Question about Samsung HLP4663W 46" Rear Projection HDTV
Cooling fan is loud on initial start up and calms down after a couple hours use. Can I change out the fan and what is the part number on the HL-P4663W?
  • 1 more comment
  • Anonymous Nov 15, 2008
    I have a loud noise once I turn the set on. It started low and about 10 sec.-after turning the tv off. Now, the sound is loud as soon as the tv come on. Is this the fan or lamp?
    The part number for the fan is BP31-00010B
    The lamp is BP9600826A(P)
  • drordeal Feb 16, 2009
    Samsung HLP4663W cooling fan replacement info
  • raylinerRay Mar 30, 2009
    Is this part something that is easy to replace? I know my way around computer/electronics components. I had purchased a 4 year warranty, and, of course, I'm 4 years 2 months after purchase date now. Any service I need to do now I'm on the hook for. (Never had to replace bulb yet, either.)
Fan is BP31-00010B
LAmp BP9600826A(P)
Posted on Nov 15, 2008
Loud fan
Chances are you have dirt buildup, get a can of compressed air, attach straw and give the cooling fan a few good blasts, blow out open ports. If no change, the laptop must be dismantled down to the motherboard level to do a complete cleaning and the cooling fan may need to be changed, the old thermal paste will need to be removed and fresh applied. Go to www.ebay.com Type: make and model of laptop, refine search to cooling fan.
May 10, 2012 | Toshiba Satellite L555D-S7910 Notebook
My fridge is making a very loud noise coming from the rear and bottom of box.we have already shut it off for four hours it stopped making noise for a couple of weeks,but now started again,we shut it down...
THERE IS A FAN IN THE BACK OF THE FRIDGE , INSULATION GETS LOSE AND HITS THE FAN. REMOVE THE LOSE ISOLATION OR WHATEVER IS HITTING THE FAN.. I THINK THIS IS THE PROBLEM..JAY THE POOL PUMP MOTOR REPAIR GUY IN LONGWOOD FLORIDA
Jun 27, 2011 | LG Refrigerators
This tv internal curcuitries and manchanical design have a colors wheel in it.The tv have loud squiling noises,motor noises,black&white or colors flickers and fating.All the effect of the tv colors wheel is dying and spinning off of it motor axis.Cooling fan make noises for a couple hours,calm down,no way.The fan would have stop functioning,way before that.
Jul 21, 2010 | Samsung HLP4663W 46" Rear Projection HDTV
2004 pacifica radiator overheats every couple
A fan is on or off not slow do any fans in your house run slow because they are old?Your thermostat fan or temp sensor is bad
Jun 27, 2010 | 2004 Chrysler Pacifica
Cooling Fan Spinning Fast On A Cold Start
most fans are clutch fans and they work or are engaged by temp.most all will spin under really cold conditions.this is normal.but to be sure, with the motor off and key in your pocket grab the fan and see if it wiggles or has any slop. if not alls good
Dec 20, 2009 | 2007 Chevrolet Colorado (Extended Cab) New...
Condenser shuts down after a couple of hours.
check capacitors, make sure the condensor coil is clean. sounds like the compressor is overheating. is the condensor fan motor still turning when it stops cooling. if not check low voltage wires to condensor, furnace and t-stat
Aug 19, 2009 | Amana Haier AP125HD Air Conditioner
Whirring noise
this is for hls and hlt but i think this is what your set is doing
http://fixyourdlp.com/blog/?p=258
Dec 05, 2007 | Samsung HLR5067WX 50" Rear Projection HDTV
Odd loud fan type noise
what you are describing is the cooling fan. That fan will come on to keep the electronic control panel cool. It is normal for tat to come on even if your done with the oven. I dont think is should be as loud as you describe. I would try the oven again and if it is still loud I would call for service because it is new. That fan will also come on when you use the self clean cycle.
Jul 25, 2007 | Frigidaire PLEB30T9DC Electric Double Oven
Samsung HLP4663W 46" Rear Projection HDTV Logo
349 people viewed this question
Henry  Thomas
Henry Thomas
