Question about HP Computers & Internet
My Hp 6700 will not boot up. The power button comes on and the fan starts to run, all of the quickbuttons light up but the computer fails to boot at all. just a black screen. the problem started when it failed to come out of a screensaver, i had locked the computer and left it out for 3 hours, nothing out of the normal, the fan was working decently hard when i returned. The computer is 6 months old
  • HP Master
  • 4,806 Answers
Has the computer been switched off when you try to boot?
Posted on Nov 13, 2008
HP pavilion dv6815nr (6700 series) won't boot after removing and and putting back the cmos battery. How do I troubleshoot this?
You bricked the motherboard. You can;t leave the battery out that long. The capacitor that holds just enough charge to change the battery probably went dead. BIOS is gone.
Sep 01, 2014 | HP Pavilion dv6815nr Notebook
Computer on no display,coming peeps,not work fan
When you plug in the power cord is there any lightswhatsoever on the laptop, where the plug goes in or on the AC Adapter of thepower cord?
When you press the power button do you hear fans running, hard drive spinning,lights on the computer, hear any beeps or lights constantly blinking, hear theDvD/CD drive click and the light on the drawer of the DvD/CD turn on for asecond or two? If so the computer is trying to boot or may have booted, butthe screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous. Most times the problemis with the memory or Video Card. Count the Blinking Lights or Beeps and takenote of their pattern (1 Long or 1 Long followed by 2 Short).
Maybe your power cord is bad if you don't get anything to happen whatsoeverwhen you press the power button. And if that's true maybe you wasoperating off the battery the last time you had it on and since the power cordis bad, it was not charging the battery so the battery is drained and the powercord is bad.
Maybe you have a Static Charge Buildup. Remove the Power Cord, then Press and Hold the power button for 30seconds. After 30 seconds plug the power cord back in and hit the power button to see if it boots.
Maybe your memory is bad or the memory slot is bad.Remove the Power Cord, Open the Case and remove one of thememory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x onit with an ink pen. If it fails to boot then move the chip to the nextmemory slot and try rebooting. If it fails take the chip out and set itaside, then put the other chip in and try booting it in both slots. If itboots, just to verify that the chip set aside is bad, mark an x on it and putit into the open memory chip slot and try booting.
May 07, 2012 | HP Computers & Internet
Power supply unit starts (fan running) but computer does not....
Try swapping out the ram 1 at a time, making sure there is one memory piece there while testing. If no! check hard drive for activity.
Mar 14, 2012 | HP Pavilion a1102n PC Desktop
What will i do to my hp mini notebook it has a power but it cannot booth
Perform a Hard Reset Do these actions first to clear all temporary setting before troubleshooting the problem.Disconnect all peripheral devices and remove all USB devices and media cards.Disconnect the AC power adapter, remove the battery, and then press and hold the power button for at least 15 seconds to drain residual charge.Reconnect the AC power adapter (do not connect the battery), press the Power button and look for the LEDs to blink or glow, and listen for the sound of a disk drive and fan turning.Perform each recommended corrective action and then attempt to restart the computer.Symptom 1: LED lights do not glow, display is black, no fan or drive sounds are heard, and computer does not startIf LEDs do not glow or blink when AC power adapter is attached and power button is pressed, there is no power available to the notebook Check AC adapter wiring and power connection to the notebook Connect a different AC power adapter and remove battery, then restart notebook.Connect a different battery and disconnect AC power adapter, then restart notebook Symptom 2: LEDs blink or computer beeps but does not start Blinking LEDs or beep tones indicate a hardware failure during the pre-start up testing Count number of blinking LEDs or beeping tones to help with diagnostics testing Symptom 3: LEDs glow, fan noise may be heard briefly, display remains black, and computer fails to startup or boot Usually occurs if a component is installed incorrectly, or there is a device conflict or failure Connect an external monitor to check if the problem is the built-in LCD display or graphics card Remove all CD/DVDs, SD cards, USB devices, peripherals and do a Hard Reset If memory or hard drive components were replaced, reinstall original component Remove memory modules and replace one-at-a-time Remove and reseat hard drive If possible, turn on power, press F10 to enter BIOS mode, and run Memory Test and Hard Drive Test On newer notebooks, turn on power, press Esc to enter UEFI mode, and run Memory Test and Hard Drive Test If possible, turn on power, press F8 to enter Windows Advanced Boot Options , and select Repair Computer option, or enter Safe Mode and run Memory Diagnostics If all other methods fail , but computer can boot to BIOS, use recovery disk to recover the computer to original condition Symptom 4: Computer may display an error message on a black screen during startup or boot Search www.microsoft.com for terms in error message Search www.hp.com for terms in error message
  • If possible, turn on power, press F10 to enter BIOS mode, do the corrective actions listed under Symptom 3 to run memory and hard drive tests.
