I just received a (refurbished) Pavilion Elite m9350f. During setup, I attempted to connect my old VGA monitor. It would only be recognized by using the adapter for the one DVI port. When it was hooked up to the VGA port, the screen remained black. When it was hooked up (through the DVI port)the image quality would be OK for a couple of minutes, then it a digital pattern formed over the screen. Once that happened, the computer became inoperable after an additional minute. How can I connect properly and get everything running properly?
  • 4,806 Answers
Plug monitor into VGA port, start machine, go into the bios settings and load optimised defaults press F10 then reboot, if the problem persists its your graphics card or monitor
Posted on Nov 13, 2008
I have red vertical stripes, then white dots, then when windows loads, I have wavy red lines. Using Nvidia Geforce 9800 GT with Pavilion Elite m9350f. Is this my video card problem?
Okay you proved it is the monitor, but first sub the video cord from the computer to the monitor if possible, if okay! at this point you are looking at a LCD panel display problem, cheaper to replace than go through expensive repairs.
Mar 19, 2012 | HP w2207 Monitor
I have an HP m9000z that was previously used with a DVI cable/monitor. I only have a VGA cable/monitor and the pc doesn't access the monitor.
This PC has a VGA and a DVI ports? Are both ports on the motherboard or a Video card? Or is the VGA onboard video and DVI is a Video card? You may have to disable the DVI port to get Video to vga or enable the vga port.
Jan 13, 2018 | HP Pavilion Elite M9000z PC Desktop
No signal to monitor
if u have a two VGA output in ur PC..try to use the build in VGA port...if doesn't appear... Try the one VGA port
Oct 18, 2009 | Computers & Internet
I just hooked up my HP Pavilion 9000 Laptop to my Vizio TV and put the TV on correct setting. It is not working on the TV, any ideas? I went on Display setup and kept trying to connect but it says the...
If your laptop has a VGA port, your Vizio needs to have a VGA port too so you can use a standard VGA monitor cable.
If your laptop has a DVI port, you hook it up to the Vizio using a DVI-to-HDMI cable.
And if your laptop has an HDMI port, you hook it up using a standard HDMI cable.
Hope this helps.
Oct 16, 2009 | HP Pavilion dv9000z Notebook
Connect projector to HP desktop
If you are attempting to connect an LCD projector to a laptop,you connect a monitor cable to your video card and the other end to the monitor input connector. You may have to use an adapter, I know on my LCD projector I had to use a DVI to VGA connector.
Can't say much more not knowing if you are having a problem with a particular brand of projector
Sep 21, 2009 | HP Pavilion a705w PC Desktop
Nothing on the screen at startup
If you cant get into the setup menu then I would think the monitor is defective,you did not state if you hooked up the monitor to a computer that has a vga port that works.
Jul 21, 2009 | LG 22" FLATRON LCD Monitor
Little Experiment
fun experiment with relic, monitory.
the M90 is for PCs, not TV (settopsboxs)
  • Connections( not sound)
    1 x display / video - VGA - 15 pin HD D-Sub (HD-15) - 1
see that VGA there, that is ALL this monitor supports.
what are you attempting, what is the unstated goal to reach?
no set top box stated
no service provider to the box stated.
so you have no TV and want to use a M90 computer monitor
that it?
SCART is very old EU system, (europe)
21 pin connector
you will need a Scart to VGA adapter.
buy one.
random example. (home made not easy ever work small coax cables/) I can but you, ? It also may need special terminations
no distances stated.
why not just get a real TV? & use HDMI, for ever....
https://www.ebay.com/itm/LEICKE-KanaaN-PC-VGA-to-TV-Composite-Video-RGB-Converter-Scart-Adapter-3/263205893731?hash=item3d484b3663:g:m94AAOSw0bJZufE9
Dec 22, 2017 | HP Pavilion M90 Monitor
Toshiba 19lv505 pc monitor display issue
Since Toshiba 19LV505 is a 720i monitor. Mak sure the resoltion in your PC is as one of the following:
Monitor Display modes
MODE Resolution Refresh rate
VGA 640x480 60Hz
VGA 720x400 70Hz
SVGA 800x600 60Hz
XGA 1024x768 60Hz
WXGA 1280x768 60Hz
WXGA 1280x720 60Hz
Make sure the 2nd one is no bigger than 720, (remember, it is 720i TV) Otherwise 19LV505 will not be able to handle it, all you see is black.
Try it and see if it works.
Jan 28, 2009 | Toshiba 19LV505 DVD Player
Connection between computer and monitor!!!
The cable for the monitor has to plug into the desktop. So it's a VGA cord or DV Cord depending on the type of video card you have on your desktop. Some have a built in VGA port. Make sure you connect this to your desktop.
12_17_2011_8_16_49_pm.jpg12_17_2011_9_02_50_pm.jpgThis is the cable
Jan 09, 2009 | HP Pavilion M9040N Elite Desktop PC
Connecting Bose Companion 3 to HP Pavilion Desktop (Elite m9150f)
you have to configure your sound at control panel; you have to switch from computer speakers to external, with or without a woofer. Easy shreazy.
Mar 09, 2008 | Audio Players & Recorders
Computers & Internet Logo
69 people viewed this question
David Payne
David Payne
