Question about Famous Trails Calypso FT700 Monocular
Lights come on but nothing shows its black.lens looks good
Older model night owl monocular,it has been stored for awhile..new batteries lights work but nothing shows except black..lens looks good not grey but has a blue tint..what could have happened while in storage..been in a case.. worked fine when put in storage.
  • 4 more comments
  • Henruchito Nov 22, 2008
    Night vision was working properly when stored for just few days and when taked out of case, simply doesn't work. No hits, no humidity, new batteries, and view is black.
    Everything looks good, and indicator lights turn on.
  • Anonymous Nov 26, 2008
    I bought new Night Vision Monocular NVMT . It never worked. It looks darker inside than outside. I changed two batteries( new) to exclude battery failure.To make things worse I lost original bill of sale. I have proof of purchase on credit card statement.The producer is Yukon Advanced optics.I wonder if there is shop in Arizona that can repair it. I can use some advice .
  • Anonymous Dec 03, 2008
    Same identical problem. Stored, put new batteries in, lights go on and black lens. Used only a few times and is still brand new. Any clues? Your input would be greatly appreciated and thanks in advance. Bob
  • replusted Dec 14, 2008
    Brand new unit worked for a day then was put away without the battery in it. It was stored in a dry temperature controlled home for 6 months. When put back into use the unit did not work. I replaced the battery but still no luck. I can't believe that other people are having the exact same problem. It sounds like a manufacturing defect of some sort.
  • wadingriver
    wadingriver Feb 23, 2009
    Same but different My NOCX3 did this. brand new, I played with it for 10 minutes tops. Took the battery out, stored indoors. 3 months later I put battery in and turn on. BRIGHT green light in center dimmer light as it should be around edges but not fseeing anything through the it.
    Returned it for a NOCX5 and same exact scenario. tinkered with it for a few minutes, pulled tha battery and put away for years. put in battery. BAM, same issue. AND no response at all from www.nightowloptics.com
    These aren't that cheap, what's teh deal?
  • jpdg Mar 02, 2009
    i have this yukon spirit stock for a day... then when i use it, it doesnt work.it has power indicator turns on new batteries.
Posted on Apr 01, 2009
    Problem Solver:
  • 15 Answers
I have seen a few of this model and the tubes were gone in each case. Best way is to check if HV present at tube - get someone who knows what they are doing to take a look. If it is the tube, it will be expensive to repair. Unscrewing the lens may reveal that the inner surface of the tube has dark marks, also indicating possible tube damage.
Posted on Nov 29, 2008
How and where do i remove the battery
Note where he points to place the battery at 3:49 minute mark
Night Owl Optics Night Vision
requires (1) 3-volt Type-123 lithium battery (not Included)
Apr 15, 2016 | Night Owl Optics Night Owl NONEXGEN-W...
Night owl monocular had broken photo facade lens set, is it replaceable
Hello, to answer both your question on fixya. Yes Since you Nigh Owl Monocular NOCX3 is five or more years old. You can check with Night Owl Optics in El Paso, Texas. I am sure that I have the replace lens or the whole 1,5 50mm front lens. Contact at drawbridge21@q.com. It will be free and the only cost will be shipping. Richard
Sep 14, 2011 | Night Owl Optics Explorer NOCX3 Monocular
I have acquired a night owl monocular nightscope. the only number I could find was in the battery compartment # H3T-3M. there was a serial # 9846786. The problem appears to be the switch. the powerligt...
Yes, If you turned the Night Owl on during the daylight hours, or looking directly into bright lights.
If you have done this more than few time it could have damaged the image intensifier tube. If this happen to many times, it's finny, kaput, so long, it gone south, and gone bye-bye.
Looking at bright lights is damaging to NV devise. The intensity plate in the image tube, magify the existing light about 3000 to 8000 (radian light from the stars, moon and other light sources).
You have 80mm front lens on the Night Owl NOCP5. This mean that more light can inter into image tube.
Sir, have you been looking at bright lights, operate NV system during the day, have you? If not, there could be something else worng with you Night Owl. stewbison
Mar 07, 2011 | Night Owl Optics Cyclops Pro NOCP5...
My Night Owl Cyclops NOCC3 night vision monocular wont pick up the infra red light properly so I can't view anything at night!!!! I haven't the lens cap off in light only when it's dark out and it won't...
Hello, is the IR glowing red, don't look into the IR lens. Just place your hand in front of it and see the is a red glare on your had. If there is a red glare then IR is work.
Another thing when you taking a look see through the Night owl NV monocular there should be a green glow from the image intensifier tube, if not, then the NV monucular isn't working properly. stewbison
Feb 21, 2011 | Night Owl Optics Cyclops Compact NOCC3...
I don't know how to work this, we received a Night Owl Explorer Nocx3 for Christmas several years ago. The instructions got lost and it as set in a draw ever since. I have stored the battery out of the...
Hello Here Night Owl Optics owner manual web site for your monocular: http://www.nightowloptics.com/documents/NexGenMonoMULTImanual.pdf
One more thing. DO NOT LOOK THROUGH NV MONOCULAR DURING THE DAY, OR LOOK AT BRIGHT LIGHTS. This will destroy the image intensifier tube. Bright lights will make it go south faster than Speedy Roadrunner. I need parts if the image tube is gone. Night Owl Optics in El Paso, TX will charge you about $200 plus parts and shipping to repair it. So, listen no looky at bright lights in the neighbor bedroom window, hey. GB...stewbison
Jan 24, 2011 | Night Owl Optics Explorer NOCX3 Monocular
I put in a brand new battery in my night owl optics night vision monocular and the red light comes on but i can not see anything out of it.
Hello, this Night Owl monocular will have two light (LED's), one green for on/off, and other red LED for IR illuminator. So, does the green light come on? Also, if still does work, then send it to me. I some parts to fix other NV devise and 95% of them are manufactured in Russia including yours.
I wish you all the luck. GB...stewbison
Dec 20, 2010 | Night Owl Optics Explorer NOCX3 Monocular
Night owl nocc3 looks like a star field inside
it sounds like the light "pickup" at the front is not working,, was it stored with the front lens cap fitted and in the dark? if not you may have bamaged this "pickup" it could also just be dirt on it,,you can undo the front lens and clean the "pickup" if the unit is turned off and you use a soft lint free cloth
Jul 31, 2010 | Night Owl Optics Cyclops Compact NOCC3...
Pitch black
Unscrew front lens front of intensifier tube should have an even bronze tinted coating on glass if it is grey and blotchy the tube is degassed. common fault with this model nightvision
wayne
Feb 26, 2008 | Optics
Nothing but Pitch black
I Have two Mk 6500 they are both pitch black inside. YES i put new battery in same thing. Is there a way I can fix this my self, they want $800.00 to fix one at ATN... these are not junk scopes..
Feb 26, 2008 | ATN Aries 390 Paladin Weapon Sight
Famous Trails Calypso FT700 Monocular Logo
619 people viewed this question
Top Famous Trails Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Mark Campeau
Level 1 Expert
Are you a Famous Trails Optic Expert? Answer questions, earn points and help others
