Question about Mitsubishi VS-50605 50" Rear Projection Television
Mitsubishi 50 inch projection tv
Hi my name is bill i have a problem with mitsubishi 50 inch rear projection tv when you look at the screen arond the edges they have a 3 D effect in the middle of the screen its clear
  • Anonymous Apr 09, 2009
    i have the same thing happening with my tv
You probably have a problem with the convergence board.
Posted on Apr 05, 2009
I keep getting a blank blue screen when I turn on my Mitsubishi 60 inch TV and then turns off by itself after about a minute. When I press "pip" on my TV remote I can see a small square screen...
there are 2 tuners in a rear projection tv. maybe the main tuner is faulty or the tuner's associated circuit has problem. if there is no signal these tv are programmed to turn the power off/stand by.
Aug 19, 2011 | Mitsubishi VS-50603 50" Rear Projection...
We have a 52 inch rear projection Mitsubishi not sure of the model number and the picture is starting to go blurry with reds and greens at the bottom of the screen
Here is another similar problem with a Mitsubishi Rear Proj. TV and it has some things to try and an estimate if that is the problem.
"Cost of convergence repair is always around $400"
http://en.allexperts.com/q/TV-VCR-Stereo-1749/Mitsubishi-WS55511-Projection-TV-1.htm
You could also try messing around in the menu for convergence adjustments. Usually it will let you adjust at 8 points on the screen.
Oct 26, 2009 | Mitsubishi VS-50607 50" Rear Projection...
My 10 year old 55 inch Mitsubishi rear projection shuts off.
The main board/switch is worn to the point it will not work anymore after a while, I been in the business for years, These are wonderful TV's, yes there are replacement parts but a quick fix your looking for here will be unsuccessful this is the reason I am providing my advice and take a chance on the rating your going to give me. Try www.ebay.com look for people that is saling parts for these TV's.
May 03, 2009 | Mitsubishi VS-50607 50" Rear Projection...
Mitsubishi WS 65857 Picture problem.
Mitsubishi's have been known to "burn in" when you have a stationary image on the screen for too long. Usually its not a problem but in some cases I've seen..if its hours and hours of game play..or even places like home shopping network that have phone numbers that never move during the broadcast...it can cause the image to burn the screen.
The projection tubes would not be burned...it would be the mirror viewing screen.
Apr 24, 2009 | Mitsubishi WS-65857 65" Rear Projection...
Yellow hue in center edges are ok
These tvs have had optical block problems. How old is the TV? This may be under warranty.
Apr 16, 2009 | Hitachi 50V710 50" Rear Projection...
Hi, have a 50 inch rear projection Mitsubishi. The problem is that the picture is curved and some of the words around the edges are doubled. Its most noticeable when watching sports because the score board...
power transistors in the convergence circuits on this series TV go bad after several years, making the wavy lines around the edge of the screen and 'doubling' of the edges of the text in varied colors which do not converge. Professional repair is required unless you are brave enough to tackle the project yourself and follow some rather simple instructions, buy a few tools from Radio Shack, and save yourself about $500 bucks...which I did on my own 42" Panasonic rear projection set.
Feb 01, 2009 | Panasonic PT-51HX41 51" Rear Projection...
Dull almost Foggy picture.
you need to take the screws out from around the screen in the back, on edges, go to the front and take the screws out from the bottom of the screen, should be 4 or 6 in the front, pick up on the screen and lift off, only about 8 pounds, now clean the little mirror in front of the projector, and clean the dust off the projector lence, that will solve it, iv had to do this on about 50 of thease tv's
Jan 08, 2009 | Mitsubishi WD-52327 52" Rear Projection...
Double vision on my Mitsubishi 46 inch width screen--TV is 5 years old
any repair shop can re converge the tv for you.id do some calling arond and get a few quotes to see what it would cost to have them come to you
Oct 09, 2008 | Mitsubishi WS-55513 55" Rear Projection...
Mitsubishi rear projection tv color problem
I'm going to guess that this unit is a DLP projection set and that the lamp is not new. Try a new lamp. The heat of the lamp will char over time. If not the lamp, some of the internal filters in the light engine might be getting effected by heat and require replacement.
Keep us posted.
Dan
Sep 12, 2008 | Mitsubishi Televison & Video
Mitsubishi VS-50605 50" Rear Projection Television Logo
1,081 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
