Question about Maxtor Hard Drive
External n256 firewire connection does not identify
Inherited 3 maxtor externnal drives one is USB..plug and works but two qre firewire connection and do not identify when i plug in
  • 63 Answers
I would think you need to enable your firewire in the BIOS
Posted on Nov 21, 2008
The computer suddenly won't read my maxtor ex. hard drive anymore. What should I do?
If u are connecting it on the front usb
Try to connect at the rear usb. If it doesnot work then you have to check in device manager wheather the usb is disabled or not. If it is ok here then go to registry bu typing regedit in run window.
Go to HKLM---System-----Services-----usbstor
in that start value should be 3.
If it is 4 then change it to 3.
Dec 22, 2010 | Maxtor OneTouch II external hard drive...
I installed from original CD and my computer running Vista does not find maxtor ll external HD. Is it compatable with Vista? why does it not find the drive?
Start "Device Manager".
Make sure that the USB devices are "ready" and "enabled".
Then, connect the external USB device.
Can you try the Maxtor external device in some *OTHER* notebook?
If it does not work, then the Maxtor device has a problem.
Nov 08, 2009 | Maxtor OneTouch II external hard drive...
Mhy maxtor external hard drive is not being recognized by my computer. What do I need to do?
Does it work when connected to a different computer?
If not, is it still under warranty?
If not, disassemble the case, and you'll find an "internal" MAXTOR disk-drive inside the case; try connecting that drive as a "slave" disk-drive inside your computer. If it is not recognized, then it is "dead" and you should take a hammer to it, so that any of your personal data on it will become impossible for any "identity-thief" to read, and then buy a new, larger, external drive.
Sep 13, 2009 | Maxtor Hard Drive
Hi how are u i hope u will mbe fine but i am not fine because i have 2 maxtor n256 40gb hare drive one i ma all ready useing in my pc and other i want to use as a usb port able i get one contener to fix my...
This depends on your country, i.e whether you can easily get what I'm about to tell you to buy from any computer store.
There is an external drive case that is being sold at many computer stores now that can actually enable you to connect your harddrive to it, then it has an external USB cable that will make you to be able plug it in any available USB port on a system (I recommend USB port 2.0 for high speed rate). So you can just get that and trust me, you'll be fine...lol.
Hope this helps.
Jul 20, 2009 | Maxtor Hard Drive
My computer no longer recognizes my Maxtor One Touch III Firewire 400/USB 2.0
go to my computer proeprty then uninstall usb driver and then right clik any driver then clik on scan for hardware then it searches usb and install automatically.
May 22, 2009 | Maxtor One Touch III 500GB FireWire/USB2.0...
Connecting problem
Boot your system with external drive unconnected, then go to add new hardware. then plug in maxtor and follow guide, if this is not of any help then unplug and replug drive IE switch off replug and switch on your Maxtor. After a while when all the software gets together all will be harmonious and groovy.
Nov 28, 2008 | Maxtor OneTouch II external hard drive...
I recently purchased an external hard drive, and how do connect it to my computer.
External Hard Drive is mostly of the USB interfacing type. If urs one is the same, then it is just as simple as plugging in a pen drive in the USB port. If it has external power supplies then u can easily figure out how to connect. There are two parts in the power supply (if external power supply cable is provided), 3-pin main power supply connector and other is the adapter which goes to the external hard drive.plug in the other end of the adapter into the hard drive (there is a hole in it). connect the main power cable to the adapter extension. now for the usb Hard Drive, connect the USB cable to the USB port of the computer. Switch on the power supply to the Hard drive and u r ready to use ur brand new External Hard Drive. If it is a Firewire interfacing one then u may need to open the CPU box, and then connect the firewire connector on to the motherboard firewire port. It is easy to identify, it is a red colored port/connector.
Oct 11, 2008 | Western Digital 500GB My Book World...
RE: my external hardrive
Check cmos to see if usb ports are enabled? If Windos 2000 you need a usb driver disk.
Feb 28, 2008 | Maxtor OneTouch II external hard drive...
External Hard Drive
Couple of questions first: -What operating system was running on the new and old PC? -Is the old PC still running and available? Once you answer these we?ll start work.
Mar 04, 2007 | Maxtor OneTouch A01B080 80 GB Hard Drive
Maxtor Hard Drive Logo
77 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
