Question about HP iPAQ HX2795 Pocket PC
IPAQ 2795 freezes during boot up.
New iPAQ 2795 freezes during boot up. I had it about a week and just configured the ActiveSync bluetooth last night. Hot restart doesn't work and I'm unable to conduct a Cold start.
  • jccf May 25, 2008
    screen freezes during boot up and screen backlight shuts off. :/
  • utlx Aug 23, 2008
    I have the exact problem which occurred during a firmware update. I need a way to get my 2795 to boot up. I have tried all suggestions may by HP support to no avail. Please help.
I had the same problem. Contacted HP customer service chat, and got the following answer that
solved the problem:
1. Remove the battery for 30 minutes.
2. Insert it again in the iPAQ.
3. Perform a clean reset on the iPAQ and at the same time charge the iPAQ.
To perform a clean reset please follow these steps:
Press and hold the Calendar button, the Power button, and the Messaging button.
While holding these buttons, use the stylus to lightly press the Reset button on the bottom of the HP iPAQ.
The problem can also be solved by getting a new battery, and performing the clean reset while charging (using the portable charger, not the cradle).
Posted on Feb 05, 2009
Pocket pc 3850
Set it up with what? Do you mean sync with your computer? Are you using USB or Bluetooth?
Best thing to do.
1. Unplug your USB connection from PPC -> Computer
2. Uninstall Activesync if you have it installed
3. Restart your computer
4. Re-install activesync
5. Restart your PPC
6. When asked to connect the PPC connect it via USB
Jan 06, 2008 | Compaq iPAQ H3850 Pocket PC
HP Pocket 2003. Need to restore information but not recognising profile. Where do I find the files on PC to copy mobile devise. Using XP student edition
Syncronation profile? you should make a new active sync profile.
or do you mean something else? please be more spesific.
if your device was hard reset and you need to restore something.
tell me what exactly.
Mar 28, 2008 | Computers & Internet
Activesync via bluetooth
Click on Ipaq wireless
turn on the blutooth
Click on Manager
at the bottom click on new
and then click active sync via bluetooth and go from there
Jan 02, 2008 | HP iPAQ HX2490 Pocket PC
Activesync problems with IPAQ 1940
 connect the cable with pc , open the active sync on ipaq then connect the cable with ipaq..if not still soft reset ur Pocket PC and reconnect.
Sep 17, 2007 | O2 Xda IIs Pocket PC
Calendar and outlook sync
Is ActiveSync set to sync only items from the last 2 weeks?
May 22, 2007 | HP iPAQ H2210 Pocket PC
ActiveSync Problems
If you tried it on two different desktops and you tried it after a hard reset, I would say that you have narrowed it down to a hardware problem. When you tried it on the two PCs did you use the same cable to connect it? If yes you might want to try a different cable or if possible you can you try a bluetooth sync? If a different cable or bluetooth doesn't work you probably need to have the device repaired.
Sep 11, 2005 | HP iPAQ hw6515 Pocket PC
Data erased from iPAQ hx4700
If an ipaq loses power , then all data in RAM is lost. It's important to keep it charged. It's also important to do regular backups..... so there are two backup options - one is thru Activesync which will backup to your PC and one is the IPAQ's own backup program which will backup to the IPAQ FILE STORE (area in ROM) or a SD card. I do the Activesync backup every time I sync and then the IPAQ backup about once a week or immediately before a system change. Activesync backup ------------------------ Here is a guide which best explains it http://www.cewindows.net/faqs/activesync/backup.htm this guide suggests doing a full backup, but it's fine to do an incremental backup each sync - this means that only changes will be added to your backup and makes the whole process much quicker. IPAQ Backup ----------------- So under Programs is a program called IPAQ Backup. The default location is IPAQ FILE STORE which is an area in ROM and is not lost thru a power failure nor hard reset. You may also choos to backup to a SD card - a full backup will need roughly 20MB. So in this backup procedure, if you click on 'Browse' you can choose a SD card. A restore can then be performed from the IPAQ FILE STORE or SD card (depending on which location you chose) and so if you are away from your PC, this will be no problem. A restore this way , rather than thru Activesync is also much quicker, so if you have a choice go this route.
Sep 11, 2005 | HP iPAQ HX4700 Pocket PC
Sync via bluetooth
Does your USB adapter provide serial port connections ? I had the same issue with an USB adapter with a dedicated-to-phone software. I changed to MSI bluetooth adapter and then made a serial port available to COM5, then connect activesync to COM5. (make sure on the ipaq you create a shortcut "activesync connection" and pair with the bluetooth adapter.
Sep 11, 2005 | HP iPAQ hx2410 Pocket PC
ActiveSync
try soft reset on your Ipaq and a restart of your PC.
I have bluetooth Activesync working on my hw6515 connected to a Dell x300. Followed the instructions in the User Guide Chapter 9. Need to take note of the com port assigned to bluetooth serial port on the PC. Connection must be initiated each time from the IPAQ ie go to buetooth manager and connect the activesync shortcut.
Sep 08, 2005 | HP iPAQ hw6500 Pocket PC
HP iPAQ HX2795 Pocket PC Logo
795 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
