Question about Compaq Computers & Internet
My compaq Presario V6000 will not start windows, it continously loops to an options screen with the following start options; Safe mode, safe made with networking, Safe mode prompt command,Windows last known working settings and finally Start windows normally. None of these work, the screen flashes a message in blue and loops back around to the above options.
  • Compaq Master
  • 4,806 Answers
What you are describing is the blue screen of death, meaning theres a hardware or software problem, try to boot into safe mode and perform a system restore, if that doesn't work use your XP cd, let it load the drivers and the ask it to fix the existing XP installation, anything that you have saved in my documents should be safe and the problem should be solved. If the blue screen reappears then you have a hardware problem
Posted on Nov 13, 2008
Good morning. My Compaq laptop (Presario V6000) is freezing on this screen when booting up: "Windows is starting up..." It has no battery life, so it's always plugged in. Please help. I have...
You can try booting into safe mode to see if there is a problem with a program/driver/setting in windows. First shut off the machine completely. Then after the first logo screen goes away start tapping F8 about every second until you see a new menu screen. It will have options like Safe Mode, Safe Mode with Networking, etc. Use the arrow key on your keyboard to highlight Safe Mode with Networking. Then hit enter. You may have to hit enter again to select your operating system, but usually it just flashes text across the screen then comes to the Welcome screen with Administrator and your username. Click on your username to log in. Click OK on the warning message that pops up, it just explains safe mode. Try opening word and your paper, and see if you can work. If so, then you need to figure out which driver or program you recently updated, and roll it back or uninstall it. If you need further help let me know.
Jul 06, 2011 | Computers & Internet
Safe mode
Get windows 7, or downgrade to xp. lol kidding. During the start up, i beleve its either f11 or f12 press them it should bring you to a boot screen. follow option. or you can use the compaqs built in recovery system. reinstall your system. vista has a option to save its old files for transfer.
Dec 29, 2009 | Compaq Presario 5000 PC Desktop
Compaq presario is stuck in a start up loop, this is a new problem, can't get the computer to go past the windows start up screen
Press F8 after you restart( before the Windows screen). And choose Last good configuration. If it does not work Repeat in Safe Mode and try to restore to a previous Restore point.
If nothing works you might have to reinstall Th OS.
Hope it helps.
Rate the solution if it solves your problem.
Aug 30, 2009 | Compaq Presario Notebook
Windows xp will not load on my computer....
It could be your hard drive problem. Which I called it, "Crash." I would suggest you try to format the hard drive and reload the operation system with your installation CD.
Jul 22, 2009 | Acer Aspire™ T180 PC Desktop
Start Normally (black screen with options)keeps re-loading itself
If you can't get into windows normally or into safe mode to try to restore the system back to a date when it worked properly then you'll need to wipe out the hard drive and start the system from scratch.
Feb 08, 2009 | Compaq Presario SR1050NX (DW257A) PC...
Stuck on safe mode
goto start --> run --> type msconfig --> there should be a option to change to the boot tab, under boot options tick safe mode off. and press apply and then ok and restart your computer
Jan 24, 2009 | Compaq Presario 5000 PC Desktop
Compaq presario 2500 does not boot
you got an OS problem try to re install your OS.
Oct 17, 2008 | Compaq Presario 2100 and 2500 ,NX 9000...
Compac presario R3000 problem
That screen is normal but only shows on certain occasions. Just use your arrow keys to highlight "Start Windows Normally" and press enter and you will continue to the blue sign in screen. If the removal software asks you start Windows in "Safe Mode", then restart the computer and select "Safe Mode with Networking".
Most common method for receiving that screen and those options is pressing a specific key during start-up for additional start-up methods. Another reason which may be the reason for your case is that something went wrong during start-up. Just follow the instructions above and it will be fine. Usually the reason why you are asked to choose is shown at the top of the screen and it will tell what the problem is.
Aug 11, 2008 | Compaq Presario R3000 Notebook
Compaq notebook won't boot up
Hi
When you boot the computer back up go into Safe Mode and check to see if you can roll the computer back to the point before you installed the software.
If so this should work. If it works then run a virus scan, a defrag of the hard drive and cleans the temp files.
OR
You can do a diagnostic startup and uninstall Onecare. So once that it is uninstall ed it should be smooth sailing.
Here is a link for some startup / diagnostic software you could try after booting.
I hope this helps
/Shawn
May 19, 2008 | HP Compaq Presario V2000 Notebook
Computers & Internet Logo
146 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
