Question about Toshiba COPIERS E-STUDIO 520 Copier
Recover user data
I have an estudio 520. The hard drive "failed" (F105 message). The service rep wanted to format, but I wanted to save my customer copy counts. I put the drive in a computer and copied everything to an identical drive (WD400). The fact that I was able to copy it made me suspicious of the failure, but after he formatted it, the copier works again. Now to my question. Is there any way to get the department copy counts off the drive? I can see lots of folders, but no software I have will read the files. Quite a bit of money is owing for copies if I can get the numbers. Thanks for any info you can provide.
  • rharley Nov 17, 2008
    Thanks for the message. The problem is I can't read/interpret any of the files on the drive. In fact I don't even know the name of the appropriate file. I don't have an actual "backup" from TopAccess. I have an exact copy of the drive at the time of failure. I need to see the copy counts that were in place at that time. Of the many files, I see a binary file that was altered the day of the failure. I suspect that is it, but can't read a binary file.
  • rharley Nov 20, 2008
    In theory, this was helpful, and I appreciate it. What actually happened is Toshiba took the drive away to recover it. Whether they are successful or not remains to be seen.
  • 1,879 Answers
Make the e-FILING feature work (do not use the drive where your data is saved YET). Save and Download files/records off the network.
e-FILING Functionality:
Storage of documents in system for Print On Demand, Retrieval,Editing over Web Tool
After successful network saves/downloads, then use/get information from the back-up.
Posted on Nov 14, 2008
  • monk3ybidzness
    monk3ybidzness Nov 17, 2008
    Only the printer's system can read those files regardless where the data is (inside the printer or off the network).
    Once the e-Filing feature is active, have it read the data off the network.
    Master:
  • 505 Answers
Connect the drive to the computer and manually delete the folders and files which are not required.
Thanks
Recover All Data From Hard Drive
Yeah, you are right! When something important is lost from hard drive without data backups left, hard drive data recovery software really can help rescue it all back.
In fact, not too long ago, I also accidentally formatted my external hard drive and lost a great number of files and folder without updated backup left.
Finally, in order to rescue the recent drive files and folders back, I tried many data recovery software online and finally rescue my needed drive stuffs back with one, like this:
http://freeware-fix.blogspot.com/2013/02/external-hard-disk-format-recovery.html
If anyone also has such drive data loss problem, it may also help.
Just make drive data backups well all the time.
Jun 13, 2013 | Computers & Internet
Tip
How to fix No Bootable Media Error Message
FAT (File Allocation Table) is one of the most widely used file systems used now-a-days with various versions of Windows operating systems and memory cards. Every logical partition contains a FAT that consists of file allocation information and the information of free allocation units that need to be assigned to files. Although the FAT file system is reliable, corruption still occurs due to various reasons. In such situations of FAT corruption, your system becomes unbootable, resulting into inaccessibility of data saved in FAT based hard drive. To access the data after FAT file system damage, an easy way is to restore the data from an updated backup. But, with inaccessibility of data backup or backup falling short to restore the required data, an ideal option left is to use an advanced FAT Data Recoveryapplication that can recover the lost data.
To illustrate the above scenario, consider a practical case the below error message pops up when you attempt to boot your system:
“No Bootable Media”
As the above error message appears at the time of booting the system, you wont be able to access the data saved in the hard drive.
Cause:
The above error message because the FAT file system has been corrupted. Few main causes for file system damage are improper system shutdown, human errors, and virus attack.
Resolution:
To isolate the above error message and to access the data after the above error message appears, you will need to follow the below steps:
Run CHKDSK utility to repair the FAT file system. If the problem persists, format the hard drive.
While the latter resolution resolves the above error message completely, it also deletes the data saved on your hard drive. In such cases, if the backup is not available, then you can only recover your formatted data by using an advanced third-party FAT Data Recovery software.
A FAT Partition Recovery utility thoroughly scans a FAT based hard drive and recovers almost all data, even after formatting. The data recovery utility can be downloaded from the Internet.
