Question about Hitachi 46GX01B 46" Rear Projection Television
Hitachi projection tv, no pictures, no sound.a red light blinkin
With only a red light blinking.
  • Hitachi Master
  • 19,396 Answers
When TV does not start, and sometimes you hear a clicking noise, that means that the TV is on protect mode.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Posted on Apr 17, 2009
Red light only blinks
ON THE BALLAST SENSOR CONNECTOR AT THE ADaPTER CHECK VOLTAGES BROWN WIRE 0.1V,ORANGE-5V,YELLOW-3V, GREEN-5V. RED-GROuND. GR. CONNECTION IS OPEN. NEED TO JUMP IT FROM THE WIRE TO THE NEGATIVE SIDE OF THE FILTER CAP ON THE BALLAST, if this doesn't do it may need a new lamp.........good success, meder's tv service
Oct 15, 2013 | Sony Grand WEGA KDF-42WE655 42" Rear...
Hitachi tv LCD blinking red light tv wont' turn on. replaced lamp model 60V500A
I have hitachi lcd rear projection tv model 60v500A at first I was getting a red spot on centar of tv with in two mounths the spot got bigger. I chanched the lamp but now i don't have a picture, the red indicator on tv is now blinking.
Aug 10, 2010 | Hitachi Televison & Video
Hitachi 55FX20B 55 in. Rear Projection - no picture or sound
TV always has high voltage shock risk while repair. As you said you are not familiar with TV repair so better to handle repair person this issue.
Oct 01, 2008 | Hitachi 55FX20B 55" Rear Projection...
Hitachi 61UDX10B
I would check for burnt resistors as the 150s are interchangeable with the 110s however in alot of hitachis I have seen resistors blow after upgradeing to the higher wattage ICs. I Usually switch out the convergence resistors whenever I go to a higher wattage IC just to be sure. If you need more help let me know.
May 18, 2008 | Hitachi 61UWX10B 61" Rear Projection...
Lost picture
sounds like video card failure mode, 101..you a technically adroit person?
Apr 03, 2008 | Televison & Video
Hitachi TV no picture no sound
Most common fix is shorted cap C702 ? near flyback transformer
and open E994 pico fuse in power supply. Capacitor is sometimes partially covered by glob of glue from factory....
Let me know right away,please......................T.
Dec 03, 2007 | Hitachi 50UX26B/27K 50" Rear Projection...
No picture or sound
you may have a flyback problem. send to nearest service station for repairs.
Sep 13, 2007 | Hitachi 50UX57B 50" Rear Projection...
Hitachi 46GX01B 46" Rear Projection Television Logo
123 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
