Question about Tao XM2go Satellite Radio Receiver
Need repair service
I dropped my Tao XM2go and the on/off button is jammed. I can work with it and make it come on and show the show in progress on the display, but it will not change channels and none of the other buttons work.
Can you refer me to a repair service? Thanks.
Bob Carroll
stoodleysnow
SOURCE: Tao XM2go shuts off for no reason
You could try taking the batteries out and cleaning the contacts, replacing the batteries and/or using sellotape to hold the batteries in place. They could be loose and disconnect when you move it in a certain way. If not the batteries, you could try further dismantling and cleaning, but you may just end up with a clean ball of sellotape that still has problems...! worth a try. stoodleysnow
Posted on Aug 30, 2006
johnychel
  • 796 Answers
SOURCE: XM2Go Tao Display Problem
have you tried resetting it??
Posted on Mar 05, 2008
  • 3 Answers
SOURCE: my tao xm2go will not turn on
Dear Glen,
My Tao solution is to buy the Delphi MyFi which appears to have an identical interface. See page 10 here: http://file.xm411.com/manuals/MyFiUserGuide411.pdf . This is expensive but service in not available.
digitally,
(/\/\<erwin
Posted on Nov 21, 2008
  • 3 Answers
SOURCE: atenna connection when using Altec Speaker or Car Kit
Dear xm2go,
I could not find any service options for my own Tao XM2go unit. The only option appears to be the Delphi MyFi unit which appears to be identical (see page 10 here: http://file.xm411.com/manuals/MyFiUserGuide411.pdf )
digitally,
(/\/\<erwin
alicantecoli
  • 22265 Answers
SOURCE: Can no longer transmit on Tao XM2go to unused FM
these things are controlled by a crystal diode and this is faulty ,its lost its value ,take it to a repairman who can renew the frequency diode for you its not a expensive job as its not a difficult job to do .
Posted on Dec 02, 2010
No sound comes out of radio?
Turn up the volume by pressing the top of the center cluster of buttons. Does it work in the home dock or car dock without headphones?
Nov 23, 2012 | Tao XM2go Satellite Radio Receiver
My tao xm2go unit is transmitting a very weak fm signal to my car radio. I can barely hear the audio.
You likely need to directly connect. In most cases the FM transmitter is too week to broadcast through FM stations, and a direct connection will clear up your issue. It could be as simple as connecting via an Auxiliary cable or Cassette Adapter. If you don't have the ability to use one of those, you can get an Auxiliary Input Adapter. Another solution would be an external FM Transmitter, with a larger range.
Jun 26, 2012 | Tao XM2go Satellite Radio Receiver
My Tao xm2go quit working. I've tried re-setting it. I've replaced the battery, I double checked that the charger is putting out the correct voltage with a multi-meter. it won't turn on, either with the...
Try plugging the power adapter directly into the bottom of the radio without using either base/cradle - wait a minute - then see if you get a battery indication.
Jan 18, 2010 | Tao XM2go Satellite Radio Receiver
My tao xm2go will not turn on
Dear Glen,
digitally,
(/\/\<erwin
Nov 21, 2008 | Tao XM2go Satellite Radio Receiver
Atenna connection when using Altec Speaker or Car Kit
Dear xm2go,
digitally,
(/\/\<erwin
Oct 07, 2008 | Tao XM2go Satellite Radio Receiver
Antenna Connection Problem
I have the same exact problem. I took a small needle nose pliers and pressed the antenna connection on the TAO radio. I put it back into the cradle of my Altec Lansing amplified speakers. It works again. For how long we will see.
Sep 05, 2008 | Tao XM2go Satellite Radio Receiver
Tao won't start
Dear Jim,
My own Tao unit is dying as well. Servicing does not appear to be available. The only solution I have found is to buy the Delphi MyFi unit which appears to use an identical interface (see page 10: http://file.xm411.com/manuals/MyFiUserGuide411.pdf ). What a bummer!
Digitally,
(/\/\<erwin
Jul 29, 2008 | Tao XM2go Satellite Radio Receiver
Display of recorded programs does not match the program playing
There is a very small reset button under the back cover. You will need a small paper clip to reach the button. It is located in the upper left hand corner. The button is not under the batt., it is about 2" above the screw on the side. I don't know if this will solve your problem, but it should reset your radio to its default settings. Good Luck!
Apr 29, 2007 | Tao XM2go Satellite Radio Receiver
Aug 30, 2006 | Tao XM2go Satellite Radio Receiver
Tao XM2go Satellite Radio Receiver Logo
53 people viewed this question
Top Tao Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Tao Audio Player and Recorder Expert? Answer questions, earn points and help others
