Question about Garden
PoulonPro Leaf Blower will not run properly
The leaf blower only surges. Rarely will it reach full power and run as it was designed. Spark Plug, air filter, gas filter all have either been replaced or cleaned. The model number is BVM200.
It will start, but the engine will only surge trying to catch and run at full speed.
  • fullard Nov 25, 2008
    Tried all the above and still the same problem exists.  It will start without a problem, but it won't reach full power. When you try to get it to maximum, it only surges.  Compression tests indicate 60lbs and holding.  What next?
  • 4 Answers
The carb has a screen in it it needs to be cleaned out the fuel gets crystalized in the carb when it sits for a while. and if the carb has a high and low on the carb meaning 2 screws on the side of the carb .one is for air and the other is for fuel try this first start it up and give it full throttle and turn the high adjustment till it does something screw it in slowley and or out till it is at full rpm sometimes the adjustment screws do vibrate there way out of adjustment .if it dont work then take the carb apart to clean out the screen
Posted on Nov 14, 2008
Shindaiwa leaf blower EB8520 loose power every 5 secondes for 5 secondes
Sounds like you are running it with the choke on - is it spitting black smoke?
Jan 12, 2013 | Garden
Gas blower engine surges and shuts off when engine gets hot
check your fuel lines for cracks, could be sucking air or could be your carb needs cleaning, make sure you clean the screen inside the carb, if you run it with the choke on partially does it smooth out and quit surging, if so it is definitely a fuel problem. Hope I helped you. 2StrokeJim
Nov 27, 2011 | Poulan 25CC Gas BlowerVac
Blower not running at high rpm when full throttle. Cleaned air filter, gas vent, gas filter and spark plug. Blower is 3 years old. Have not bought any new replacement parts.
Try removing the muffler and look inside of the exaust port, you should be able to see the piston in the full opening of the port. If you can, try starting and running at wide open throttle. If it runs fine( a bit loud, so wear hering protection), then you have a plugged or partialy blocked muffler or spark arestor. Sometimes rich mixture can cause excessive carbon build up.
Hope this was helpfull.
Nov 07, 2010 | RTO Echo 25.4 Cc Backpack Leaf Blower -...
The leaf blower won't start and I did change the spark plug and last time it run for like 30 sec. before it shut down again.
Main cause of small gasoline engine failure is carburetor clogged. Try spraying carburetor cleaner into carburetor and intake. Check if unit has air cleaner. If engine starts briefly with cleaner then carburetor needs manual cleaning. Carburetor removal and overhaul.
Jul 10, 2009 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Stilh leaf blower and it surges
How old is it?
Your brief description of the problem points toward air in the fuel lines.
Remove the engine cover, and try to see how flexible the fuel lines are. If they are hard and brittle, it's time to change them.
If you need further assistance let me know.
Apr 19, 2009 | Garden
Echo PB 2100 Leaf Blower will not speed up
Remove the muffler and clean the exhaust port, spark arrestor screen and muffler intake.
Apr 09, 2009 | Garden
Leaf blower problems
You may have a dirty fuel filter, or carb needs cleaned.
Mar 19, 2009 | Craftsman Garden
Poulan pro bvm200 leaf blower/vac won't run on high
Is the exhaust spark arresor screen clean? a blocked exhaust will do this.
Nov 29, 2008 | Garden
Garden Logo
687 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
