Question about Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft. Front-Loading Washer
Need a part number
I need a part number for the Whirlpool Duet Sport model number wfw8300sw00 central control unit. I also need to know where I can purchase this. It seems the Whirlpool site is useless.
  • 370 Answers
The part number is W10160252. You can order the part at sears.com . The price is 131.10
Posted on Nov 21, 2008
Getingcodef71onwasherwasherwillnotstart
An F71 error indicates that the control panel (the buttons you press) is not communicating with the central control unit. Open the panel and check if there is continuity to the control panel wiring harness. Make sure that the wiring harness is fully connected to the user interface panel and the central control unit. Depending on if the drum rotates, you need to replace the user interface or the central control unit. (If the drum rotates, then it's probably the user interface. Otherwise it's the central control unit.)
Whirlpool has the parts diagram for the GHW9150P on their site in the Manuals and Literature section. The direct link to the parts list for the GHW9150PW0 is: https://www.whirlpool.com/digitalassets/MLPDF/Repair%20Part%20List%20-%208180440.pdf . For other models, enter the model number and click search on this page: https://www.whirlpool.com/webapp/wcs/stores/servlet/OCManualsLiteratureSearchView?catalogId=10561&langId=-1&storeId=10211&krypto=5QgxQhneFliXuEuX564wSQ%3D%3D&ddkey=http:OCManualsLiteratureSearchView . This site has the parts for the GHW9150PW0: http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5136839&diagram_id=28192106 . If you have a different model, start here: http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=ghw9150p .
I hope this helps.
Oct 10, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Sport Model WFW8300SW0 basket won't
The following list of codes indicates an electronics communication problem with the washer: - Duet HT washer - F01, F03, F06, F11, F23, F24, F27, F28, F29, F30, F31, F32, F35, F42, F61, F62, F63, F64, F65, F70, F71, and F99
If Pause/Cancel does not work:
  1. Unplug washer or disconnect power for one minute.
  2. Plug in washer or reconnect power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, call for service.
I would first replace the door latch/lock assembly, a number of users have and it fixed the F-11 error code completely. Its the cheapest part for this problem.
Hope helps.
Jun 27, 2011 | Whirlpool Duet Sport HT WFW8400TE Washer
My washer will not start it says" F-01" and constantly blinks when I try to press start. HELP!
Hi
Thanks for using FixYa. Error F01 in your whirlpool duet sport indicates EEPROM error which means that a communication error between the Central Control Unit (CCU)
and the EEPROM onboard the CCU occurred. This error also occurs when the pump driver fails to activate and/or one of the main relays is not working. To resolve this issue leave the unit unplugged for 5-10 minutes so that if this was caused due to power surge it is cleared. Also check the CCU (central control unit), if bad you’ll have to replace it.
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 23, 2010 | Whirlpool Duet Sport HT WFW8400TE Washer
Whirlpool Duet Sport Model WFW8300SW00 stops after spin cycle
F01 - There may be an internal problem with the control, attempt a Hard Reset.
Hard Reset - In some cases the control can be non-functioning or may not accept activation from the control panel. To clear and restart the control follow the these steps:
* Unplug or turn the circuit breaker off for 30 seconds.
* Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
* Press the Pause/Cancel/Stop button twice to clear the "PF" in the display.
* Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts.
The F01 generally indicates a failed electronic machine control board.
This error code can sometimes be caused by a glitch or power surge through the electrical lines.
You may be able to clear this code by unplugging the washer for 5 minutes.
If the code returns after plugging the washer back in, then the electronic machine control board will need to be replaced.
The procedure for accessing and replacing this control board is shown in this image...
http://media.fotki.com/1_p,wkwdftgtbkdgfrwxgtqsskgwtqkq,vi/ksrttqdqrxkssrqtgsd/1/1303472/5961857/image12917img-or.jpg
Be sure to unplug the washer before accessing internal components.
When you access the control board, I recommend transferring the wires from the old control board to the new replacement control board one connection at a time.
Once you have all of the wires transferred, remove the old control board and mount the new control board in the washer.
Reassemble and test the washer.
The "F01" error code indicates a communication error between the Central Control Unit (CCU) and the EEPROM onboard the CCU.
The "F01" can also be displayed if the onboard "Pump Driver" fails to activate.
Generally in order to correct this failure will require replacing the CCU.
There is no way to test and verify if the control board has failed.
The technical data sheet basically states to replace the CCU.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 27, 2010 | Whirlpool WFW8300S
I have a whirlpool duet front load mod#wfw8300sw00 washer and it makes a horrible sound when spinning almost a grinding sound is it done? or could it be something minor?
i have wfw8300sw00 whirlpool duet sport, i start de machine it's turn ons side (right to left) and abour 3 minutes it stop off no message.
Apr 29, 2010 | Whirlpool WFW8300SW
Whirlpool Duet Sport ~ E28 Error Code
serial communication error between central control and motor control.
Check connections at ccu (top front right corner) and mcu (bottom by motor), check belt drive for wear.
Did motor run ? Any other codes in diagnostic? (any one modifier button 4 sec on 4 secs off 5 times.) F codes are failures and C codes are portions of test cycle(automaticly run)
Apr 28, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Front loader mdl WFW8300SW00 will not start
I had a variety of error codes show up on my duet, and I'm not sure but I seem to recall a 31, but the most constant was 02. I took off the front cover, pulled the white plug out from the unit, put a bucket under it, unscrewed it and drained it. It may be the MCU is having problems because the washer got plugged up.
Apr 23, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Older whirlpool duet washer has error F11
F11 is a serial communication error between the central control unit and the motor control unit.
Unplug the machine and open the panels.
Unplug and re-plug all wire connectors from the ccu to the mcu.
Inspect all wires and harnesses for a bad wire.
Could be bad components; ccu or mcu or motor
Feb 23, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet sport washing machile leeks out of dtergent area!!
the water is leaking out from the dispensor area??? sounds as if perhaps something has gotten down there blockig the waterwway, try removing the soap dispensor entirely and lookin towards the rear for a possibel obstruction
Feb 15, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
F20 CODE Whirlpool Duet Sport Washer wfw8300sw00
Hi!
“F20” on display
(Water Inlet Problem—no water or insufficient
water supply) Select PAUSE/CANCEL twice to cancel the cycle
Unplug washer or disconnect power. Check the following: Are water faucets completely turned on?
Are screens at inlet hose connection to washer
clogged? Are water inlet hoses kinked? Are water inlet hoses frozen?
Do rate the solution.
Thanks
Rylee
Feb 08, 2009 | Whirlpool WFW8300SW
Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft. Front-Loading Washer Logo
181 people viewed this question
Dan Webster
Dan Webster
Sal De
