Question about Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White
Bake not working
After self cleaning bake does not work but tried broil is working. I am thinking that the bake element is not working.
my oven model # CFEF372CB2 i am looking for a reset switch and can'tfind anything on the back. I am thinking that maybe temp has gottenexceded. the broil element works because when u turn it on there is 2settings hi and low, so that has nothing to do with temp only voltage.the surface elements work and everything else is fine no error codescoming up. also i was wondering about and error codes i am not getting any, andwant to maybe generate a error code if possible for further help thxsagain
  • 3,037 Answers
Well, to ensure the element isn't bad, you can take an ohm meter to the contacts of it and measure the resistance. It should be around 20 ohms. If it is much greater or infinite, the element is bad. To get to the contacts you will need to unplug the oven, pull it away from the wall and remove the rear panel. Then disconnect the element wiring and touch the probes from the meter to the contacts on the element. Otherwise, usually, the temp sensor is bad if the broiler still works, this is a small pencil shaped rod on the inside top of the oven. You can test it the same way and it again should be around 20 ohms. You can order a new parts locally or from repairclinic.com. Let me know what you find.
Benjamin
Posted on Nov 04, 2010
Both Oven elements do never come on Together, Top Works When turn on Broil and Bottom when On Bake & Auto. Pls help.
that's normal. The top element is meant for broiling only while the bottom one is meant for baking.
Mar 11, 2015 | Whirlpool 30" Self-Cleaning Freestanding...
My top oven won't reach temperature. Convection and broil work, bake doesn't. Over a year ago I did a self clean...hasn't worked since. I really need it to work especially with Thanksgiving next week.
It does sound like the element may be bad. The control will cycle the bake and broil elements to even the heat in the oven. if the element is out the oven won't heat well.
Nov 22, 2014 | GE Profile JT952 Electric Double Oven
My oven will not heat up to temperature
It may be the bake element that has gone out. The self clean usually uses the broil element to heat the oven. And most oven will either put 120 volts to the broil element while baking or pulse the broil element while baking. This will cause the oven to get warm but not hot. Check the oven bake element it cound be bad or a wire may have burned off.
Feb 14, 2014 | Ovens
The bake element (in over) will no longer get hot, should the element itself be replace or could it be something else? Range model RS675PXEQ0
It does sound like the bake element is probably the problem. Many ovens turn on the broil element with 120 volts to even out the heat in the oven or pulse the broil element. This may be why the oven is warm but not baking.
Nov 12, 2013 | Whirlpool 30" Self-Cleaning Freestanding...
Why has both top elements stop working at the same time
Hello kimberlymaso - If you are referring to the bake element, but the broil element works then you would need to just replace the bake element. If both your bake and broil element does not work, then there might be a problem with the wiring communication. However, if the oven does not bake and/or broil but the cook top works; contact a professional to diagnose the EOC (electronic oven control).
Sep 25, 2012 | Frigidaire 30 in. Electric Gallery Series...
Frigidaire Gallery oven large element stopped working
Hello -
If you are referring to the bake element, but the broil element works then you would need to just replace the bake element. If both your bake and broil element does not work, then there might be a problem with the wiring communication. However, if the oven does not bake and/or broil but the cook top works, contact a professional to have the EOC (electronic oven control) diagnosed.
Sep 19, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
My bottom oven ( non-confection) will not go on-it will just sat 100 degrees but won't get warm or hot. Top seems to be working fine. This started after I tried to use the self cleaning feature.
If broil and bake do not work on your bottom oven, it is probably your lower thermistor or control board. If the bake works but broil doesn't or broil works and bake doesn't, it is very likely your heating element. With an ohmmeter, the heating elements should be about 40 ohms. Much higher or lower signals a problem. If you suspect the control board is the problem, they can be repaired quickly and reliably at www.fixyourboard.com
Oct 11, 2010 | GE Profile JTP56 Electric Double Oven
I ran the self-clean mode this morning. After it finished this process, I preheated the oven to do some baking, and now the oven won't heat at all.
I am going to assume that you selected bake as you normally would and there are no faults (error code) reported. - this would mean there would not be a problem with the controller or the temperature sensor. The problem may be with only the bake circuit - so try the broil function - If the broil works then you may have a problem with the bake element or the connections to it or the relay on the controller - check the connections first then the element - If the broil does not work also then you may have a problem with the relay on the controller or the connection of the other leg of the 220v supply.
Make a check or have someone check it and wrte me back a post here
Regards
Oct 04, 2008 | Whirlpool RBS275PD Electric Single Oven
Self-clean not cleaning
I was wrong (I think).  the baking element probably was burnt out as the repairman said.  He replaced it and I thought selfclean still wasn't working.  In fact, I think I just had to give the self-clean function more time.  Also, I was judging by smell.  We have become used to a bad odor during self clean which was missing when it was broken and still missing after the repair.  Bottom line, the oven was clean after the baking element was replaced, sans smell.
Apr 19, 2008 | GE Profile JTP18 Electric Single Oven
Whirlpool oven issue
Usually, when an oven won't bake, it's because the bake element is burned out. The bake element is the black, pencil- thick tube at the bottom of the oven. When the oven heats, the element glows red. This element has an expected life-span of several years. It may last for only one; it may last for many more. When the element burns out, you need to replace it.
Oct 26, 2007 | Whirlpool RBS305PDS Electric Single Oven
Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White Logo
169 people viewed this question
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
ashburton
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
