Question about Kenmore 50522 / 50524 Side by Side Refrigerator
Water gushed out freezer door, possible solenoid problem?
Water was leaking out onto the floor, opened freezer door and water gushed out, we turned off water to fridge, then turned it back on-now no ice cubes are being made but we are able to get drinking water. Fridge is a Kenmore side-by-side, model 59652679201
The drain is clogged. The drain is usually located inside the freezer on the bottom shelf to the rear. Use a meat baster and a solution of 1 tsp. baking soda and 2 cups of hot water-not boiling to unclog the drain. You probably also have about 1/2 inch of ice build-up on the bottom shelf. This will have to be removed first.
Posted on Feb 15, 2009
Water leak onto floor
There should be a drain pan that is deposited into, however some will crack or be moved out of place causing this.
Apr 29, 2014 | GE Profile : PSCS5RGXSS Refrigerator
My refrigerator expelled water tonight. Whe I woke, this morning, I found the floor with water. Can you tell me what could be happening?
if the drain is blocked in the freezer water can leak out onto the floor if it's leaking out of the frezer door.open the door and check the bottom rack,if it's frozen in or ice is on the floor of the freezer then it's the drain.also if you have a water line going to the machine one of the water lines could have cracked.let me know what you find and we can go from there
Jan 08, 2011 | Maytag 25.6 Cu. Ft. Side-by-Side...
Water is slowly dripping onto the floor from the bottom of the freezer door. it is as if the door is full of water. any suggestions?
ARe the temperatures good inside the freezer? If they are not near 0° F, that is the cause of the water drip.
If it is nice and cold in freezer, check freezer floor, is there a sheet of ice? you have a clogged defrost drain, clear it or have it cleared for you.
Good temps no ice on freezer floor? possible water leak inside door from water dispenser
Aug 13, 2010 | GE GSH25JFR Side by Side Refrigerator
I have a Maytag MSD2556AE Side by Side Refrigerator/Freezer. I keep getting a puddle of ice in my freezer and water leaks out of the freezer onto the floor. All this happens in spite of the water line to...
Sounds like you have a frozen drain line. I would unplug the unit at let the drain line thaw. This would be the easiest way to rectify the issue. Leave both doors open for 24 hrs. Hope this helps _MJ_
Jul 28, 2010 | Maytag MSD2756G Side by Side Refrigerator
All of the water came gushing out onto the floor...all hoses attached and in good shape
Nine tine out of ten the fill valve housing is cracked, try filling washer with bucket if no leaks that will prove it, if leaks with bucket fill the problen is probably the water pump or hose's that go to it
May 15, 2010 | Frigidaire FWSB5700DS Top Load Washer
My Kenmore side by side unit leaks water onto the floor and the water dispenser has stopped working. When I hit the dispense switch I hear water squirting.
Probably the plastic tube that came from the solenoid is broken somewhere between the solenoid and the dispenser(usually under the refrigerator).
Sep 20, 2009 | Kenmore 18.3 cu. ft. Top Freezer...
Sub zero 550 (14 years old) has a small but steady leak onto floor from freezer compartment. Small amount of frost buildup on inside of door. Food is frozen and the door "appears" to seal we
Right hand side wall in the freezer - take a look- any frozen water or moisture? Need check a drain line, usually defrost heater inside the freezer wall getting bad and draining water just freezing inside of it.
May 10, 2009 | Sub-Zero Bottom Freezer Refrigerator
Water runs out of freezer door overnight ,at times
Have a look at this link:
http://forum.appliancepartspros.com/refrigerator-freezer-repair/7670-leaks-water-floor-front-freezer.html
or this one:
http://www.ehow.com/video_112132_fix-leaking-refrigerator.html
Apr 17, 2009 | Westinghouse Refrigerators
Water dispenser not working
2 possible problems.
#1 water valve for the water side is stuck in the closed position.  Only way to tell is to pull the bottom kick panel out and look for the water line disconnect.  Separate the line, close the door and try to draw water through the dispenser.  If the water comes out of the disconnected line, then the water valve is good.
#2  if water is coming out of disconnected line, then the problem is in the freezer door.  There is a heater that keeps the water line from freezing inside the freezer door.  It is not repairable!!  The freezer door has to be replaced.
Nov 21, 2007 | LG LRSPC2031 Side by Side Refrigerator
Kenmore 50522 / 50524 Side by Side Refrigerator Logo
199 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
acrman404a
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
