreign.matter got into the line or valve when you changed out your faucet. if this is not the problem you may have a faulty faucet. You may be able to back flush the faucet with a garden hose by leaving the hot side open, but you will get wet. If you used Teflon tape on the supply line and it is a compression fitting, some of the tape could be blocking the water. for more info go to waterheaterflush.com
Oct 16, 2012 | Price Pfister Plumbing
Brand new $65 Peerless Faucet installed in Master bath---squeals like a woman having a kid & the master has to flush the toilet 6 to 8 times or so a day & night to make it *******!!! I've had...
You may be experiencing what is commonly called "water hammer" from trapped air in the water lines. The most common way to eliminate a water hammer is to replenish all air chambers with air. You can't inspect them, so here is how you do it. Shut off your home's main water supply valve (usually located by the water meter inside the basement, or on the other side of the wall from the water meter if the meter is outside the house.) Next, open the nearest outside faucet to the water meter. Then open several of the inside faucets including the one in the Master Bath. Last, open the faucet that is at the lowest level of the property (usually the utility tub in the basement). Turn it on all the way to drain all the water from the pipes. As the water is drained from the pipes, it is automatically replaced by air, including the air chambers. The moment the water is completely drained from the piping the lowest faucet should be turned off and the main valve reopened. Aire will be pushed out of the horizontal and open vertical water lines and sputter as it exits the faucets inside and out. When all faucets are running smoothly, close them one by one from outside to inside, lowest to highest. In most cases, this should give you quiet running faucets.
Aug 28, 2011 | Garden
When i turn my kitchen faucet on the water is very
It is air in the line just run the sink one as it is off the main . if this does not work water company can do it from outside at a hydrant
Jan 05, 2018 | Delta Commercial 400-WFELHHDF HDF Series...
My Delta Model 174 sputters air when turned on and leaks from the base of the spout. What causes this?
Air is getting into your water line, though I can't imagine how since it's a closed system. The only time this might occur is if the water main was shut off and all the water was drained from the lines. This is only necessary if your doing some plumbing work.
Jan 26, 2010 | Delta Faucet Delta 174-SSWF Waterfall...
American Standard kitchen fawcett
It could be air if you recently had the water off at the main and let the pipes drain, but this would go away after a short while. It is most likely either a feed line from the wall to the faucet flexing when the pressure and hitting something under the sink or a water line in the wall that may have not been strapped properly to the stud when installed. They bounce around sometimes if not secured. Hopefully the feed line as the second is a bit more work to correct.
Good Luck
Nov 29, 2008 | Plumbing
Plumbing Logo
3,063 people viewed this question
Top Plumbing Experts
Paul Carew
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
