Question about Kenmore 659 Electric Dryer
Dryer doesn't turn on
I have an older lady kenmore electric dryer model # 86592110. I will not power on although the light is on and stays on even when the door is securely closed. How can I repair this? I had a problem with my washer last year and I got answers that walker me right through a self repair. I saved $200 plus dollars. Please help me again!!!
  • 734 Answers
1. No power to the dryerMake sure there's power getting to the dryer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter or by plugging something else in.
2. Door switch / Door switch actuator lever
The dryer would not start with a broken door switch. Replace the door switch if found defective.
Most dryers have a door switch actuator lever - when you close a dryer door, it presses against the lever, which actuates the door switch. If the lever is broken, the switch would not activate and the dryer would not start. Replace the lever, if broken.
Note: Door switch actuator lever usually comes with the door switch assembly and it is recommended to get the whole assembly since there is almost no price difference between the door switch assembly and just the lever. Check your model for more details.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
4. Timer
Replace if defective (note: uncommon problem).
Posted on Dec 02, 2008
We have a 15 to 20 year old Kenmore clothes dryer. Model 110 86592110 65921. The drum/tube ?? is making a terrible noise. I think the problem is that the Teflon ( or what ever it's called) that supports...
Check the rear drum rollers they are probably worn out. Just need to replace rollers
or could be front plastic glides but either one is a cheap fix.
Feb 10, 2011 | Kenmore 659 Electric Dryer
The drum turns but I have no flame on my lady kenmore dryer model 6607921
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 26, 2010 | Dryers
I have have an older kenmore electric dryer that won't start. Let me give you some detailed information about the events that happened prior to the discovered failure. -This dryer hasn't been used for a...
The heat is not a factor.Make sure you do not have a tripped breaker. Otherwis if you had a power surge to the dryer, ther could be electrical damage.
Aug 11, 2010 | Kenmore Dryers
Kenmore electric dryer shuts off after 5 minutes and won't restar
when you try to start it again do you hear a humming comeing from the motor? can you jump start it by turning the drum while holding the start button? If you say yes to these questions you have a bad motor.
Jun 21, 2009 | Dryers
Kenmore 80 series Gas Dryer
HI. you are correct. this dryer, although gas, is using a Glow igniter system. most older models used the snap igniter that clicks over and over to spark the burner but, this dryer is only 2 years old so, it should be outfitted with a glow igniter system. This igniter is powered by electricity.
It works in conjunction with a Flame sensor.
Jun 02, 2009 | Kenmore Dryers
Lady Kenmore electric dryer broken start button
it is time to replace it, that sound and smell is from the dryer motor itself.
Jun 28, 2008 | Dryers
Kenmore 659 Electric Dryer Logo
95 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
