Question about Emagic EMI 6/2 USB audio External Sound System
Rca to midi adaptors
I've lost the adaptors to my sound card and I had in mind to make my self new ones. My questin is now witch wire from the RCA plug should be connected to wich pin in the DIN contact. regards J?rgen
0 characters
1 Points
I have an error message that says: Error wile trying to synchronize Audio and MIDI Sample Rate 38441 reciognized. Check conflict between GarageBand and external device. Any suggestions?
what you need is a "FULL DUPLEX ASIO DRIVE",which you get with programs like cubase sx, this is like a universal driver which has always synced any audio equipment i've hooked up to my computer, internal & external.make sure it's the full duplex & not the asio4all v2.
But really you shouldn't be having much trouble if your using a USB midi interface.unless your computers sound card is ****.
try resetting the sound cards sample rate to 44100HZ which is the standard rate for most audio,or 48000HZ for digital.
May 16, 2011 | Tascam US122 Audio/MIDI Interface with...
Word clock /midi connector pinout
1: MIDI OUT 1(PIN 4)
2: MIDI OUT 1 (PIN 5)
4:MIDI OUT 2 (PIN 5)
5:MIDI OUT 2 (PIN 4)
6:MIDI OUT 1 (PIN 2)
7: -
10: MIDI OUT 2 (PIN 2)
11:MIDI IN1 (PIN 4)
12: MIDI IN 1 (PIN 5)
14: MIDI IN 2 (PIN 5)
15: MIDI IN 2 (PIN 4)
That's it!!!
I had the same problem as you and this was the first web I saw. I was looking for it in other webs but, least the guy who selled me the Terratec mic8 ews found the cable, so I believe that i had a matter to help people that has the same problem as me!
Apr 08, 2010 | TerraTec Electronic EWS MIC8 Sound Card
We want to change game port to midi
there is an adapter that will give you 2 midi connectors, as a matter of fact I have one right here, even includes a piggy backed female 15 pin connector for you to still be able to plug in a game controller.  Look for it in music shops that sell computer based recording / composition software and hardware.  I think I paid about CAD20 for mine
Mar 17, 2009 | Creative Labs Sound Blaster Live! 5.1...
Us-122 lost cd;9,15,69,19.html
there is all the info you need there good luck its a nice unit
Nov 28, 2008 | Tascam US-122 USB Audio/MIDI Interface...
No midi sound
In sonar go to the options menu and select: Audio -->advance. and from the list select the "Asio" driver, then you'll have a new midi output (synthe sw...) select it to have a sound while playing MIDI files.
Sep 21, 2008 | Edirol UA-25 External Sound System
TASCAM 144 is not a soundcard, but an audio interface
You are correct, there is no "voice generator" within the Tascam US-144.  It can simply transmit the very primitive note-on note-off type data to a Sound Module or keyboard (like a Roldan SoundCanvas), and then that would generate the actual waveforms.
A SoundCanvas would suit your needs well, as you could run the midi out to this voice generator, and then run the stereo output of that back through the Tascam and into the computer for recording.
Aug 11, 2008 | Tascam US-144 Sound Card
I still haven't fixed my MIDI CRISI PROBLEM. I am still looking for solutions in your audience of other web users in this type of MARK OF YHE UNICORN PC MIDI FLYER. I found a an article on the PARELLAL THAT IS USED ON IT. I need all the information I can get to.I was testing this product with the VISTA OS AND HEARD A SOUND-IN PORT, NO SIGNAL. Still need more answers. I Really need the DRIVERS/DOWNLOAD AND THE MANUAL of this product. I am doing at this point freehand.I'll continue to look on your website for help. I prefer the Free Tech Support at this time.
Thank you for notifying me and I will continue to look for help on your web site
Jul 22, 2008 | Mark Of The Unicorn PC-MIDI Flyer Sound...
No midi out device is detected
If you dont have a joystick port on the card, then you dont have a midi out. make sure your "out" or"playback" is patched to your card's synthesis engine, wavetable or GM/GS midi playback, and not to a "midi out" which really means a physical midi port.
Mar 01, 2008 | Creative Labs Sound Blaster Live! 5.1...
S/PDIF not working
Hey hoof
My only experience with faint sounds is when ground wires in the particular circuitry are not property connected. That means tracking the wires from the one end to the other if you can get to them. If they are not embended in a casing or housing I would change them.
Also, try changing the RCA plugs; even their connection can cause the sound shorting if there is a short.
Well....hoof... well,,,,good luck buddy.
Dec 31, 2007 | M-Audio Delta 1010 Sound Card
Audiophile USB / OSx 10.4.10 / Audio is fine but Midi not appearing anywhere
Ok her's wuz up! It's the install **** that this driver's been tackling with since the beginning! (This somewhat goes for the oSX to i gues =) Anyway, so...
1. Uninstall the whole thing! Also run regedit (XP,Vista?) and delete everything named "Audiophile" (installed audio apps mostly recognices to the new drivers once installed so don't worry).
2. Then reboot and run the new drivers - and remember that old ****, click "continue anyway" at all THREE times.
3. Then reboot again (do NOT turn the card on yet). I turned it on after shortly after BIOS screen and that was almost too early! Anyway, then follow the "found new harware" routine - TWO times - one for SOUND and one for MIDI.
This might seem basic and all but, hey... with theese kind of cards.. sheeesh!. And when ARE they going to get there "protocal" aproved?! Next OS?!
Jul 02, 2007 | M-Audio Audiophile USB Audio and MIDI...
Emagic EMI 6/2 USB audio External Sound System Logo
37 people viewed this question
Top Emagic Audio Cards Experts
Brian Sullivan
Brian Sullivan
Sudeep Chatterjee
Sudeep Chatterjee
Teet Bergmann
Are you an Emagic Audio Card Expert? Answer questions, earn points and help others
