Question about Onkyo TX-SR605 Receiver
Lost DVD Audio in and Video
I have had a PS2 connected to the DVD in at the back of the reciever for months and always worked fine. Now I don't get any audio or video to play. I can move the conections to the front and it works fine again. Am I missing something EZ or do I have a hardware failure on my input ports? Thanks
    Problem Solver:
  • 16 Answers
If you didn't do anything with the programming of the receiver inputs, then I'm afraid you do have a problem with your hardware inputs in the back of your receiver.
Posted on Nov 15, 2008
No audio after recording from sat. Reciever
Double-check your input cables from the receiver to the LG 389. Do you have the sat. receiver AV out connected to the front AV In on the LG DRT389? Make sure that you haven't mixed up the L and R audio connections on either side. (I've done something similar with RCA cables myself.) Next, try a different set of cables.
If that doesn't work, there may be a problem with the audio jacks on either your receiver or the 389. To check, plug the AV cables from the Sat. Receiver directly into the TV. If you have sound and video, then the input jacks on the recorder may be damaged.
Try using another input. (It looks like some models have the SCART input; you may need to set the input source in the menu under AV2 Decoder.)
The fact that you have audio output on USB and DVD's means that cables/connections between the LG289 and the TV are fine.
I hope this helps. Please add a comment with the details of which AV port you are using on the LG389 for additional assistance.
Lost video signal to monitor (TV)
I had the same problem - Onkyo had me reset the unit by holding down VCR and pushing the power button. Make sure you record your settings before doing this - as the unit will be fully reset. This solved the video problem for me.
May 26, 2010 | Onkyo TX-NR905 Receiver
I can't get my PS2 to connect to my dual xdvd270
You can connect the PS2 Video out (composite video out) to any of the 2 monitors video connector and the audio at the audio connector, remember to select A/V ext (External Audio and video) both video and audio uses 3,5mm jacks, if it does not work you might need to try to draw out the jacks a little, the connectors are of poor quality so be carefull.
You also might want to check if the right system is selected PAL/NTSC, check the format from your PS2 and set the monitor to accept the same signal type, then it should work fine.
The only thing I am not sure how you do is to get the composite video out of the PS2 but study the manual or google and you will find it I guess, but my guess is that you allready have that part covered.
Jan 03, 2010 | Dual XDVD270 Car DVD Player
Connected denon avr 1800 reciever to new hd tv. i cant find my reciever manual. how do i set the reciever to play the tv sound?
If you connect your tv's audio output to the reciever's audio input in the (TVor video section) using audio cables only---red & black or red & white) then select TV or Video on the front of the reciever depending on which connection on the back that you use it should work fine!!
Nov 06, 2009 | Denon AVR-1800
I've lost all digital sound to my reciever.
Get into the cable box menu and look for audio settings, chances are your digital output from the cable box is off. If you still can't get audio, reply with your Cable Box Make & Model and I can help you further. Hope this helps
May 25, 2009 | Yamaha RX-V757 Receiver
Lost Audio via HDMI
Check the pins on HDMI cable at both ends. Check for bent or broken pins. If all are OK, re insert firmly. Retry
Apr 05, 2008 | Onkyo TX-SR605 Receiver
KLH R7000 Component Video Problems
I have lost my remote and instruction book where? do is it worth it replace
Mar 07, 2008 | KLH R7000 Receiver
DVD Audio Output Stops
Hey Kelby,
I've had a similar experience where a DVD movie would be playing and suddenly my Denon would just shut off, I later discovered that my rear speaker cables were not correctly installed in the back so the reciever recognized it as a short and would just shut down. Just make sure your rear speaker cables are correctly installed (right to right and left to left and with correct positive/negative placement) and see if it still does it. If it's still happening, then I wouldn't know what it is. Good luck.
Jan 23, 2008 | Denon AVR-1803 Receiver
I need a solution to my dvd video problem.
denon recievers are very finicky I know I have one. Call denon customer service they are always very helpful and never ask for a serial number or anything like that. I call them at least once a year b/c of a setting I have messed up.
Dec 12, 2007 | JVC XV-S500 DVD Player
Onkyo TX-SR605 Receiver Logo
Top Onkyo Audio Players & Recorders Experts
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