  • Symptom 5: Computer displays a blue screen or continually re-starts After an error message is displayed, you can usually bypass the error and continue to run the notebook in Safe mode to install an updated BIOS or driver.
    • Search www.microsoft.com for terms in error message.
    • Search www.hp.com for terms in error message.
    • If possible, turn on power, press F10 to enter BIOS mode, and run diagnostic Memory test and Hard Drive test .
    • If possible, turn on power, press F8 to enter Windows Advanced Boot Options , and do one or more of the following:
      • Select Disable automatic restart on system failure to view error message.
      • Run Repair Your Computer .
      • Run Last Known Good Configuration .
      • Select Boot into Safe Mode and then select Run a Microsoft system restore .
      • Select Boot into Safe Mode and then select Uninstall recently installed programs .
      • Select Boot into Safe Mode and then run Windows Update .
    Symptom 6: Computer displays the Windows logo screen and stops responding If no error message displays, turn on power, press F8 to enter Windows Advanced boot options ,and select Disable auto-restart to view error message.
    • If possible, turn on power, press F10 to enter BIOS mode, and select Restore the BIOS defaults (F9) .
    • If possible, turn on power, press F10 to enter BIOS mode, and run Hard Drive Test .
    • If possible, turn on power, press F8 to enter Windows Advanced Boot Options , and select Last Known Good Configuration (Advanced) . .
    • If possible, turn on power, press F8 to enter Windows Advanced Boot Options , and select Boot into Safe Mode and then Uninstall recently installed programs .
    Update Computer After Resolving A Problem When the computer starts into Windows normally, you should install the latest updates and patches to prevent other start-up problems.
    Oct 09, 2011 | HP Mini 1000 Netbook
    When my HP pavillion a1700n installed with vista home premium shuts down or goes to sleep mode it will not turn back on. The little led light under the power button does not come on but the power button...
    Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
    One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
    Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
    the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
    make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
    hope this will help
    don
    Feb 28, 2011 | HP Computers & Internet
    HP DV928US When battery in or charger plugged in
    fails battery out so leave it out they love to short.
    so when it fails test 2 is, hit the F10 or ESC key promptee
    went it fails to boot, check BIOS key first, if BIOS fails.
    be more clear.
    what does it do when it wont turn on.
    BIOS dead. screen 100% dead, and not even text
    BIOS works even with HDD and DVD drive pulled.
    that is the acid test on PCs.
    the screen must say, hit F10? or ESC to enter setup, means HP BIOS. it must or power is no good. get a new power pack
    the shut down tell me lost power, that can be the power pack 19vdc
    or the jack at the mobo if failing to said pack.
    try side pressure on that jack if at anytime the power button fails.
    it self shuts down, I got that but lets fix , cant boot first.
    that is how to fix this.
    power on failures, are you saying the power key fails. some times
    and the fan does not run every time.?
    Also,
    this old LT uses CCFL back lamps.
    that love to fail. so when it shut down did the fan die.
    did the HDD stop spinning ear to bottom? if not the CCFL is failing.
    using and external monitor proves this every time,
    do the flash light trick?
    http://www.pcdied.com/monitors.html#flashlighttest
    Aug 29, 2017 | HP Pavilion dv6928us Notebook
    Computer wont stay on once power button is pushed
    yes unfortunately with this series of laptops it is VERY common for the motherboard to fail because of something called an NVIDIA chipset so if you are not hearing any fans or hard drive activity for more than 3 to 5 sec than im sorry to say that this is what it is but you can however get new motherboards on ebay for a fair price! i am sorry and i wish you the best of luck.
    Dec 16, 2009 | HP Pavilion dv6000z Notebook
    Computer will not boot up
    rest bios by removing battery and holding power button for 1 min.
    Jul 07, 2009 | HP Pavilion dv6000z Notebook
    Fan is running, power button with blue light is off, cpu won't boot up
    Your cpu might have died. As the computer is starting tap F8 and choose last known good configuration to see if you can get it started.
    Apr 26, 2009 | Gateway 500GR PC Desktop
    Emachine Will not boot
    different beeping patterns are codes which indicate what part of the hardware has failed (ram, video card, cpu, ect). the fan failure would not cause beeps, and would not cause the cpu to fail unless already in windows. if you could find out the manufacturer of your motherboard you could check with them about what the paticular pattern of beeps which you are getting mean.
    May 17, 2008 | E-Machines eMachines Desktop PC
    Computers & Internet Logo
    48 people viewed this question
    Top HP Computers & Internet Experts
    pontelemon
    pontelemon
    Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
