Question about Video Game Consoles & Games
Running any microsoft flight simulator 2002,2994 fsx.and using Saitek X52 controllers I get cursor drift across the screen right to left. Without the X52 this does not happen. Will my download of new driver solve the problem. 2 giga ram, dual core processor, GeForce 7600 GT card.With win XP .
The driver download should solve this problem.
if not it could be campatability problem for your software and you should read up on that,,,:)
If all else fails maybe your hardware is no good and return it.
Posted on Mar 14, 2009
Bought the saitek headset how do configure to talk to the tower in the fsx game
You cannot talk to the tower in FSX, only via third part software and then the button you wish to use would be configured within that software (such as Live ATC),
May 15, 2010 | Saitek Pro Flight Yoke System Flight...
I'm in Belgium fan of fsx with window 7 64bits with saitek x52 pilot 6.0.4.1(HID-USB) All the bitton are working except one : the twit (rudder). It makes a mouvement (kind of vibrations) around the the...
You should set this axis up first as a rudder in FSX settings, then calibrate it. Make sure you hav the latest drivers for it too. Make sure that Auto-rudder check box is unticked. I hope this helps, good luck
May 08, 2010 | Saitek X52 Flight Control System
Fsx gold crashes to desktop when menus used during flight...But the problem does not occur when I use dx10 preview....but most of my many addon aircraft liveries are not supported in dx10 my pc is as...
This is almost certainly a graphics card driver issue. Check you have the latest one. If you have the latest driver installed, try going back one as this can help.
Apr 15, 2010 | Microsoft Flight Simulator X for Windows
I have Microsoft Flight Simulator X and a Satek X52 flight control, however I have problems with the throttle on all aircraft. I have to use the F-4 key - can you help?
You need to assign the throttle function correctly WITHIN FSX settings area itself. Also calibrate the joystick in windows first. If you are not familiar with assigning FSX functions to your joystick, check the Learning Center section within FSX for step-by-step details.
Feb 24, 2010 | Microsoft Flight Simulator X for Windows
Using fs9 with Saitek yoke - aileron control drifts to the right. Had the yoke for several years - it didn't use to do this. Reinstalled fs9 after a year of none use and now have this drift trouble.
The Saitek joystick yoke used to work perfectly. It was only recently that I experienced the aileron drift!
I un-installed and deleted averything related to FS9 and then started to load FS9 and all the add ons etc. The yoke works perfectly again. I have no idea......!
Dec 26, 2009 | Saitek Pro Flight Yoke System Flight...
The x-axis on my x52 flight control system doesn't work
try runing the install new hardware wizard then try and redownload all your drivers.
Jul 31, 2009 | Saitek X52 Flight Control System
Saitek X52 Flight Control Problem
Make sure you have the latest drivers for your operating system and graphics card, including direct X. Good luck
Feb 02, 2009 | Saitek X52 Flight Control System
Remove the X52 and drivers from your system. You have to install them in a certain order, so look in the documentation for the correct way to install and you will be okay. Good luck
Feb 02, 2009 | Saitek Pro Flight Yoke System Flight...
MS FSX -view keeps switching from cockpit to spot view
The most likely problem here is that you have multiple assignments for the view change command set to multiple controllers hooked up to the system. They are conflicting with each other causing random view changes.
Firstly, go into Windows Control Panel and to Game Controllers. Remove any controllers listed in that box that are not currently connected or being used in your flight simulator.
Next, go into FSX, into the control assignments section...
Go through each controller in the drop down box (in the button/keys tab) and ensure only one controller has the assignment for view changes assigned.
Nov 23, 2008 | Saitek Pro Flight Yoke System Flight...
Video Game Consoles & Games Logo
117 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
