Question about Hoover U6616-900 WindTunnel Bagless Upright Vacuum
Self Propelled Feature Has Stopped Working
My 17 year old was using the vacuum and ran over his head phone cord, he yanked the cord out of the vacuum, and now the self propelled feature of this vacuum is not working, I have checked to make sure the belts are on, and they are. I did find a small broken black plastic piece in the vacuum, but I don't know where it came from, can't see anywhere that is might have fit. Would buying new belts help this, they are a few years old, or am I in for a huge repair bill. Thanks
  • Dildoe Apr 12, 2008
    Self-propelled feature does not seem to be working as good as it use to.
    Mike Dillon
    2178 Darlington Dr.
    The Villages FL 32162-7722
    (352) 430-2437
    (586) 242-1086 cell
    mikenjandillon@comcast.net
    President:
  • 1,673 Answers
Does the brush roll turn when it it is on the carpet? The flat belts should be changed often, they stretch and won't turn the brush roll. When you pull back on the handle, does it feel loose or does it feel like you are pulling a cable. It you tilt the handle back, then look down on the right, there is a cable, does it look ok and attached to a nlack plastic part, if not then the actuator is broken. Do the 2 knobs on the nozzle slide back and forth, if not, then the slide may be broken. You may have to take off the top cover and inspect it.
Posted on Jan 19, 2008
I have the Hoover, self propelled vacuum. I have only used the self propel function a few times, but our babysitter used the feature and now the vacuum only works on the highest carpet setting. The middle...
Move the carpet height control switch to a higher position if the vacuum is difficult to push. If the setting is too low for the carpet being cleaned, the brushes press against the floor preventing the vacuum from moving easily.Set to a medium-high height setting then check.Slide the "Self-Propel" button to the "ON" position if the cleaner does not self-propel. -----------
The self-propel feature operates only when the cleaner switch and the self propel button are both ON. ---------- Try this settings and check.This should help.Thanks.Helpmech.
Jun 24, 2011 | Hoover Self-Propelled WindTunnel Bagless...
Just replaced the belts on my Hoover Windtunnel II self-propelled vacuum. The brushes are now turning ok, but the self propelled feature is not working. Squeals when when you lock it in the upright...
Check the plastic part, which the the self propelled cable is attached to. (release the handle, tilt it back. You should be able to see the cable attached by a screw to a black plastic arm.) It is either broken or the cable is lose.
Nov 14, 2010 | Hoover U6630-900 WindTunnel Bagless...
Self propelled feature does not work. I replaced
There is a cable from the handle down to the transmission on this machine that breaks all the time or the cable is mounted to a plastic piece that is broken. That will need to be replaced.
Nov 28, 2009 | Hoover U6476-910 WindTunnel Upright Vacuum...
I have a self propelled Power Supreme vacuum. It
Most common cause is fibre / hair in the roller and brushes. remove base cover and remove fibres . Remove screws and use small scissors to cut along roller / brush then pull gently.
Sep 20, 2009 | Vacuums
I have a Hoover WindTunnel, Self-propelled model, and it was working great until I ran over a portion of the cord, then it started making a bad noise and I noticed the roller is not moving consistently...I...
The V belt usually wears down first. Remove the roller and belt to visually check for wear and belt material in the roller pulley. I would change the flat belt as well. Also, replace the cord if any wires are exposed
Mar 08, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
I own a self-propelled Hoover Wind Tunnel vacuum cleaner (Model U6425-920). I do now have an owner's manual and was wondering how to clean the Hepa filter on this model (*this model uses a vacuum cleaner...
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=794479
Generic problem for all Vacuums
Posted by gohornsgo on July 17, 2008
I own a self-propelled Hoover Wind Tunnel vacuum cleaner (Model U6425-920). I do now have an owner's manual and was wondering how to clean the HEPA filter on this model (*this model uses a vacuum cleaner bag also).
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. The best way to clean the HEPA filter is to take it outside and use a blower over the trash can and blow off the dust and dirt, or use things like an old paint brush and brush it off, or you can vacuum it off with another canister vacuum or shop vac if you have an extra one. For the best filtration is to replace it, there fore the air flow will catch most of the dust and dirt and then you would have to watch how fast it gets dirty and then do the maintenance.
So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 17, 2008 | Vacuums
Hoover only two years old an stopped working!
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=40540&thid=564949
Hoover only two years old and it stopped working!
Posted by baby_nurse on May 02, 2008
My Hoover self propelled wind tunnel was working great until a couple of days ago when it started shutting on and off while vacuuming. I thought it was the outlet but when I plugged it into two different outlets it did the same thing. Then finally yesterday it just stopped working it won't even turn on when plugged in. I thought it was the switch but it is not. Is it the motor? Has the motor burned out? Do I need to buy a new one? Help!!
Hoover U6616-900 Windtunnel Bagless Upright
I think you are right, if it is not the switch then it would be the motor. Does it smell bad like a burning smell? If so it is definitely the motor and then @ that point you may want to get an estimate for motor replacement, and keep in mind of what you spent on the vacuum versus what the cost of repair might be. My own rule of thumb is if it cost more than ½ of the price I paid for it then you have to decide – do I want to pay the repaired cost for the vacuum or do I want to purchase a new one. Just a suggestion... You may want to check with your local vac dealer. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
8 a.m. - 7 p.m. EST
Don – The Vac Man
Go Ahead. Use Us.
May 02, 2008 | Hoover U6616-900 WindTunnel Bagless...
Hoover U6616-900 WindTunnel Bagless Upright Vacuum Logo
100 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
