Question about Desa International Powerfast Heavy Duty Staplegun
Staple Gun: PowerFast Heavy Duty No. 31690. Won't staple.
I loaded it touse, and the staples wouldn't move forward. I slid the staple loaderout and a metal gadget fell out. It has a spring attached to it. Apparently this is what makes the staples keep moving foward, and itbecame dis-attached. I can't figure out how to re-attach it. And towhat!
It would help if I could see a diagram. I don't see how to get in to where the spring is to be re-attached, even if I knew exactly where.
Thank you for your reply.
5 Suggested Answers
  • 384 Answers
SOURCE: how do i load the Desa Powerfast heavy duty
Turn Stapler over.
Posted on Aug 06, 2009
  • 3 Answers
SOURCE: I have a PowerFast staple gun #31600. Can not
I got some staples stuck in my Powerfast 31600 too. I THOUGHT they were the right staples, I was wrong. You have to bend a little tab on the bottom of the stapler to let the slide come out of the back. Then you can remove the staples. Replace the slide and tap the tab back into place with a punch.
Posted on Aug 11, 2010
SOURCE: I need to replace my
http://www.bizrate.com/staples/powerfast-staple-gun-31600/
Well there is a link, also Ebay has them too i believe.
Posted on Sep 07, 2010
farmerbear
  • 490 Answers
SOURCE: How do I load my
Howdy, I don't have pictures, but that model is loaded from the bottom (not the back,as one might expect) while the plunger is pulled to the rear then pushed back in once the staples are laid in the track on the bottom. Handy once you get used to it:)
Regards, Farmerbear
Posted on Sep 09, 2010
Follow the directions on the bottom where it says Press to open. Slide the silver loader out. It appears as though the staples should load on top of the silver loader. When I do this, the stapler does not work. When I insert the staples directly into the opening that was created when the silver loader is pulled out (the staples pointing up), close the silver loader which closes all the way with the staples on top (like if you had loaded them on top when it was sticking out), and press the handle. Works the first time! I don't know why it works this way and not when I load it from the top when the silver loader is sticking out. I just wanted to get it working! Hope this helps others in the future.
Posted on Dec 27, 2012
Loading staples into a Stanley sharpshooter staplegun
There are 4 staplers in the Stanley SharpShooter family. You drop the staples on top of the "slide out loader," then slide it into the gun. See models and staple sizes below:
TR150HL Stanley Sharpshooter
  • Stanley SharpShooter TRA700 series or Arrow T-50 heavy duty staples
TR150 SharpShooter
PHT150C SharpShooter Heavy Duty Hammer Tracker
  • TRA700 series or Arrow T-50 heavy duty staples (1/4"-3/8")
TR250 SharpShooter Plus Heavy Duty Staple/Brad Nail Gun
  • Stanley SharpShooter TRA700 series or Arrow T-50 heavy duty staples and 1/2", 9/16" and 5/8" Brads
More information on the Stanley SharpShooter and a quick loading demo can be found here: http://www.expotv.com/videos/reviews/12/134/StanleyTR150HLSharpShooterHeavyDuty/185661
Sep 11, 2012 | Stanley Proto Stanley TR150HL SharpShooter...
I have a stanley heavy duty stapler TC110. When I put my staples in, they don't seem to be catching. There is some black part sticking out of the end where the staples should come out. It looks like...
The staples load on the underside of the stapler.
Step 1 Push down and retract the stapler pushup mechanism.
Step 2 Position the stapler so that the moving hammer handle is down
and the staple exit is up
Step 3 Load the staples into the chamber on the bottom with the points up.
Step 4 Push the pushup mechanism into the locked position until it latches, you will feel the spring resistance as the staples are pushed into place.
Sep 04, 2011 | Powerfast Stanley TR110 Light-Duty Staple...
How do i open the stanley tr110 staple gun to load the staples
Angelbabie...Like most things, it's pretty easy if you know how.
1.Release the loading latch located on the back end of the staple gun by pinching it with your thumb in a downward motion. This will release the catch and allow you to pull the loading slide out.
2.Hold the gun upside down (so the staple don't fall out) and place a stick of staples in the bottom of the channel which will be exposed once you pull back the loading slide.
3.Push the slide back in and make sure the latch is engaged. All good to go!
Happy stapling.
Mar 01, 2011 | Powerfast Stanley TR110 Light-Duty Staple...
How do I load new staples in my TR110?
there is a lever on the back that you need to pull down in order to load the staples,, now it is spring loaded - so you will need to depress it and slide it back to reveal the chamber.
c...
Feb 15, 2011 | Powerfast Stanley TR110 Light-Duty Staple...
Bought 5/16 8mm staplescannot get to fit in channel so stapler can beused
This gun uses the T-50 style staples. It uses Heavy-Duty, Narrow Crown Staples.
Jan 06, 2011 | Powerfast Stanley TR110 Light-Duty Staple...
How do I load my manual powerfast staple gun? Pictures?
Regards, Farmerbear
Sep 08, 2010 | Desa International Powerfast Heavy Duty...
I'm stumped -- I just bought a Stanley Heavy Duty TRA700. I took the "safety" off (the wire loop that holds the handle down), pinched the lever on the back and slid out the tray the staples go into. I...
The question here is what are standard staples in YOUR opinion? Are they designed to be used with this staple gun. What length are the legs of the staple 1/4" or less.
You cannot just use any staple in these guns They have to be the correct type either stanley or Bosh
Please rate my help++++Thanks for using FIXYA
Jun 20, 2010 | Stanley Chrome Hd Staple Gun Tr110
LOAD IT
pull out the spring at the end of the gun. turn the staple gun upside down. Lay the staples in the track pointed side up, push in the spring slide so that it locks. You are ready to staple.
Nov 08, 2008 | Powerfast Stanley TR110 Light-Duty Staple...
Desa International Powerfast Heavy Duty Staplegun Logo
215 people viewed this question
Top Desa International Tools & Hardware - Others Experts
john h
Tom Chichester
Are you a Desa International Tool and Hardware - Other Expert? Answer questions, earn points and help others
