Question about Sharp AL-1540CS All-In-One Laser Printer
F-5 error My copier flashes f-5 error? Not sure what it means. Model # Sharp AL-1540CS
  • 38 Answers
Manual says F5 as copy lamp lightning abnormality.
Never had on AR series Sharp machines this trouble,but remember on old Canon NP 6016 when lamp was bad -no dark ends and low intensity of lightning but intensity too high.This machine was equiped with doc feeder and customer performed a lot of copies from glass only and I think he was damaged lamp when close the doc feeder.
the fluorescent type lamp was used on this Canon-Sharp uses Xenon lamp (I think),but they could be very common in construction (tube with electrodes on ends and gass inside)
This fault is very difficult to troubleshoot-try another lamp first,next sensor from good working machine.
Posted on Nov 13, 2008
Error code H 4 Sharp model AL 1540CS
This is a critical issue which needs constant monitoring of the device and continuous chat / email exchange.
Thus it is advised to please avail paid fixya services for better support and quick solution.
Thanks
Oct 24, 2011 | Sharp AL-1540CS All-In-One Laser Printer
We have a SHARP copier that is giving an ''L'' error signal. Pease advise as soon as you canl
L1 mean scanner problem
l4 mean main motor problem
What is your problem,I wiil solve
Jan 07, 2010 | Sharp AL-1540CS All-In-One Laser Printer
Sharp 1540cs L-1 error, then L-5
Try cleaning the guide bar, then lube it with oil also clean your sensor under your carriage(blow it out with a can of air. If the problem persist check your belt and make sure its tight. You can adjust it from the left rear of the machine behind the Main board.
Mar 26, 2009 | Sharp AL-1540CS All-In-One Laser Printer
Code CH on Sharp copier
CH code on a Sharp usually means the front door or a side door is not completely shut. Try opening and closing every exterior door until the code goes away. If the CH is flashing, it could mean either an optical or a heat roller fuse might have blown. Have you recently replaced any supplies?
Feb 27, 2009 | Sharp AL-1540CS All-In-One Laser Printer
I have 2 model al-1540cs copiers that are producing blank copies. The scanner doesn't seem to be moving and is in the unlocked position. I am getting no error messages, the paper is facing in the right...
When [L1-00] appears, the scan head
locking switch is locked. Turn off the
power, release the scan head locking
switch, WAIT 10 SECONDS and turn the power back on.
Dec 04, 2008 | Sharp AL-1540CS All-In-One Laser Printer
Error Code "L" 0n Sharp AL 1540CS
The scanner does not move - I get an "L" code flashing on the readout - please help???
Jeri
Oct 04, 2008 | Sharp AL 1631 Copier
AL-1540CS error code F5
i have al-1540cs and it if flashing H then 4
Apr 09, 2008 | Sharp AL-1540CS All-In-One Laser Printer
Sharp AL- 1540cs
On my SHARP AL-1540CS printer 4 and H blinks alternately and none of the buttons except power is working.
Oct 19, 2007 | Sharp AL 1215 Black and White Copier
Sharp AL-1540CS All-In-One Laser Printer Logo
138 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
