Question about HP Compaq Presario R4000 Notebook
Samsung np r40 pluss will not start up sometimes.the screen stays blankand the light for the hard drive stays off and there is no sound from hard drive
  • GTOM Jan 22, 2009
    sorry i never got back on.I got friend to check power lead,charger etc,found that the battery faulty this in turn blew the 3 amp fuse in plug . The salotion to change fuse and do not remove and install old battery.Got a new battery on ebay
  • John R Jarvis May 11, 2010
    Does anything else happen?
Won't start
http://www.samsung.com/us/search/espsearch.us?keyword=Np-nc110-a01us+
Dec 09, 2013 | Samsung Np-nc110-a01us Nc110-a01...
Samsung r40 reset to factory settings
hello there Start by pressing F4 when the BIOS "Samsung" screen is showing. This will allow you to restore the original operating system from the recovery partition, if is there. (Also try the other Fn keys - F6 and F8 may do something).
Otherwise you will need to beg, borrow or buy an XP Home installation CD and use that for a new installation. You can use the Samsung key on the bottom to activate it. You can get the R40 drivers from SamsungPC.
Feb 12, 2013 | Samsung NP-R40 NP-R45 NP-R65" (CL102791)
HOW DO I REMOVE CD-RW FROM SAMSUNG NP-R40
there is a screw & a button near the drive, first remove the screw, then push the button up (its like a lock), keeping push the level up while pulling out the drive.
Oct 28, 2009 | Computers & Internet
SAMSUNG R40PLUSS COULD NOT FIND THE FILE ''FLASH.OCX''
the system 32 folder in the windows directory is corrupt, if you can get your machine started, back up all of your data straight away before the system crashes "DO NOT TURN OFF THE COMPUTER UNTIL BACKUP IS COMPLETE" then you'll have to do a recovery either by disk or recovery partition, consult the laptops user manual for the recovery instructions
Nov 13, 2008 | Computers & Internet
Screen Keeps dimming and contrast function does not work
This is possibly, a loose cable or the screens inverter board is overheating. the inverter is similar to a booster in a flourescant light fitting. which converts power from DC To AC and boosts up the panels Light Tube. CFL if it,s faulty or overheating. this will cause the panel to dim.
also check the plunger at the underside of the screen, isn,t sticking down. designed to cut off the panel when the lid is closed. Finally some model laptops, only boost the brightness running on A/C Power. the battery would run-out fast with screen at full brightness. if theres an fn key on the keyboard, press fn and the brightness button to adjust screen brightness.
Mike @ Compurepair.
Jul 31, 2008 | Samsung V20 XVC 2400 Notebook
IBM R40 Problems AC adaptor plug needs to be adjusted (wiggled, coached on the female connector) minutely to have panel (green) lights illuminate. No battery, Windows gets on screen, password entered, then...
I recommend bringing this laptop into Best Buy for repair. This has several hardware related issues from what you've described. If the repair quote is any more then $200 (which i anticipate it will be) I would consider investing in a new laptop and not throw good money after bad.
Thanks
May 02, 2008 | IBM ThinkPad R40 2722 Notebook
Can't boot my Thinkpad R40
its ok pat sounds like mobo power ships not doing thers jobs nomore ok would have to buy new motherbord ok thx nick
Feb 06, 2008 | IBM ThinkPad R40 2722 Notebook
Computers & Internet Logo
198 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
