Question about Samsung Digimax S800 Digital Camera
Camera turns on, but screen black-only when card is inserted
Screen is on when memory card is not in--but as soon as you insert the card--all is black and nothing works. What happened??
    Scholar:
  • 85 Answers
Ok
May be ur Memory card or Memory card Slot are currept..
Try to use another memory card and check that ur camera turn on or not...
note- battery will have to fully charged.
It may possible that ur camera's memory card slot is dameged...
if another card also has the same prob..contact to service centre...
Posted on Nov 13, 2008
    President:
  • 624 Answers
This could be a problem with the memory card. Try another memory card and see if it help. You should also turn the camera off before taking out a card and putting one in.
It displays an hourglass with a black screen when you turn it on
  • turn off remove and re insert the batteries first
  • remove the memory card
  • turn on the unit . if the hour glass does not appear try inserting a different memory card .
  • if this works your camera may have trouble reading the old card
Aug 23, 2014 | Nikon D5100 Digital Camera with 1855mm...
Screen blacks when i insert my memory card
Only insert and remove memory cards when the camera is shut down. Before you go on with this memory card, check in a PC with a cardreader if the memory card is ok. Onlty when you are sure it is working good, go on. Perhaps you have another memory card to test in your camera. Please switch it of and check if the battery (ies) having enough capacity.
Oct 31, 2013 | Canon PowerShot A495 Digital Camera
Cannon s5is powershot as soon as i turn camera on a memory card error comes up and theres no card in it, does same thing when card inserted. it's got to be something in the camera slot, is there a lock in...
On the SD card there is a little switch you can move. It has 2 positions, LOCKED, and UNLOCKED. To make the card available, put the switch in the UNLOCKED position.
Here is an example-
If that doesn't work, try putting the card into a memory card reader, like on your PC or a special USB attachment. If the memory card is recognized, then it might be a problem with your camera.
Mar 01, 2011 | Canon PowerShot S5 IS Digital Camera
Every time i take a picture on my camera it says memory full insert a Sd memory card to transfer and take more photos i havent took any pictures and i inserted a SD memory card
Try this...go into the menu and scroll to "reset"...follow the on-screen instructions. Then, without a card in the camera, go into the menu and scroll to "format"...follow the on-screen instructions. Then if the pics on your memory card are safely on your computer (use a card reader to do this if necessary) insert the card into the camera, go into the menu and scroll to "format" and follow the on-screen instructions. After all this, you should be ok.
Nov 22, 2009 | Vivitar ViviCam 8025 Digital Camera
Blank screen
Try this...if you can still get into the setup menu, scroll to "reset" and follow the on-screen instructions. If not, remove the memory card and battery...press all the buttons...leave the camera alone for 20 minutes...insert the card and then the battery...turn it on. Did that help?
Sep 28, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
N 73 screen
remove the memory card and try it work's properly. after u just insert the memory card i likely to be working.. better u need to format the memory card..
Sep 06, 2008 | Nokia 6230i Cellular Phone
Camera wont work when memory card is inserted
I suggest you try to use a different memory card. If it doesn't happen again then it's probably a bad memory card.
Mar 06, 2007 | HP Photosmart M417 Digital Camera
"Memory card is locked"
This error message means that the memory card is write-protected. To take a picture, turn off the camera. Then insert a new card or change the storage location to internal memory
Aug 29, 2005 | Kodak EasyShare CX7530 Digital Camera
"Memory card is unusable"
This error message means that the memory card is slow, corrupted, or unreadable. Turn off the camera then insert a new memory card.
Aug 29, 2005 | Kodak EasyShare C360 Digital Camera
This error message means that the memory card is write-protected. To take a picture, turn off the camera. Then insert a new card or change the storage location to internal memory.
Samsung Digimax S800 Digital Camera Logo
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
