I have a Gigabyte MA78GPM-DS2H and I'm having audio problems. I've checked the external speakers on another box and they work. I tried to update the drivers and I have the most current. I checked CMOS to make sure the onboard audio is enabled, it is... I checked the internal wire connections and they are all placed correctly. I'm still not receiving any audio. When I do plug in the external speakers Vista asks me about the place I've plugged them in at. Any other ideas on how to fix my issue?
I reinstalled the drivers and the audio is now working.
Posted on Nov 14, 2008
How do I diagnose and fix my laptop's sound problem? Should I just throw it out the window?
From the description you have a hardware problem possibily caused by the ipod plugged into the headphone jack of the laptop. I'am convinced the sound section on the motherboard is damaged, probably the audio output ic. But to trouble shoot the problem will require someone with a strong background in electronics, I would suggest going no further until you have estimate in hand.
Jun 26, 2012 | Computers & Internet
which operating system
You receive an error that states: There might be a problem with your audio device
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrative tools computer management device manager scroll to sound video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to
reinstall drivers
click start control panel sounds and audio volume advanced speakers make sure you have selected the
(appropriate speakers) also audio you will find 3 drop down lists make sure you have selected the correct speaker settings there
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
if his does not fix the problem
click start control panel sounds and audio devices you can adjust the volume there also select speaker
volume you can change your settings there you can also tick in the box place icon in taskbar for any
further volume control settings you will need to right click on the speaker volume icon system select adjust volume
click start control panel sounds and audio volume advanced speakers select the appropriate speakers
from the drop down list or navigate to the device manager scroll to system devices + to expand system
speaker right click properties then select use this device (enable) also you might check
the speaker plug/outlets is usually at the back of the computer or if its a laptop on the side
you will have to open up the computer to check the lead attached to the rear of the input plug make
sure the connection is good with no dust as dust causes static electricity
clean your computer of dust using a fine air blower from a compressor making VERY sure that there is
no MOISTURE in the air line specifically around the sound card and the CPU central processing unit
dust causes static to build up in a computer
hope this helps
Jun 26, 2012 | Fujitsu Siemens Amilo Pi2515 Laptop...
Dell Inspiron 6400 E1505 audio not working.
Try system restore to straighten out registry to play audio..
Apr 01, 2012 | Dell Inspiron 6400 Notebook
I cant find raid driver for Windows 7 to my motherbord GA-MA78GPM-DS2H Hans Gunnarson
North Bridge AMD 780G South Bridge AMD SB700The AMD RAID drivers should do the job,
http://wwwd.amd.com/AMD/SReleaseF.nsf/softwarepages/DriversbyDeviceChipset?OpenDocument
Along with AMD RAIDXPERT
http://support.amd.com/us/kbarticles/Pages/CS1-AMDRAIDXpertDriver.aspx
Mar 18, 2011 | Gigabyte Computers & Internet
My computer can't play audio on speaker and head phone.
Hi, try this link to download your audio driver: http://en.kioskea.net/download/download-1119-drivers-for-motherboard-gigabyte-ga-ma78gpm-ds2h
Hope this helps
Jul 16, 2010 | Gigabyte GA-M61PME-S2 Motherboard, AM2,...
Audio Problem
when was the last time when your audio was working fine? try to do a system restore first, if not fix then download the latest audio driver. uninstall then reinstall the audio driver. try connecting an ext speakers if you will audio if yes then check audio settings from the control panel. if not then update the bios if not then replace motherboard.
Oct 15, 2009 | Dell Inspiron 1525 Notebook
I used ga eg45m ds2h, is it necessary to install eternal graphic software, when im using a third party card say ati hd4550. when i play some games it tends to fliker and exit, automatically... pls. help me...
Operating system have built in drivers that can be used when installing external harware line video card. The problem with this is that sometimes new drivers are released for video cards to fix bugs. So, I suggest you install the latest driver of you video card. If you don't have, just google it you can definite get it.
regards,
Jeep Brainy
Aug 10, 2009 | Gigabyte GA-EG45M-DS2H M-Board,...
Speakers make crackle noise.
tried to reinstall/update your audio drivers and tixed your sound equlizer.
Apr 06, 2009 | HP Pavilion dv9000z Notebook
20 people viewed this question
 Grubhead
Grubhead
