Question about Zanussi Washing Machines
Pump needs replacing on Zanussi iz 16s jetwash. Anyone know which panels come off? Or where I can get a service manuel?
    President:
  • 1,462 Answers
Tilt machine back at a good angle and pump is accessible from underneath
Posted on Nov 14, 2008
How do you remove the lower front cabinet plinth on a Zanussi IZ 16 S washing machine?
Why? If I remember correctly behind the plinth do not have access to anything. If you need to replace the drain pump or filter housing you can access from the bottom or open housing of washing machine. This washing machine has a housing split into two halves and afterwards you will have access to almost all components of the washing machine.
If you need to replace just plinth, may help this spare part list.
Dado
Feb 19, 2017 | Zanussi Washing Machines
Is the alan screw that holds the pully for drum on zanussi iz 12 right hand or left hand tread?
Have a look at the beginning of the tread, and it will become obvious that it is left or right hand.
Jan 24, 2015 | Zanussi Washing Machines
Zanussi ZSF2450 has the pump running but the front panel has switched off - booklet says contact service centre anyone know what is wrong?
The flood switch has tripped, this is either due to water in the base of the dishwasher or a faulty flood switch.
Mar 04, 2012 | Zanussi Dishwashers
Where is the Recirculation Pump for IZ16S and how do i get to it?
You need to roll the washer onto its left hand side (to the left as you face the machine). Now have a look at the underside of the machine. The recirculation pump is on the top left as you look square on with the base. You will see the pipe lead off it which powers the jetwash nozle. Un-fasten the two 8mm bolts which hold on the pump assembly (this allows the pump some movement to gain access to one of the three screws holding the actual pump in place to the housing!). Un plug the two spade connectors then unscrew the three screws to release the pump from the housing. Be sure to fully drain the machine using the emergency drain hose before removing the pump. I'm not a washer repair man but have just taken mine off in preparation for fitting a new replacement.
Jun 14, 2010 | Zanussi Washing Machines
The belt has snapped. Does anyone know how to
If there is no removeable rear panel then it can be done from the top, it is not easy, but I have done it in the past.
If you tilt the washer towards you, it gives more room to get your hands and arms in to fit the belt.
Otherwise it means removing the rear half of the cabinet.
Hope this helps.
Jan 25, 2010 | Zanussi F1245W Front Load Washer
Zanussi IZ 12 pump access
You should not need to remove anything to check and clean pump filter.
Open the filter door at the bottom right front of washer, there you will see the pump filter cover, unscrew the filter anti-clockwise, and remove the filter, and clean same.
With the filter out, you will see the filter housing, which is fastened directly on to the pump, have a good look inside the housing, and see if anything is stuck in there.
Refit filter, and test.
Please rate my fixya solution.
Thanks.
Jan 31, 2009 | Zanussi IZ12 Front Load Washer
Drain pump FJ 1454W
Prob sorted, phoned Zanussi service enginneer
Nov 13, 2008 | Zanussi FJ1454W Front Load Washer
Zanussi zwf1631w jetwash front loading washing m/c
had to call an enginer out, the problem was down to a faulty motor rota, to identify if e30 is this fault, rotate the drum (so the motor rotates) and try to start the m/c. if it runs ok you know to change the rota. hope this may help someone
Sep 12, 2008 | Zanussi ZWF1440 Front Load Washer
Zanussi IZ 12
I've just spent an hour taking mine to bits. On the back there are 2 x 9mm silver nuts at the bottom, below the star head screws you removed to get the top off. Then there are two more sneaky ones at the bottom of each side panel, just next to the gap about half way along on both sides., with a plastic cover hiding them from view. Make sure you release the mains cable holder from the top of the back by pressing the plastic clips down, then the whole shebang should slide off easily.
Regards. Paul C
Dec 31, 2007 | Zanussi IZ12 Front Load Washer
Washing Machines Logo
146 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
