Back to:
Tags:
Whirlpool Duet GHW9150P Front Load Washer
Control lock light (by 15 users)
posted by powerless on Nov 16, 2006
I loaded my duet washer, closed the door and the control light is stuck on and it won't start any cycle. Can you help? I did unplug the washer but it won't reset.
Comment by powerless, posted on Nov 16, 2006
Press the end of cycle signal- button for 3 seconds and it is ready to go.
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
14 Other Users Have The Same Problem
Comment by Guest, posted on Sep 11, 2008
The "control locked" light is on on my washer. I am unable to start any cycle.
Comment by dwb2006, posted on Aug 17, 2008
Found control lock light on.  Recommended solution pressing end of cycle button worked.
Comment by kaylarson, posted on Jul 18, 2008
control light is on and machine won't work
Comment by kmahaffeyste, posted on Jun 27, 2008
All of the lights are on looks ready to start, but won't! Help
Comment by Bonnie139, posted on May 24, 2008
I run out of water and the machine shows a error message, I try to cancell but it does not response
How do I reset my machine?
Best Solution
posted on Oct 12, 2007
FixYa! (100)
ally1010
Rank:Apprentice Apprentice
Rating: 100%, 14 votes
worked for me too :) thanks.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on control lock light:
I don't want to Accept this solution
Solution #2
posted on Oct 21, 2007
FixYa! (100)
Guest
Rating: 0%, 0 votes
i had the same problem with my duet magtag washing machine. The control locked light displayed and i tried repeatedly to turn the power on and off but to no avail.  i read this persons complaint the same as mine and i was able to hold the end of cycle bottom down for three 3 seconds and the light disengaged and now i was able to do my washing.
Thank You!
Solution #3
posted on Jun 08, 2008
FixYa! (100)
Guest
Rating: 0%, 0 votes
What does it mean when it reads hf on the washer.Does not spin right
Thank You!
Solution #4
posted on Dec 16, 2006
FixYa! (100)
donno
Rating: 100%, 51 votes
Try holding in the "End of Cycle"tone button
Thank You!
Solution #5
posted on Sep 05, 2007
FixYa! (100)
Guest
Rating: 0%, 0 votes
wow, worked for us too. thx!
Thank You!
Solution #6
posted on May 16, 2007
FixYa! (100)
tareik
Rating: 99%, 27 votes
End of cycle button WORKED for my stuck Control Light. THANKS
Thank You!
Solution #7
posted on Sep 11, 2007
FixYa! (100)
Guest
Rating: 0%, 0 votes
It worked! Thank you :)
Thank You!
Solution #8
posted on Mar 09, 2008
FixYa! (100)
lori325
Rating: 95%, 3 votes
Thanks I was so excited to find this help online, Thought I would need to call an overpriced plumber on monday. Then I tried the help you guys told me and was so excited I went out and got icecream and the whole family made icecream sundaes to celebrate.Easily pleased- thanks
Thank You!
Solution #9
Not Rated (0)
Guest
Rating: 0%, 0 votes
not working for me!!!!!
Thank You!
Solution #10
posted on May 01, 2008
Not Rated (0)
Guest
Rating: 0%, 0 votes
THANK YOU VERY MUCH
THERE IS NOT A WORD ABOUT IT IN THE WHOLE MANUAL. I HAVE GREAT APPRECIATION FOR PEOPLE WILLING TO SHARE THIS INFO.
WORKED GREAT,
CLEAN AGAIN!!!
Thank You!
Solution #11
posted on Apr 04, 2008
Not Rated (0)
Guest
Rating: 0%, 0 votes
THANK YOU SO MUCH!! THIS WORKS!!
Thank You!
Solution #12
posted on Jan 27, 2008
Not Rated (0)
Guest
Rating: 0%, 0 votes
Thanks so much!!! What a relief!
Thank You!
Solution #13
posted on Dec 29, 2007
Not Rated (0)
Guest
Rating: 0%, 0 votes
Just want to say I had the same problem with the Control Locked light, used the advice on this site about holding down the end of cycle button - it worked! yipee!!!!!!!!!!!!!!!!!!!!!!!!
Thank You!
Can you Help with these Washing Machines problems?
All other functions, including agitate and drain, are...
My wife's duet dryer will not start. The unit has power,...
Fabric softner does not dispense, basket remanes full...
washer doesn't wash slowly. Always on super high spin...
I have the front load Whirlpool Duet washing machine and...
14 Other Users Have The Same Problem - Continued
Comment by Guest, posted on Apr 26, 2008
i pressed yhe end of cycle button the light is blinking and we still cant get frontloader to start.
Comment by Guest, posted on Feb 23, 2008
Thanks. Holding the end of cycle alarm for 3 seconds did it. Very frustrating, all I was doing was releveling
Comment by Guest, posted on Feb 02, 2008
"End of cycle" worked great. Thanks!
Tried powering off for 15 minutes, then a complex set of button pushes but this simple remedy worked the best.
Comment by Guest, posted on Jan 17, 2008
end of cycle button worked great. Thanks for saving me alot of headache!
Comment by Guest, posted on Jan 02, 2008
i have a whirlpool hdwm1100 and the panel is saying control's locked i have tried holding down the end of cycle button but has not worked can you help ?
Comment by Guest, posted on Dec 25, 2007
Comment by Guest, posted on Nov 15, 2007
Yup, that worked. Just hold the "end of cycle" alarm button for 3 seconds.
Comment by lgoode, posted on Nov 13, 2007
Just want to say I had the same problem with the Control Locked light, used the advice on this site about holding down the end of cycle button_ IT WORKED!!! THANK YOU, THANK YOU!!
lgoode
Comment by Guest, posted on Nov 02, 2007
Mid cycle my front loader stopped and timer started flashing with (F-28). We unplugged, reset breaker, pressed stop, pause it will not restart. Also door will not open (there is still wet cloth inside). We need help to get the door open to remove wet cloth.
Loading problems.
Repair Service
Find Washing Machine Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
