Question about Sony Grand WEGA KF60XBR800 60" Rear Projection Television
We keep losing sound and picture on our TV
We have a rear project TV and it recently started doing something weird. The sound and picture turns off for about 30 seconds and then will come back on. The picture returns about 5 seconds before the sound returns. The TV will then only stay on for about 1 to 3 minutes before doing it again. The green power light is still on while this is happening.
Any ideas?
  • 5 more comments
  • patandnicci Nov 14, 2008
    I wanted to add that the lamp indicator light is NOT on when this happens.
    Thanks! :)
  • Mitro Nov 16, 2008
    My "Sony - Grand Wega" keeps turning blank yet it stays on flashing a red light
  • patandnicci Nov 18, 2008
    We have not replaced the lamp. We were thinking it wasn't the lamp since the sound goes off as well. It is a Sony Grand WEGA. Not sure on the model number.
  • hazahart63 Dec 01, 2008
    my KF60XBR800 does the same cycling off/on thing. I just replaced the lamp with an aftermarket bulb on 9/27/08. The picture is good, but the cycling time seems to drop by a minute with each one; i.e. 14 mins, 13 mins, 12 mins.etc.
  • KRISTAGUY Dec 03, 2008
    THE TV SHUTS OFF AND THE LIGHT BLINKS GREEN AND WILL COME BACK ON IN 2 MINUTES AND THEN STAYS ON FOR 30 SECONDS AND GOES BACK OUT AGAIN.
  • Any Guy
    Any Guy May 11, 2010
    have you replaced the lamp recently?
  • Any Guy
    Can you tell me the brand and model of your TV? Also what do you have connected to the TV and does the problem happen on all inputs or just one?
  • 320 Answers
If you haven't replaced the lamp, it is almost certainly time to change it. A weak lamp will cause the TV to play for a short time. As the old weak lamp heats up, it draws more current, and the reflector in the lamp, having become cloudy over time, converts the light into more heat rather than reflected it out into the set. Eventually the lamp draws too much current and the set turns it off, going into a restart cycle. Buy an original Sony lamp, as the aftermarket replacement lamps are known trouble makers. Be sure to rate this solution. Thanks!
Posted on Nov 18, 2008
  • Any Guy
    Any Guy Nov 18, 2008
    As far as the second user "Mitro", a flashing red light usually means something else is wrong. Can you tell me how many times the light is flashing and what the model number of your TV is?
Is it possible to replace the bulb in this tv or something like that? I was watching it the other day when a loud pop occurred and there was some burning smell accompanied by the picture and sound going...
Shop around for the Big Screen repair Tech. Shop.The problems u discribing,the tv have more than a dead projection bulb.Circuits boards have burn components,must be trouble shoot and replace first.Before even know the static of the projection bulb.
Jul 16, 2010 | Sony KP-53S65 53" Rear Projection...
RCA Scenium 52 DLP
you should take it to a tv repair shop to look it over, they charge $50 and they will tell you want the problem is.
Dec 17, 2007 | RCA Scenium D40W20 40" Rear Projection...
Have picture lose picture tv turns off and on
the lamp has a life cicle. if yours is been used a lot. then the lamp has to be changed. when the tv cannot turn on steady and gets off imm. the computer inside the tv tries to turn off the set but the lamp charges again and the micro tends to keep working. the first step to take in this tv is to change the lamp to eliminate this common source of problems
Jan 21, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
VS-50803 50" Mitsubishi No picture problem
Sounds like your picture tube has went out,, or maybe something simple,, to fix,, i would at least let a tv shop check it out ,, worth a chance ,, nothin 2 loose,, good luck
Oct 05, 2008 | Mitsubishi VS-50803 50" Rear Projection...
RCA Rear Projection problem
the problem with that is probably that your blub has gone out and need to replace it.
Sep 24, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
KP-46S4U lose picture after a few second blink of brightness
does the from led blink if so how mant times pause then blink again?
Feb 12, 2008 | Sony KP-48S65 48" Rear Projection...
HLP5085W
If you look in the back of your tv, you should be able to see the light from the bulb, if the bulb isn't working no light.
Oct 12, 2007 | Samsung HLP5085W 50" Rear Projection...
Losing Picture
It sounds like the tv is dieing but since it is rear projection you may be able to fix the problem by replacing the bulb in the tv
Jun 20, 2007 | Hitachi 50UX57B 50" Rear Projection...
Snap crackle pop
Check the Flyback, had same problem, replaced it and the unit worked good.
Oct 15, 2006 | RCA P46921 46" Rear Projection Television
Sony Grand WEGA KF60XBR800 60" Rear Projection Television Logo
140 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
