Question about Sony Playstation 3 (PS3) Console
Ps3 not reading game or blu-ray discs
It has the disc icon on top right, just stays like that
  • 2 more comments
  • Anonymous Nov 13, 2008
    Playstation 3 does not read any disks at all. It's a little more than 1 year old.
  • rjones456 Nov 14, 2008
    yes
    the ps3 is laying flat, with plenty or room for ventilation.
    we have left it off for a day and it still seems to not reconise there is a games or blu-ray disc in the unit, it just has has the small disc icon in the top right corner.
    the unit is about 7 months old
    regards
    ray
  • choper01 Nov 18, 2008
    yes i have same prob..can u help here
  • Anonymous Dec 11, 2008
    yeah i have the same prob too. just got my ps3 a coupe days ago and it won't read any disc i put in. Any solutions?
    Thanks all
    Scholar:
  • 91 Answers
The ps3s have a problem overheating they sell a cooler for them do you keep your running alot or on all the time or in a inclosed area like a entertainment stand or laying on its side ?????
Posted on Nov 13, 2008
  • steve albertson
    steve albertson Nov 18, 2008
    either buy a can of air and blow it through the vents on the sides and in the back also in the slot or return it if its 7 months old they come with a 1 yr manufactures warranty
Dosn't always read disc's, games dvd's. and now has stopped reading compeatly
The problem is that the lens/laser is weak and need to be replaced. Since it was reading disc and now it cannot read any disc anymore, that confirms the problem. To replace the laser/lens of the playstation 3. Please follow the steps below:
  1. Safely turn off the playstatiion 3,
  2. Disconnect it from the power outlet,
  3. Leave the unit to dissipate its high current in about 6 hours before starting to work on it,
  4. Open the top cover of the PS3.
  5. Pull out the power plug for the Blu-ray drive.
  6. Carefully pull up the Blu-ray drive and unclip the data cable ribbon from PS3 drive.
  7. Remove the two silver screws on top right and bottom right,
  8. Unscrew the 3 black screws to the left as well,
  9. Remove the top metal shielding of the Blu-ray drive, exposing the guts.
  10. Remove the top frame now that we are inside to reveal the laser (unscrew the screws)
  11. Once that is done you should be staring at the Blu-ray laser.
  12. Remove the Blu-ray lens screws,
  13. There are more screws to remove,
  14. There you go after removing all those screws the laser should easily come out, simply repeat the process for another working Blu-ray drive and extract its Blu-ray lens or just simply buy a replacement part (part #kem-400aaa) and insert it in the Blu-ray drive and start screwing it back on.
Hope this helped You. Thank You for using FixYa!!!
Jan 26, 2011 | Microsoft Xbox 360 Console
My PS3 won't read games or dvds, it doesn't even rev up when the disc is inserted. I've tried using one of the disc cleaners, but it didn't even read that. I'm not sure what is wrong with it...
I know what's wrong:
This is the 2nd most common problem with PS3's. This isn't a bad problem. Your
laser/lens will need to be replaced. Do you see the time clock in the top right
corner going around and around? If so, you are just having laser/lens problems. If
you do not see the time icon spinning when you insert a disc, your PS3's Blu Ray
drive controller board has gone bad and you will need to send it to Sony and not a
3rd party technician. Certain problems are only repairable by Sony. Good luck.
Jan 18, 2011 | Sony Playstation 3 (PS3) Console
Wont read game disc but will read dvds sometimes freezes up during game play
This is the 2nd most common problem with PS3's. This isn't a bad problem. Your laser/lens will need to be replaced. Do you see the time clock in the top right corner going around and around? If so, you are just having laser/lens problems. If you do not see the time icon spinning when you insert a disc, your PS3's Blu Ray drive controller board has gone bad and you will need to send it to Sony and not a
Jan 17, 2011 | Sony Playstation 3 (PS3) Console
I have disc read problems.
I do hear that the controller card on that revision of PS3 can have failure issues... right now I'm waiting on a new bluray drive assembly for a CECHE01 because of, basically, the very same problem. This eBay seller(lives on the other side of the US from me) seems to know a good bit about these issues, and even provides his phone number for tech support. Search under his store for: CECHE01
http://shop.ebay.com/arcphiltechrepairs/m.html?_nkw=&_armrs=1&_from=&_ipg=25
Nov 29, 2009 | Sony Playstation 3 (PS3) Console
My ps3 wont play blu ray movies or games but cds and dvds work fine
The Blu Ray Diode fried when you shut the power switch on in the back. The PS3 uses 2 different lasers to read disks. One for standard dvd's and cd's and one for Blu Ray. The only way to fix your PS3 is to replace the Blue Ray Diode or laser lens. I would recommend paying the $150 bucks to have sony replace unless you know something about Diodes and lasers.
If you hold down the eject button for 10 seconds it will reset your laser and then you should be able to shut the power down in back safetly.
Formatting and or resetting the hard drive won't do a thing if your diode is fried.
I found a work-around to get it to read discs though. You have to have a bluray disc in the drive (game or movie) and start a downloaded game or Playstation Home. Once the game or Home loads, hit the PS button on the controller. The crossbar menu will pull up and you will notice the disc icon will (magically) pop up. Click the quit game icon. Once you are out of the downloaded game or Home the disc icon will still be there. You can then load the game or disc. The icon will remain there until you eject the disc, so you will have to repeat this every time you want to load a game.
Check What Resolution You Have Saved On the PS3 Maybe When It goes Blu-Ray Its To High Res For The Standard TV..
if you felt i have spent my time to help you... a very helpful rating is appreciated for answering ur query...
regards iversh
Aug 18, 2009 | Sony Video Game Consoles & Games
Ps3 won't read disc
When Blue ray disk is placed into slot it seems like it is going to work and the screen on tv shows the entro for sony but nothing happens. Controls on controller will not function.
Apr 29, 2009 | Sony Playstation 3 (PS3) Console
Won't read any disc
You need a new laser. I have repaired several of these (about 20) with the same problem, wont read discs. The laser can be purchased for $50 online, try ebay.
Jul 14, 2008 | Sony Playstation 3 (PS3) Console
PS3 wont read discs
Me too dude, down right disturbing. We are all getting F-ed!!!!
have an 80 gig machine, downloaded the aptch, played 1 game of CoD and it froze. WTF!!!
Apr 20, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
27 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
