Question about GE DBSR453EBWW Electric Dryer
Timer only works on Timed Dry Setting
I Have a GE Model DBSR453EB3WW Electric Dryer. The problem I have is that the Timer only works on the Timed Dry function. It does not move/work on the two Automatic settings although it does heat etc. Any ideas? Thanks, this site is very helpful
  • r_niccum1 Nov 14, 2008
    Any idea where to get a heating element at a discount price. GE only sells the entire housing assembly for 167 bucks
  • 1,543 Answers
Check your heating element. If one coil of the heating element is burnt out the dryer will heat on the remaining coil, but the timer will not advance in automatic dry.
Posted on Nov 13, 2008
  • Carl Schulzetenberg
    Carl Schulzetenberg Nov 15, 2008
    Ya, I think the restring kit for your model is a WE11X10007. Get one from a local repair shop, as GE charges high retails and shipping and handling. I'd have to check that number for sure when I get back to my shop, hopefully tomorrow. Restring kit should save you big $ over the entire assembly.
Timer counts down but doesnt shut off
same problem with Kenmore dryer Model No. 110.96250100. The timer would not advance under any setting. I replaced the timer and it only advances under timed dry but does not shut off when it times out. Under all other settings, the timer knob does not move, but the temperature stays warm. I checked the continuity on thermostats and resistor and, to the best of my knowledge, all passed. all in all, it appears to be a mechanical problem with your timer.
Please remember to award your selected response
Jan 11, 2011 | GE DNCD450EA Electric Dryer
The drum on my dryer will turn when I set the timer to any setting, but the timer does not work, nor does it heat up. Any suggestions?
See if the timer advances in the timed dry or the auto dry cycles. If the timer advances in timed dry but not in auto dry, then you could have a wire connection failure in the orange wire from the heating element to the timer.
If the timer will not advance in either type of cycle, then I recommend checking the timer part number that you are using.
Jan 07, 2011 | Estate EED4300TQ Electric Dryer
My GE dryer has no heat but runs. Also when you put the setting on more dry or less dry the dryer will run for hours, but will run the correct time on the timed dry setting. Either way the dryer will not...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Oct 07, 2010 | GE DBXR463EDWW Electric Dryer
Sensor and timed dry isn't working. Dryer runs but never stops.
if the timer dont run on the timed dry setting the timer is bad.if it works on the timed setting but not the auto setting you have a heat issue.
Mar 06, 2010 | GE Dryers
Hotpointdryer timer problem
There are two coils in the heating element, and if one burns out, the timer will not advance in automatic dry. The timer should still advance when using manual (or timed) dry.
Jan 20, 2010 | GE DBSR453EBWW Electric Dryer
Dryer is not drying clothes.
well im not going to look up the model # to see if its gas or electric,but check the exhaust tube for blockages
Apr 21, 2009 | GE DBSR453EBWW Electric Dryer
My GE Driver will not heat
Check the circuit breaker or fuse box it takes two one to run one to heat. Then check thermostats Hi limit may be burnt if it overheated If the venting had been blocked. Hope that helps
Dec 26, 2008 | GE DBSR453EBWW Electric Dryer
Electric dryer timer
the auto temp sensor is bad / Larry
Nov 01, 2008 | Kenmore 62602 Electric Dryer
DBXR453ET3WW Electric Dryer Won't shut off unless on timed cycle.
hi thanks for the question in the ge dryer theres 2 elements so if one is not working you only get half heat i would check the heater thanks the appliance doc
Jun 18, 2008 | GE DBXR463EBWW Electric Dryer
GE DBSR453EBWW Electric Dryer Logo
437 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
