Panafax UF-585 will not receive faxes, it just rings and rings. Memory on the LCD states 16% not sure if that has anything to do with it but it normally says 99 or 100%. Phone line has been checked it is working fine.
  • 1 more comment
  • jenl997 Nov 14, 2008
    How long does the All job clear or the shipment set take - the fax seemed stuck in All Job Clear Initialize now and didn't move or reboot - just wondering how long it takes.
    Also - we don't have a flash memory card - should we?
    OK - I waited and it did reboot - but it is still just ringing and not receiving faxes anything else I can try?
    Genius:
  • 2,120 Answers
Press the OUT button.
Unplug the power cord for 10 seconds.
If all else fails:
Open the toner door
Press FUNCTION
press 7
Press monitor key slowly 4 times
press *
press 6
scroll down to ALL JOB CLEAR
press SET.
or
scroll down to SHIPMENT SET
press SET
press 2
machine will reboot
Posted on Nov 13, 2008
  • Leroy Elliott
    Leroy Elliott Nov 14, 2008
    While it's ringing, press the START button.
    try SHIPMENT SET...same steps as above..
    Otherwise, i'm stumped because if it rings, it's should be OK.
  • Leroy Elliott
    You don't need a memory card.
The lcd screen does not work any more and i cannot fax panafax uf - 585
hi hahudson,
I think you need a physical service of that fax machine.
mastergani
Feb 04, 2011 | Panasonic Panafax UF-585 Plain Paper Laser...
I have a Panasonic Panafax UF 595. Battery error
The battery case is next to the small blue lever where the document is placed to fax out.
Feb 16, 2010 | Panasonic Panafax UF-585 Plain Paper Laser...
Panafax 585 block fax reception?
Press
Function
64
set
look at your settings again
Fax number 1 set to tel
Fax number 2 set to fax / tel
Feb 18, 2009 | Panasonic Panafax UF-585 Plain Paper Laser...
PANAFAX UF-585
Bad fax stuck in memory. Press:
Fuction
7
6
set
Nov 02, 2008 | Panasonic Panafax UF-585 Plain Paper Laser...
UF 585 Fax Machine Message in memory
if its only a few % like 1, 2, or some thing its probably nothin retrievable, you can have a tech come and clear it but if all else is working and the mssage in mem file dosent keep growing try and ignore it till next service
May 05, 2008 | Panasonic Panafax UF-585 Plain Paper Laser...
Panasonic Panafax UF-585/595
could be a number of causes, most common someone fiddling with settings, secondly adsl internet und unfiltered lines so put filter on fax and any ext. ph. lines also contact your telecomunnications co. (and waste hours of time, be put on hold 25 times, told your account number isnt valid, theyre having a glitch in the system, its not their problem, youll have to ring back later, confirm your adress, D.O.B.- Ph no. -credit card no.- tax file no.- and your third cousins 2nd wifes stepsons- ex girlfriends- brothers 4th grade teachers middle name) and ask to have the line checked
Mar 28, 2008 | Panasonic Panafax UF-585 Plain Paper Laser...
Panafax UF-585
You can find that option in Service Mode 6 (Ram Initialize).
Hit Function + 7
Hit Monitor 4 times, then " * "(star)
Press 6 for Ram Initialize
Option 14 (All job clear) is the one you are looking for.
Hit enter and it will run for a few seconds and reboot itself.
Jan 14, 2008 | Panasonic Panafax UF-585 Plain Paper Laser...
111 people viewed this question
jasbo
jasbo
