Question about Cell Phones
Nokia 5300 Phone problems
I have 2 phones all 2 not working here is problem 1 the phone got wet i dry it out it worked for a couple of days and then start telling me no network coverage problem 2 it was working and just stop comes on and shows a white or grey screen
  • 1 more comment
  • Steven Estwick
    Steven Estwick Nov 15, 2008
    Thanks for the infomation on the 2 phones the first 1 with the power amp or antena problem i will take to the service center the second problem is not the display screen i replace that already and i try the the piece inside in another phone that is working and still the same problem grey or white screen so i need another solution to that problem can it be the circuit boardwait on your reply thanks
  • Steven Estwick
    Steven Estwick Nov 16, 2008
    Hi,yes the phone is nokia 5300 i have tried all the solution you have given me if you have anything else i can try i would greatful i even try it in another phone the circuit board same problem grey or white screen leave your telephone # so i can call you direct thanks i live in Barbados +246-2434773
  • Steven Estwick
    Steven Estwick Nov 18, 2008
    Hi i have tried all those already but thanks alot
  • 283 Answers
1st phone
-since the phone was wet the probable problem of your unit might be either its antenna switch or power amplifier. I suggest to go to service center.
2nd phone
-need to replace the LCD of the phone.
thank you for using fxya....
Posted on Nov 14, 2008
  • 1 more comment
  • amin dianalan
    amin dianalan Nov 16, 2008
    Is your cellphone nokia5300? change its flexible wire or ribbon wire...thank you..
  • amin dianalan
    Please dont forget to rate me thank you..
  • amin dianalan
    amin dianalan Nov 17, 2008
    since you have 2 nokia 5300 try the upper board(1st unit) to the other..Thank you...
My nokia c3 got wet and i turned it on its shows only white screen is there a high chance it will go back to normal?
You should have turn if off imediately and removed the battery and then dried out your cell phone for several days in a warm dry place.
Most likely the cell phone is damaged, you maybe lucky, remove the battery and dry your cell phone for several days, then see if it works properly.
If it does not work, I suggest you put your money towards a new cell phone instead of getting it repaired as the cost of repair may not be a cost effective solution.
Apr 18, 2012 | Nokia C3 Cell Phone
Hi my Nokia 5230 touchscreen phone got wet in my bag this morning and now it isnt working, the lights go on and i can phone it from the house phone, but the screen is blank so i cant read, sent texts of...
Take battery, back cover, sim card and memory card out. Leave it in dry and warm place. Let it be there 2-4 days and let it dry, after this you can hope it works but there is no guarantee.
Hope it helps.
Jun 07, 2011 | Nokia 5230 Cell Phone
Assalam o alaikum. my cell drop into water tommorrow next day working right.but now many of buttons are not working??? what i can do for this? Thanks
Number 1 rule if your phone gets wet... DO NOT turn it on.
Remove the battery from the phone. get a small ziploc freezer bag place phone in bag pour uncooked grains of rice into bag. Enough to cover phone completely. Close bag. Let it sit for at least 2 days.
This is to absorb all the moisture from the phone. Remove phone, insert battery and try using it. It may work. But you need to wait until your phone is completely dry before attempting to use it.
Mar 09, 2011 | Nokia 1208 Cellular Phone
My phone no work , &my phone creen was white
When phone is blank. There have been many incidents ofpeople accidentally dropping their cell phones into various bodies of water orother liquids. If this happens to you and your cell phone gets wet, you maythink at first that it is damaged beyond repair and dread the cost and hassleof replacing it. But with some resourceful thinking, in many cases it ispossible to save a wet cell phone if you take action quickly enough. Remove battery and Sim cardimmediately. 1. Wait it out. Yes, it's boring and will take a while, butthis is probably the safest method overall. Just let the phone sit out in a dryplace for at least three days while the water evaporates. A variation on thisthat might speed up the drying process slightly is to leave the phone on top ofa low heat source such as a television or cable box. 2. Put the phone in a bowl of dry rice. Many people havehad success with this one, and it makes sense because uncooked rice can absorba lot of water.If still problem, please contact Nokia service dealer.
Dec 31, 2010 | Nokia 5130 XpressMusic Red Unlocked Import...
I want to format nokia 5300 but code *#7370# is not working
that code can't works at 5300,its only you can do for phone like 6600,7610 (WD 2).for 5300 go to setting than restore factory setting with code 12345.
May 20, 2010 | Nokia 5300 Grey Cellular Phone
Nokia 5300 Wont Send Text Messages
i had the same problem. first try turning the phone off then back on and if it doesnt work after that then go into menu>optus>SIM Backup and turn it on
worked for me
Apr 11, 2008 | Nokia 5300 Grey Cellular Phone
Samsung A707
well that means you have liquid damage and you have voided your warranty on your device. Your only option is to buy a new phone or take advantage of insurance if you have it!
Mar 29, 2008 | Samsung SYNC SGH-A707 Cellular Phone
Nokia 5300 xpress music mobile phone won't ring
did you going to settings and then to tones?
Jan 19, 2008 | Nokia 5300 Grey Cellular Phone
Wet nokia 6630
i think now is too late but next time pour it onto a jar full of rice. the rice'll dry it up in 2 days
Dec 01, 2007 | Motorola Mobility V600
Wet Phone
Sometimes you can save them by not turning it on and putting it in the hot water cuboard for couple of days, but if you have tried turning it on already... well sorry mate its got liquid damage and thats the worst thing you can do to a phone . Best advice replace it.
Jun 06, 2006 | Nokia 6230
Cell Phones Logo
81 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
