Question about RCA F32650 32" TV
F32650/atc113ca1 pushed power button to tune on tv,,green light on power button blinked twice,then went out,tv did not start! unpluged power cord for about one hour or so..thinking tv has to reset itself..pluged tv back in to serge protector..pushed power button again..no lights on..just a loud chirpping sound..unpluged power cord ..repluged cord in ..again..same thing happened...what went wrong..worked fine before for about 3 years..on problems what so ever,untill this time...maybe because i pushed power button twice..wanted to turn tv on but changed my mind..after that i had this problem..did i do the wrong thing like pushing power button on like a computer mouse? help me,i like the tv..has xbox connector build into it...
  • 1 more comment
  • gary l. henritzy Nov 16, 2006
    help me find service manual for f32650/atc113ca1.
  • TINYS Jan 06, 2009
  • R E May 11, 2010
    is chirping sound on when plugged in, sounds like transistor failure
    Scholar:
  • 68 Answers
This could cause a problem, because modern TVs and most other entertainment electronic goods, have a small kind of computer chip, but there should be a Reset button probably inside the set! If you feel confident about computer chips you may be able to find the button by tracing the circuit.(Disconnected from the mains). Another idea is if there is a small button cell or battery inside, then try disconnecting it for a day. Good Luck!
Posted on Dec 02, 2006
SOURCE:
I have a RCA TV model F32650 Chassis ATC113CA1 and when i turn it on the green on light comes on and off 3 times then shuts off, i put a new fuse but it still does same on off 3 times, does anyone know...
I already figured out that my flyback transformer was bad, this is an ongoing problem with a lot of RCA CRT televisions because RCA used very cheap parts in order to save them more money, rather than making there customers happy with good quality parts, and my TV was made in MEXICO, and that my friends is why we the American people are getting screwed. (Shame on you RCA)
Jan 05, 2010 | RCA F32650 32" TV
TV will not turn on. Push power button green
Try this and let me know what you find:
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} MOST OF THESE SETS HAVE A SELF DIAGNOSTIC:
UNPLUG TV AND THEN PLUG BACK IN---TURN ON---GREEN POWER LIGHT COMES ON FOR A MOMENT AND GOES OFF.
PRESS AND HOLD “device” and “menu” buttons on front of tv for at least 5 seconds and then release both together.
Watch for power light to blink in a sequence:
1 blink-then 2 blinks-------no error
2 blink-then 1 blink-------X-ray protection
2 blink-then 2 blink-------SHORT PROTECTION*******
2 blink-then 3 blink---------deflection circuit problem
2 blink-then 4 blink---------vertical circuit problem
******2, then 2 is most common---usually means one of the fuses that protect the Convergence IC or IC’s is blown---set will detect no voltage to convergence IC and shut down.
SET WILL REPEAT BLINK ERROR CODE UP TO 5 TIMES AND THEN TO GET IT TO REPEAT MORE YOU HAVE TO UNPLUG SET AND TRY TO TURN ON AGAIN.
IF IT IS 2 AND THEN 2---USUALLY
CONVERGENCE CIRCUIT PROBLEM
If it is 2,2 I have START TO FINISH STEP BY STEP INSTRUCTIONS AND PHOTOS TO SHOW YOU WHERE THE FUSES & PROTECT RESISTORS FOR THEM ARE LOCATED.
The instructions tell you everything you will need for the repair and how to do it.
You can buy all the parts needed for less than 30 dollars on Ebay (I know the best seller there) I have repaired hundreds of these sets with this problem
If this information has helped you rate this solution as I do this here for free.
If you want the instructions & photos let me know and I will post them here for free.
SD TECH
Dec 09, 2009 | Mitsubishi WS-55809 55" Rear Projection...
I have an RCA D52W20 with chassis ATC 221 that no longer works. When plugged in, the green power light blinks twice and then goes out. When the power button is pushed the light blinks twice, then about 4...
The tv is going into protection shutdown. It will try to power up three times, but each time it tries, the microprocessor recognizes an overvoltage, or overcurrent draw, and after three attempts it will place the unit into protection shutdown. There can be many causes of this, but the most likely one is that there is a short circuit in the high voltage circuits. You probably have a shorted flyback and associated components.
Nov 28, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
I cannot get the printer cartridge to go to the left so I can take the cartridge out to replace. On-off green light keeps blinking - help!
unplug power cord, press power button and plug the power cord. do not release the power button. press resume button twice then release the power button.
turn off the printer.
turn it back on hopefully it will solve the problem
Oct 04, 2009 | Canon PIXMA iP1600 Printer
Same thing happened to me
Well, no sound no picture = power supply unit
Sound no picture= flyback
picture no sound =tuner/audio logic
You get my drift?
You power supply is bad you replace it you got another new TV, with this digital conversion hitting I would rather advise you to get a nice flat panel and donate that one to Goodwill
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Jun 13, 2009 | RCA F32650 32" TV
Sony Triniton Wega Model KV 32HS510. After pushing the power button,the tv starts to power up, then the standby light blinks 7 times then pauses before blinking 7 times again. It continues to do this,...
This is usually an indication of a failure in the scan amplifier sections. When the scan amplifiers or high voltage sections fail, the main power supply will usually also require servicing.
It is very common that the fly-back and high voltage multiplier and also the horizontal output stage fails in these sets. Along with it, the power supply will usually require to be serviced. On rare occasions, the vertical deflection amp fails.
Jerry G.
Jul 08, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
Power button is green - no blinks / no picture / no sound
Unplug it from the wall, wait 2 minutes and plug it back in. if problem still exists, its probably the main pcb.
Jun 19, 2008 | Dynex 32 in. LCD Flat-Panel HDTV
RCA F32650
I let it go and she corrected by herself. What do you think?
Aug 14, 2006 | RCA F32650 32" TV
RCA F32650 32" TV Logo
291 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
