Question about Lucent Legend MLX-28D Corded Phone
Programming Merlin Magix PRI for outbound caller ID
I've got a Merlin Magix with PRI, how do I program it so that the end user can see our number?
Thanks.
How to get caller id for missed calls for Panasonic kx-t7730
Panasonic KX-TA624/824 automatic Caller ID logging How to set up automatic Caller ID logging
in the KX-TA624 phone system with KX-T7735 phones. (for dash four and five, and KX-TA824)
System Programming:
  1. In System Program number 900, enable Caller ID for the lines you have Caller ID on. (To get into system programming, press Program * # 1234.)
  2. In System Program number 901, select your own area code and any other area codes that don't have to be dialed when making a call. The area code digits are removed from Caller ID log information so you can return a call without dialing unnecessary digits which would mess up the call.
  3. In System Program number 902, if necessary, indicate the number of digits to be removed, and a particular digit (usually 1) that might have to be added, when returning a local phone call. The default programming is to remove the first three digits, and add nothing; which is correct for most locations.
  4. In System Program 903, if necessary, indicate the number of digits to be removed, and up to 4 digits that might have to be added, when returning a long distance phone call. The default programming is to not remove any digits, and add a 1; which is correct for most locations.
  5. In System Program number 909, enable Call Log Assignment for each phone where you want to log Caller ID information. You can use * to indicate you want logging at all phones.
  6. Get out of system programming. (Press Hold or End, then Program.)
Phone Programming:
  1. Program a button for Caller ID Indication on each phone where you want to log Caller ID information. Press Program, then the button you want to use for Caller ID Indication (we recommend the top button in the left column), then 96, then Store, then Hold, then Program. (If you want a phone to record Caller ID information individually, rather than for the whole system, use 6 instead of 96.)
  2. At each phone where you want to log all calls, press intercom, then 7382#.
User Tips:
  • The Caller ID Indication button will light up only when the system has logged UN-answered calls.
  • Use the Navigator Key at the lower right corner of the phone to scroll through Caller ID information.
  • You can erase the entire Caller ID log by pressing Intercom, then 70**#
  • You can erase an individual Caller ID record by pressing Transfer while the information is displayed.
  • If your phone does not have a Navigator Key, you can program an available button for Caller ID Selection. Press Program, then the button you want to use for Caller ID Selection, then 97, then Store, then Hold, then Program. (If you want a phone to record Caller ID information individually, rather than for the whole system, use 7 instead of 97.)
  • To call a number displayed on the Caller ID log, pick up the handset or press the speakerphone button, and press the Caller ID Indication button.
Jul 01, 2015 | Panasonic KX-T7730 Corded Phone
How do I unblock my phone number
After you enter *67, you hear the dial tone. Dial the outbound number. Your caller ID is not presented on the receiving end.
After you enter *82, you hear the dial tone. Dial the outbound number. Your caller ID is presented on the receiving end.
Sep 25, 2014 | Lands Phones
Where is the Caller ID for Outbound calls programmed?
Have you resolved this yet? If your CO connection is analog, it's done by your telco. If you have a PRI (T1), then it's in your system's configuration.
Jun 26, 2014 | Nortel Lands Phones
NEC Electra Elite IPK B64-U20 KSU
I have a PRI and am asking the same question. I do know that you do have to go into programming to set this up. You also have to have a COIB card installed for this to work for standard Direct Inward Dial lines.
Apr 18, 2013 | NEC Electra Professional ETW-16DC-2
How do i change the outbound caller id number on the T7316? several of our users lines are currently programmed with my number as their outgoing caller id number, so their clients keep calling me back...
I found this guide that has a lot of information regarding the programming of the Norstar phones..
Hope this helps you!
http://www.telephonemagic.com/phone-support/norstar-feature-programming-code.htm
Mar 31, 2011 | NorStar T7316E Corded Phone
I am configuring a pri ckt in mitel sx200icp i cannot make outbound calls i have programmed pri card as per carrier in form 42 with NI2 - NI2bell have tried all procol variant incoming is fine
It sounds like the outbound Caller ID is not set up properly in form 22. You will need to insert *6 into the dial string. If this isn't set up, many carriers will reject the call as it doesn't see the correct outbound caller ID.
Sincerely,
Mark
Mar 16, 2011 | Mitel PRI Card T1 E1 (9109615001)
How do I programm the Speed Dial on my 4406D+?
To program your Personal Speed Dial numbers, make a list of
your telephone numbers/extensions numbered 1 to 24, then:
Press an Intercom button + lift handset + dial #00 + dial # + list number (01 to 24) + dial *21 + the number you want to store + #*00.
To use Personal Speed Dial:
1: Press an Intercon button.
2: Press Feature (if you have programmed a "Feature" button) or #.
3: Dial the two-digit code (01 to 24).
Apr 27, 2010 | Avaya Merlin Magix 4406D+ Corded Phone
How do I enable caller ID on a Lucent MLX 10DP phone system?
The CID comes from the trunk card and cabinet. It's probably a Legend or a Magix system. If you don't have the proper hardware, you need to order and program it.
Your best bet is to call your AT&T/Avaya/Lucent installer and check with them as it's beyond the scope of a free forum to give exact instructions.
Carl
Oct 14, 2009 | Lucent Merlin Legend MLX-10DP Phone
Mitel IP3300 Outbound Caller ID
First you will need to contact your carrier. I am assuming that you have a T1 or PRI service. Carrier is usually the one that controls caller id. If they dont have any restrictions please contact your local Mitel dealer. They will need to program your system.
Cheers
Mar 18, 2009 | Lands Phones
Merlin Magix PRI
If D-channel is dropped, you will get red light.
When B-Channels are in use, you will get amber light.
Sep 08, 2008 | Avaya Merlin Magix/Legend Control Units,...
Lucent Legend MLX-28D Corded Phone Logo
299 people viewed this question
Top Lucent Lands Phones Experts
Paul C.
Computer Repairing
Computer Repairing
Michael Galve
Michael Galve
Are you a Lucent Lands Phone Expert? Answer questions, earn points and help others
