SOURCE: Blurry picture
You probably have a focus problem. Possibly the focus control has opened. If so, then you would have to have the Flyback (High Voltage transformer) replaced. The control is integrated into the flyback. Depending on the labor chages and parts prices would determine if you want make that kind of investment. Other problem can also cause this effect such as a bad picture tube, open resistor,bad picture tube socket, etc.
SOURCE: focus
The writing is more blurry than the picture. it is not that serious while shifting 1 focus wire might be loose. 2 crt base loose. 3 dust like thing near focus wire. 4 adjust focus control fitted on eht. caution it is high voltage portion do not touch unless you know about it.call tech to do it. good luck.
SOURCE: i have sound and picture, but picture is blurry
your crt socket problem change it but make sure it is same type it must be ok really
SOURCE: tv has power no picture or sound
this is a proper electronic part failure this will require to be fixed by a proper tv technician as no body can guess ..call a qualified professional and get it repaired .ram mistry EMAIL [email protected]