Stellar Phoenix Windows Data Recovery is an efficient FAT Partition Recovery tool that recover lost, deleted, and formatted data from both FAT (FAT12, FAT16, FAT32, VFAT) and NTFS (NTFS, and NTFS5 ) based hard drives. The detailed help manual attached with the tool allows even a new user to perform recovery easily without any technical knowledge. It supports Windows 7, Vista, XP, 2003, and 2000.
on Jun 30, 2010 | Computers & Internet
F105 reboot call for service
[F105] HDD other error
Check if the connectors of the HDD are disconnected.
Check if the connector pins are disconnected or the wires of harnesses are broken.
Perform the bad sector check (08-694). If the check result is OK, recover the data in the HDD. If the check result is failed, replace the HDD.
Feb 23, 2012 | Toshiba estudio 255 Copier
I have an external hard disk drive. It has a 160 GB transcend, Yesterday, all things were working OK, but today, when I insert the disk, my laptop gets hung. The disk is being detected, but after opening,...
Firstly,recover your data on the external hard drive with third party data recovery software.Then you can format it to check out whether it can be fixed.
For data recovery program,I have a professional one on my computer that can recover data after deeply scanning your hard drive to look for lost data due to drive crash,system sabotage, virus attack etc.You can download it and scan your hard drive for free to preview whether your data can be recovered. http://www.any-data-recovery.com/product/datarecoveryprofessional.htm
Aug 04, 2011 | Transcend StoreJet 25 Mobile 500GB USB 20...
F105 On e-studio 520 Toshiba I know its the hard drive. Can it be saved???
Perform the bad sector check (08-694) takes about 20 minutes. If ok, recover the data if the results fail..you know replace HDD. Hope its not system board but that would be next if the HDD is good. Hope this helps.
Jun 25, 2011 | Toshiba COPIERS E-STUDIO 520 Copier
Suddenly drive is asking to format how can I save my data
Don't be panic. you can try some data recovery software. You can see
http://download.cnet.com/Asoftech-Data-Recovery/3000-2248_4-75328850.html?part=dl-75328850&subj=dl&tag=button
It tells the steps how to perform data recovery.
If above does not work, you may have to format the external hard drive (use quick format), and then use above mentioned software to scan again the external hard drive and recover your files.
May 29, 2011 | Western Digital Elements powered by WD 320...
I Have WD Passport Hard Drive in Side More Data But I Will Connect the HD Ask Format? How Can I Recover My Data Pls Help Me
http://www.asoftech.com/adr/
If above does not work, you may have to format the hard drive (use quick format), and then use above mentioned software to scan again the hard drive and recover your files.
Apr 28, 2011 | Western Digital WD Passport 250GB Portable...
Toshiba 451c Color Copier experiencing error F105
Hi how are you this is jack my personal Id (jack_pak@hotamil.com)
Dear follow the procedure .....
Other service call
(1) Check if the connectors of the HDD are disconnected.
(2) Check if the connector pins are disconnected or the wires of harnesses are open circuited.
(3) Perform the bad sector check (08-694). If the check result is OK, recover the data in the HDD. If
(4) Replace the SYS board.
Thanks
Best Regards,
Jun 30, 2010 | Toshiba Office Equipment & Supplies
Failed to overwrite all data bizhub 250
the overwrite data function is supposed to take about 35 hours but the ones that i have done took about 20 hours and ounce the process is started you should never interupt it this function overwrites all the data on the hard drive HD-504 you could try formatting the hard drive first then overwrite again
1touch the utility/counter button then details
2 press stop,0,0,stop,01
3 enter 00000000 touch end
4 touch tech rep mode
5 touch function
6 touch hard disk format
7 touch yes
8 touch enter when the message the hard disk format completed.result:ng appears touch ok
9 touch hard disk format
10 touch yes
11 touch enter this starts the formatting procedure
12 when the message "the hard disk format completed. result:OK appears touch OK
13 press the reset key
14 touch exit on the tech rep screen
if the format fails replace the hard drive the format process takes about 30 minutes if you need further instructions on how to replace the hard drive post it
Dec 04, 2009 | Konica Minolta Office Equipment & Supplies
67 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
