Question about Intel Motherboard
After 15 -20 min my monitor goes blank
After 15 -20 min my monitor goes black and the power light of monitor starts blinking..... with nothing on the screen..... but the pc is still running n on....
  • rahulgtrived Nov 14, 2008
    Thank you.... ill try the instructions u hve given....
  • 903 Answers
This could indicate a problem with the graphics card. Take the card out and clean it, then clean the slot that it fits into. (I normally use a small dry paintbrush).
Replace the card, making sure that you push it down gently but firmly and ensure that the plastic clip has gone back correctly that hold the card in place. Rescrew the card back to the casing correctly and reboot.
Hopefully this will resolve your problem. If it does not, to determine whether or not your graphics card is faulty. Change the monitor lead over to the onboard graphics port instead of the agp/pci port and reboot. If the monitor works properly with no problems, then you have a bad graphics card.
I hope this helps.
Posted on Nov 13, 2008
When I start my computer, the monitor can take up to a 1/2 hr to display. I have dual monitors; the 'Acer' will eventually blink/show 'Acer', then fade. It repeats every 3 seconds. The...
your problem sounds like you have bad capacitors on your monitors power board. once you start it, they do not have enough capacitance to give to start the monitor, but after letting it for some 10ish minutes or so, they capacitate enough to start. even then, after some time, they will lose the capacitance because they are feeding the monitor in constant power when the power from the outlet drops a bit, but being bad - they will shut off your monitor. some repair shops can change capacitors only, others would make you change the all power board
Aug 04, 2017 | Acer AL1511 15" LCD Monitor
Why does my HP vs17 monitor screen keep going to blank black screen like it turned off but did' power button light is still on? Everything is running but no picture.....keeps happening everytime...
this old monitor has 2 issues.
1: it has CCFL tubes that love to burn out (backlamps)
most this old are long go, yell,dim.,blinking or DEAD.
2: push the menu button on front of mon. turn off power saver.
3: if the PC goes to sleep, or hibernete mode (parked)
then that is 100% normal
if you dont like feature then go to windows control panel
click power, ICON and turn off all monitor sleep /hibernate modes.
that assumes windows, no OS stated.
if the lamps are dead,
use flash light pointed to sceen, see data. ? bingo for bad CCFT tubes.
as seen here
Jan 12, 2018 | HP Vs17 17" LCD Flat Panel Monitor
The monitor goes blank after a few min, it comes
Are you sure that your computer isn't just going into power saving mode? Not sure what operating system you have but go into the screen savers tab or video properties and find out how your system is set up for power saving It may be starting before your screen saver does so the monitor would just go black.
Dec 18, 2009 | ViewSonic PF775 17" CRT Monitor
Blue power button flashing with blank screen
This is most likely the power inverter board in the monitor - this is common in many monitors. If it started taking longer and longer to display an image, and the power light is blinking on-and-off, that's the problem. You can confirm that it's the monitor and not your computer or the cable by plugging in another monitor if you have one to try.
If it's under warranty, send it back, if not, there are inverter boards for many common models of LCD monitors that are replaceable. The board can run anywhere from $50 on up. Depending on how old it is, you may find it better to just replace it with a gently used one from ebay.
Jan 03, 2009 | Dell E173FP 17" LCD Flat Panel Monitor
It may be the Monitor Problem or Re-Install the vga drivers with the cd you get while buying the motherboard.
If the problem continues re-install the OS witht the latest service packs available
Let me know if your problem is solved and rate me as FIXYA!
Apr 13, 2008 | Computers & Internet
Pc screen goes black green light stays on
Well since you seem to have tried a bunch of thing why nor go a bit more and replace your video card. Below is a link to your PC:
Dec 21, 2007 | Computers & Internet
Monitor suddenly goes black
Is this monitor and LCD flat Panel? If so this is due to a bad power supply, an inverter board going bad or LCD backlight bulb blown. When the backlight goes bad it gets just enough power to start up, but when it is on for a long period of time it goes black because the bulb is not stable enough to hold the charge because it is going bad. These bulbs can be changed, but they also can be costly!
Nov 17, 2007 | LG L1930B 19" LCD Monitor
Intel Motherboard Logo
62 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
