Cannot change the screen orientation on my Gateway M280 tablet PC
Whenever I push the button (hardware) on my Gateway M280 tablet PC to change the orientation from primary landscape to secondary landscape, I get the following error dialog:
[Tablet Button]
The setting you requested cannot be supported.
Open Display in Control Panel, adjust the settings, and then try to change orientation again.
I have tried selecting nearly every single setting I can in the display settings to no avail. I am at the end of my rope and the ATI folks who created the drivers for this laptop's video card don't have a driver update to help, apparently.
I'm on Windows XP for Tablet PCs (2002) SP3.
Any and all help is greatly appreciated!
  • 5 more comments
  • Fangz Nov 26, 2008
    Same thing here. Not sure when it started. Win XP home, sp3
  • Anonymous Nov 27, 2008
    same problem. the only button i could modify was the app start one. but if i change its function to screen orientation it will still give the same error.
  • buckbee Dec 02, 2008
    I have both a Dell Latitude XT and a Lenovo tablet that are both getting this same problem. You can change the screen orientation using the ATI software but not the button on the tablet.
  • Anonymous Dec 03, 2008
    Same problem here with my Dell Latitude XT.
    The Dell people have been no help so far.
  • RC1968 Dec 11, 2008
    I have the same problem which only recently started. I too have a Gateway tablet.
  • sachrw Jan 17, 2009
    My computer is a Gateway, and the screen orientation button stopped working after i sent my computer in to get fixed. i get the same error message.
  • Anonymous Jan 26, 2009
    Dell Latitude XT. ATI card and same problem
Ok so I had the same problem on my tablet cx2000. Did you download any of the service packs from xp? If so that is what is causing the problem. Your computer will work fine without it so you just need to de-install it. Go to your add and remove programs and delete the service pack. Once your computer reboots then it will be fine!
Posted on Jan 28, 2009
Screen is real dim, but I can see if use another monitor
The back light might have failed. You will need to have tis repaired if you cant do it yourself.
Nov 03, 2012 | Gateway C-140 C-140S C-140X C-140XL M280
My laptop screen has turned on it's side, how do i put it right
A tablet PC is expected to change orientation of the screen if you put the laptop in Tablet Mode.
If all hardware and software are in working order (correctly configured) you should be able to change screen orientation
  1. By pressing the rotation button. I can't say where it is since you did not specify the Toshiba Model.
  2. Or you press CTRL ALT ( UpArrow, DownArrow, Left Arrow, Right Arrow). CTRL ALT UpArrow will restore the screen to the default orientation in tab let PC Mode.
May 19, 2012 | Toshiba Computers & Internet
I own a gateway M280 convertible laptop designed for windows xp, tablet pc edition.I tried installing windows xp sp2 but it didnt find any hard disks installed on my system.i finally got another os called...
if your installing windows 7 it will have all the touch screen drivers and such already built in, just a matter of enabling then in your control panel
Feb 28, 2011 | Gateway M280E
Can't change the orientation of the screen
By orientation i take it your screen is either upside down or sideways on?
If that's the case then hold down Ctrl and Alt and use the cursor/arrow keys to rotate the screen back to normal. This will no doubt be the cursor up key.
Jul 15, 2010 | Gateway M285-E Notebook
My tablet PC will not change orientation from landscape to portait - no matter what I do. I keep getting an error message saying the settings I have requested cannot be supported.
Check with Gateway support driver site, check for the latest graphics drivers for that model and try to update the drivers for it.
Jan 24, 2010 | Gateway CX200S Tablet PC
Screen Won't rotate
you need to change your screen resolution to rotate, make it so that it is taller rather tan wider
Dec 27, 2009 | IBM ThinkPad X41 Tablet PC
. screen orientation not working
what exactly is it, is it you screen which is rotated, if it is i would suggest you should go to control panel, nvidea control. there should be a menu on the side, in the section display there will be rotate screen, you can adjust your rotation there or any other screen settings, hope this does solve your problem.
Sep 13, 2009 | HP Pavilion tx2510us Tablet PC AMD Turion...
Orientating my Screen after I switch into tablet mode.
You can press the Orientation Button located in the right bottom corner of screen. It is marked with two arrows following each other in a circle.
Moreover, you can set as default the screen orientation you desire in Tablet Properties.
Also, remove the battery for 10 seconds and reinsert. This will enable auto orienting of screen.
Jan 13, 2009 | HP Pavilion tx2500z Notebook
your prob is u have windows xp tablet sp3 when by defoult gateway only provides u with sp2 so u have to uninstall sp3 or format your harddrive and u will need the recovery cd for that...but u can call micrsoft and they wil give u free support on how to do this...hope this helps!
Jan 08, 2009 | Dell Latitude XT Laptop
Computers & Internet Logo
1,158 people viewed this question
David Payne
David Payne
