Question about Compaq Presario SR1000T (568657) PC Desktop
How do i open up my compyuter?
There is somthing rong with my compaq presario sr100 one of the cpu fans dosent work so i have been advized to open it and clean it but im not sure how?
  • Compaq Master
  • 4,806 Answers
Look at the back of the machine, there should be 2 screws top and bottom on the right hand side, unscrew them and the side panel should slide off revealing the computers inards
Posted on Nov 13, 2008
Compaq Presario SR5402FH pc powers down, cpu fan failing
- Clean the CPU Fan with blower.
If while performing any step cpu goes to 100% then it seems problem can be due to hidden background running services, so i would suggest you to disable them with the help of Reginout, download it.
Nov 25, 2013 | HEWLETT-PACKARD Compaq Presario SR5402FH...
Won't start but CPU fan vibrates but will not go full blast. Intermittant
It appears you have a faulty CPU fan and it is causing the CPU to overheat and shut down.
I suggest you replace the CPU fan. remove any dust from the heatsink and put new heatsink compound on the CPU/heatsink.
May 06, 2012 | Compaq Presario S5000NX PC Desktop
Compaq presario sr2150nx ata 100 motherboard fan plug
The CPU fan is being detected, but there is a problem with compatability or there is a fault in the fan it's self. Have you tried your original fan?
Mar 10, 2012 | HP Compaq Presario SR2150NX PC Desktop
The Cooling fan of my HP/Compaq Presario CQ60 sounds like a jet fighter! 2 questions 1) Replacement CPU cooling fan? 2) Can anybody give me pointers on how to get in to the laptop? I have tried blowing...
Presario CQ60 Repair Manual
From the above link from HP Official Support you can download the service/repair manual for instructions and photos for dis-assembly. Refer to "Fan/heat sink assembly" on page 4-41.
At page 4-7 onwards, you would find the instructions about opening the laptop.
INSTRUCTIONS & PHOTOS
Follow the instructions carefully and remove the Fan/ Heat Sink and Clean it using a tooth Brush.
Let me know if any further clarification/ assistance is required.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Jun 09, 2011 | HP Compaq Presario CQ60Z Notebook
I HAVE A COMPAQ PRESARIO SR1339UK, THE PLASTC
you can install an other cpu cooling.
You have to find out which socket the cpu got and the size .
it has to fits to your pc case.
Look for some videos on youtube .There are some good guidlines
for cooler installin.
A cpu cooler is not very expensive but most a time a lot better than the standart cooler.
Jun 02, 2010 | Compaq Presario Fan
Compaq Presario S5300NX (DM174A#ABA) PC Desktop: Compaq Presario Dekstop: CPU Fan error on bootup. ...
The fan has a third wire, that is used to tell the uProcessor that it is spinning and in some cases how fast.
Replace the fan and that should fix it. Spares form many suppliers on ebay
May 18, 2010 | HP Compaq Presario S5300NX (DM174A#ABA) PC...
Compaq presario cpu cooling fan will not start spinning unless "helped" with tip of pen to spin over.If I dont start it manually,I get No cpu fan message,and shut down.I just replaced fan,as old had broken...
If the CPU fan speed is too slow or not working at all, the computer will shut itself off automatically to prevent damage to CPU from overheating. You may end up having to throw more money at the problem and get a new fan. I went to Compaq's web site, looked up your particualr computer, found out what type of fan you needed, and I did some research. I recommend getting the fan in the following link. It's very cheap, and has good reviews. The other fans on the site all have bad reviews. Hope this helps.
http://www.newegg.com/Product/Product.aspx?Item=N82E16835114011
Jan 12, 2010 | Compaq Presario Cooling Fan CPU Heatsink &...
My compaq presario 4000 shuts itself off every so often. it sounds like the fans are cutting in then it shuts down
There are known viruses that will also shutdown a computer. You can rule-out a virus problem first perhaps with Mcafee's free online virus scan here: http://us.mcafee.com/root/campaign.asp?cid=45694
About the fans, you should definitely check them. If the main CPU's fan is clodded or otherwise failing, then temperature is likely skyrocketting until it shuts down. You could download a CPU temperature program as well. If you have the knowledge and this is a desktop, try opening the lid and taking a look at the fans
Jul 11, 2009 | Compaq Presario V4000 Notebook
Lines running along the screen which are permanent
may be the problem cause is heating...
may be cpu fan not working or there is heavy dust on fan..
try to clean cpu fan....
thanks
Mar 04, 2009 | Compaq Presario 2200 (292600-004) PC...
Compaq Presario SR1000T (568657) PC Desktop Logo
47 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
