Question about Maytag Dishwashers
My dishwasher has no connection. The entire "board" is without lights. I cannot start the machine. My biggest problem is getting support from local service! I have not talked to anyone who will help! The service depart. does not return my phone calls! Dishwasher was purchased two years ago this month, Model number:MDBH945AWW
3 Suggested Answers
HDTV GURU
  • 261 Answers
SOURCE: Dishwasher won't start
Try resetting the unit by shutting off the circuit breaker first for 1 minute then try the reset button. If nothing happens, then i would recommend having someone take a look at it.
Posted on Feb 09, 2008
  • 4088 Answers
SOURCE: Maytag Dishwasher-MDBH945AWW
About the only things that move in the cabinet other than the water pump is the spray arms. The lower arm should be screwed down fairly tightly (plastic screw), but the upper arm is held in place with a plastic friction plug--it tends to wobble more. Spin both arms by hand to see if either hits something (have the drawers in). The lower arm has metal clips on the ends which may be coming loose. They are just clipped onto the arm edges. Hope this helps!
Posted on Apr 06, 2010
SOURCE: MDBH945AWW maytag dishwasher panel lights will not
These control boards do not have fuses on them. I opened mine up when the front panel touch pad stopped working and the LED indicators were anemic. This is a sign of the ribbon cable connections have oxidized. The ribbon cable connects the touch pad to the control board.
Others have written up nice solutions on similar Maytag diswashers with the touch pad.
http://www.fixya.com/support/t387192-maytag_quiet_series_300_no_power_touch
The previous expert shows that you can diagnose this by using a 10k resistor and connecting pin 6 and 10 on the ribbon cable connector and it will start the dishwasher (you have to trip the door handle and carefully do this with the power on). This proves that the control board is fine and ribbon cable connections are the problem. Don't forget to quickly trip the door latch once the dishwasher starts.
My solution was to purchase a contact cleaner called Deoxit. You can order from RadioShack.com or get at Frys. Spray Deoxit on both the ribbon cable end (removed) and into the connector on the control board. Deoxit removed the oxide on the connectors. The twin pack Deoxit spray comes with a solution that helps prevent corrosion. I am 1 day into the successful repair of this model Maytag dishwasher.
Previous people have suggested heat and steam get into the control board and oxidize this connector. I notice on the top right where the control board sits, there is a gap to allow steam to get into the door/control board area. I used bathroom caulk to seal both sides of the door to hopefully prevent further corrosion.
Posted on Apr 11, 2010
Where in USA do you buy "dishwasher salt"?
Unless you have hard water it is not necessary to use the dishwasher salts. We are in an area with very soft water, just pretend the red light is not there and wash as usual. Same for drying agent, we don't use it and the machine still works even though the lights are on. We actually had a repair person come out, the company we bought the dishwasher from were willing to give us a new one based on my saying it didn't work without salts. Needless to say I felt like an idiot when he came. The manual that comes with the unit should be better written.... There is a delay between turning the power on and the machine starting which was the biggest reason I thought it was not working without the salts.
Jun 07, 2014 | Danby DDW1899WP Portable Dishwasher
The Clean light on my frigidaire gallery dishwasher is on continuously. The dishwasher will not start. Its over 10 years old.
the problem is in the pcb board which will have to be replaced and cost a few hundred dollars. considering that machine is only designed to last 7 years i would just replace the entire machine.
Sep 26, 2013 | Frigidaire 24 in. FDB1050REC Stainless...
CL trouble light flashing
If you reset the unit from the household circuit breaker and it doesn't change, then contact a professional to have the main control board repaired.
Aug 19, 2012 | Electrolux Frigidaire Professional Series...
Dishwasher will not start. All option buttons light up except the Start/Stop button and the cancel button. I have turn the power off and on but still no wash cycle. Inside float is clear and so is spray...
Hello, I am sorry that your dish washer isn't working. One of the biggest problems with these new dishwasher is they install the control on top of the door and the operational circuit board below the control panel. Inside the door is acceptable to moisture which creates all kinds of problems. It not the spray arm or the float, or the pump. it is where they put the circuitry to control the dish washing machine.
I hoping that all you will need is a push button control strip for this dish washer. moisture get in the micro switches and make them inoperable. These button in the control strip are hermetically sealed against moisture....for a while.
Remember, it depends on how long has the dishwasher been working and what will be the cost to repair your dishwasher. Dishwasher are really good for 10 to 12 years of service. I worked on a Kenmore that was 25 years old. I told the lady of the house it is time for a new dishwasher. I could have repaired it, but really it not worth it when it is this old. GB...stewbison
Sep 06, 2011 | Maytag Dishwasher
Washer will not start. "Clean"
Hello & Welcome to FixYa
Flashing light is reset by pressing two buttons in sequence 3-4 times, to reset your dishwasher press these buttons in sequence:
High temp wash-heated dry-high temp wash-heated dry
Please get back to me if you have any other questions.
Kevin
Jun 20, 2011 | Dishwashers
My Frigidaire Dishwasher FDB1050RES2 gets stuck in a rinse cycle. The light on the front will be lit "clean" but the bottom of the washer is full of water. Opening the door does not turn off...
by the descrition you are giving you will need to replace the main control board.Part number 154568401.you may also need to check the float switch.The part will run about 110.00 dollars from a local parts store
Dec 29, 2010 | Frigidaire 24 in. FDB1050RE Built-in...
BAUMATIC BFD47SS dishwasher won't start
Sounds like the water inlet solenoid valve is not opening. Not easy to get at to test, but if water is available at the hose inlet connection as you say there isn't anything else stopping water entering the wash cabinet.
Shouldn't be a lengthy repair - so I'd recommend getting a quote.
Aug 09, 2008 | Baumatic Dishwashers
Dishwahser won't start, start button won't light
I took the door apart, removed the control board, which I had expected to replace. I disconnected the ribbon cable that connects the control panel to control board cleaned the connections and reassembled everything. The dishwasher has been working since.
Jun 16, 2008 | Jenn-Air 24 in. JDB1090AWS Stainless Steel...
Have an AEG 8081i dishwasher. It is displaying "CE" in the timer screen with flashing indicator lights. What is it?
Aeg 8081iM "CE" fault..
Fixed it! :) wax valve looks like it got water in it, blew the controlling triac on the main board and fried a track on the board. Bought a new wax valve, installed it. Got a quote for a new board...too much($600Aud+ I'd buy a new one If I had to pay that)...Found a dead machine which had a blown transormer but good board, so played swapsies with the transformers on the main board. Fixed the source of the leak, switched it on and started washing the dishes! :) Now have a $30 spare parts machine for the experience! :)
Jun 09, 2008 | AEG Dishwashers
Open Questions:
Dishwashers Logo
20 people viewed this question
Top Maytag Dishwashers Experts
Mike Cairns
Mike Cairns
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
