CPU Fan fail
To fix the problem i need to know how to flash a bios
  • 4,806 Answers
Download the latest .exe bios file to flash within windows make sure its the same bios product for your machine, go to your computer support site for the bios update............... and be carefull 1 mess up and you have a dead PC
Posted on Nov 13, 2008
When turn on my computer after a seconds the system is shutting down.. i don't know what to do, is there a problem with the processor?
A overheating CPU will shutdown and won't start up again until the CPU has cooled down.
The overheating problem (ie. thermal shutdown) is most likely caused by a faulty CPU fan or dust clogging the CPU fan and heatsink.
Check the BIOS CPU fan speed could be set too low, check the fan speed/temperature setting.
If this problem is not fixed, then the CPU will eventually fail.
Check the fan to see if it spins freely, if not then replace the faulty fan.
If the fan and heatsink are cligged with dust, loosen and remove the dust and use a can of compress air to blow away the dust.
Sep 22, 2010 | Computers & Internet
Tip
CPU Fan Speed high
What Could be happening inside when you hear the cpu fan running at a high speed always ?
Ever thought about it ? Ok let me give you a clue on this. To understand this issue you need to understand how the hardware works on various situations.
Check the Heat settings in bios and look for the variance.
Bios can instruct a CPU fan to run faster only when there are critical lssues of heating.
The CPU starts running on a realtime 16bit more known as SMM mode.
This is a feature which is inbuilt to support the continuous performance of the Processor even while temperature level rises.
The instruction is moved through the Bios, and can be a bios related issue.
Worst case, Flash the Bios once for all and the issue will be solved.
If its a very old system flashing the bios could be also a problem, still you can seek the help of a Hardware Engineer to get this accomplished.
on Feb 13, 2010 | Computers & Internet
Amd phenom faulty
Replace cpu fan , failed cpu fan might have caused CPU stoped working. If you are sure about the CPU fails then replace the CPU. If the problem seems continues after that too, then PC might have failed to boot due to other reasons. What shows on the screen once you power on the computer? There could be , motherboard , or harddisk faults too. Try unplugging other parts and see if the computer boots from CD or USD flash or floppy drive!! Once you know that motherboard works then replace the CPU. There could be BIOS setup problem. Did you check the BIOS for harddisk is set properly.
Sep 17, 2009 | AMD 2.1GHz Phenom X3 Tri-Core 8450 AM2+...
System fan has failed
Your system's fan has failed. If it is under warranty, you need to have HP made aware of this failure.
Jun 18, 2009 | HP Pavilion a1410n (ER890AA) PC Desktop
I just flashed my Bios Gigabyte GA-965P-DS3 from F12 to F13. Now my CPU fan is at full speed. It's loud and driving me nuts. I've looked all through the bios to see if I can slow it down. Also, went on...
it's actually good that your cpu fan is runing at it's full speed. Usually only the manufacturer issues firmwares. Lookforward Gigabyte for the update. thanx
Jan 20, 2009 | Computers & Internet
Hp Mecia Center m7060n fan failed, new fan not detected
the fan must be the correct fan
i guess you meant the CPU fan, ? desktops can have 2 or 3 fans.
the fan has 3 wires, in many cases, the 3rd wire is a RPM tachometer that if not correct the PC can not read RPM
if RPM reads 0 the PC will be very upset. and do that.
my guess you bought the wrong fan, and is super easy to do
giving the many fans
on some PCs the BIOS monitors the fan RPM and heat sink temperatures, or both, and tells yous fan bad for either failing
on my PC here, now, I can go in to bios and see both live sensors
RPM and Temperature. this allows for easier diagnosis
i dont think your PC has that page in BIOS to do monitors for trouble shooting, in fact mine has 3 fans all 3 are monitored, now.
high end PC .
this older desktop , only the m7200 pages are there. at hp.
so cant look at the fan nor BIOS.
i use a windows program that lets me watch the fan speeds
and all CPU and GPU core temperatures. (ask) its free.
the troubleshooting guide at HP stops short at this problem
says get it fixed. so you want to fix it your self sure.
so talk to one of the top, CPU/HEATSINK/FAN makers
and buy this from them.
if the fan spins fast and RPM is 0 wrong fant
if the fan spins fast and RPM is ok, then the BIOS dont like the CPU temperature... this has 3 causes.
fan dead. or slow. or wrong fan installed
heat sink fins packed in lint as all do ever year.
heat sink thermal bond compound failure, common.
Jul 18, 2017 | HP Media Center m7060n PC Desktop
Processor fan failure massage.
I supose the fan works, you then need to enter bios and disable cpu fan monitoring, if the fan doesnt spin connect it to another fan connector or a plain 4pin molex connector / might require a adapter.
Try to get into bios and disable cpu fan fail alarm, keep the temperature alarm on 80 or 70. so it will yell if it gets too hot.
Apr 17, 2008 | Intel Motherboard
Cpu fan noisy /chip fan fail
You must buy a new CPU Fan. You can get them HERE or a zillion other places on the Internet. You need a Socket 939 type fan that will handle your cpu speed. If you need help installing it, it may be in the manual. You can read the manual by clicking on the picture of your MB at the top of this post and then scrolling down.
Hope that fixed ya...
Geno
Apr 01, 2008 | ASUS A8N-E Motherboard
Computers & Internet Logo
81 people viewed this question
David Payne
David Payne
