Question about iiyama ProLite E434S 17" LCD Monitor
Flickering screen on iiyama prolite monitor
About 4 months ago we had a couple of power cuts within a few days of each other. Both times my computer and monitor were turned on and obviously cut out. I noticed, after the second occurence that my screen was a little bit blurry particularly using outlook express the type is a bit faint and it shimmers. Its usable and is not getting any worse. However the shimmer and blurred aspect is magnified hugely if I try to play any downloadable games on shockwave.com for example. It is fine for games like solitaire that are already on the system. any thoughts on correcting this would be greatly appreciated. I don't really want to buy a new monitor.
5 Suggested Answers
worldvet
  • 859 Answers
SOURCE: iiyama ProLite E481S random shutdown
If you're talking about a CRT that is going on "The Blink", yes this is where the name comes from. And this is becoming more and more of a problem you do indeed need a new monitor.
Three good places to shop online is :
newegg.com
zipzoomfly.com
tigerdirect.ca
Be certain what ever you buy is compatible with your current video display adapter. If your adapter has a VGA and a DVI socket than you can get either in a flat panel which is to say 60Watts vs 180 Watts in power consumption. The larger the flat panel the more power it consumes. More often than not, a 17 or 19" flat panel is more than sufficient. If you actually plan on sitting at your PC and watching movies go wider. If you are a hard core gamer go wider. Otherwise, a 17 or 19" monitor should serve you well.
Posted on Jul 06, 2008
SOURCE: colour changing
thanks worked perfect
Posted on Aug 31, 2008
  • 82 Answers
SOURCE: iiyama Prolite E431S turns itself on and off
i think your monitor lose a power connection
Posted on Aug 31, 2009
Geekman
  • 32281 Answers
SOURCE: Iiyama Prolite 434S monitor is too dark
Dim or dark display can be caused by a faulty inverter board or faulty CCFL lamp. The inverter supplies high voltage to the CCFL lamp, the CCFL lamp is a miniture fluro tube and these dim with age.
Check out LCD Parts for service, parts and DIY info - click on this link to their WEB site. :-
www.lcdparts.net
Posted on Sep 28, 2009
Hello, I have an insignia NS-C3113 aftermarket radio in my 1995 Chrysler Sebring. The radio worked fine when I bought the car a couple of months ago and has quit working since. At first the radio began to...
When you say that your stereo was cutting in and out do you mean that the power was cutting in and out or the volume. If the power is cutting out then the problem could be that the stereo is not grounded properly or the positive power is not connected properly. The only way that a fuse will be burnt out is if you short the stereo. If you have a12 volt test light it will come obviously handy to check your power source. A multimeter can also be used. I hope it helps
Oct 03, 2017 | Insignia NSC3113 Car CD MP3 Player
Screen cutting out
The picture board on your monitor is bad, since it goes off after few seconds and the power led or button is on, it means the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer within your vicinity to help with the replacement of the picture board because the fault is not something you can fix yourself, in order not to complicate issues.
Take care.
Jun 29, 2010 | Hannspree HH251H 25" LCD Monitor
Monitor will not turn on including power switch
I suspect the power supply for the monitor. Try a power supply from a working monitor. If you have a used computer store nearby, take your power supply to them and try it on another monitor.
There is no need to turn off a monitor using its power switch. Monitors automatically go into standby mode when they are not receiving a signal. In standby mode they use less than one cent of electricity per day. If saving electricity is your goal, raise the temperature in your home by a degree and run the air conditioning less.
May 17, 2009 | Dell Computers & Internet
Doesn't hold a charge or cut very well anymore
Heads for your model are no longer available. Shaver will not hold a charge because batteries need replaced. Batteries can be replaced but soldering is required. If you have cleaned it well and it does not cut, I suggest getting a new shaver.
A full line of Philips Norelco shaver can be found at shaveroutlet.com
ShaverOutlet com ShaverOutlet com Rotary Shavers Men Shavers Manufacturer...
May 22, 2017 | Norelco Advantage 5615 X Electric Shaver
Westinghouse LCM-19W4
I had the same problem with my two LCM-19W4 monitors. Both failed within two months of each other. Radio Shack stocks 220uF 35V capacitors that work fine for this. You have to pay $1.49 ea though.
Nov 02, 2008 | Westinghouse LCM-19v1 Monitor
Monitor turns off
If the picture is Reddish either at top or bottom It could be the backlight failing.If you are technically able you maybe able to Replace the CCFL backlight.
Samir
Feb 21, 2008 | LG Flatron L1710B 17" LCD Monitor
Sound cuts out when you touch the cord???
bad cable shorted out in it can u get new cable or under warenty for 1 yr ?
Jan 09, 2008 | Logitech Z-5500 Computer Speakers
Tv cuts off and green light flashes
the tv will try to reboot a few times. just let i try and eventually it will start blinking red. if you could count the red blinks then i can further assist you.
Sep 23, 2007 | Sony Grand WEGA KDF-60XS955 60" Rear...
iiyama ProLite E434S 17" LCD Monitor Logo
213 people viewed this question
Top iiyama Computers & Internet Experts
William Miller
William Miller
Are you an iiyama Computer and Internet Expert? Answer questions, earn points and help others
