Question about Sony Betacam SP Small Videocassette 30 Minutes Digital Betacam SP Tape
I have a Sony UVW 1800 Beta SP deck. This morning, after completing a dub, I rewound the tape. The machine made a sound, the tape stopped and became stuck in the machine. I received an error code 02-803. I removed the top and removed the tape - however the machine still gives the error message and is not working. Can you help?
  • 88 Answers
Check your tape deck unit throughly check for any physical damage of REWIND/FORWARD Gears.and FLY Wheel.
and dis locateion of some lever positions.
defnitly you get solved
Posted on Nov 13, 2008
I have a UVW-1800 VTR. Power supply has click noise, it doesn't start up. Does anyone know the UVW-1800 power supply problem? Thanks,
Did you ever get a reply/solution to this? We have just have the same thing happen to our deck today.
Thanks
Feb 14, 2010 | Sony Televison & Video
RF INTERFERENCE PROBLEMS WITH MY BETA UVW 1800 DURING RECORDINGS - I GET AM/FM RADIO ON THE RECORDED TAPES. HOW DO I BLOK THIS?
Sounds like a grounding problem. Make sure you are using quality video cables with adequate shielding; other than that, check all your grounds on your equipment.
Jan 19, 2010 | Sony UVW1800 VCR
Error02-694 Sony Betacam Deck UVW-1800
UVW-1800 error 02-694 indicates a problem with one or both reel motors. check the cables going to both motors; have seen failures related to these cables.
Jul 21, 2009 | Sony Betacam SP Small Videocassette 30...
Sony Beta sp deck 1800 wont take larger tape down
Most likely problem when a Beta SP deck won't take the large tapes is a bad cable in the cassette housing. Replacement isn't too difficult, and the cable only costs about $20.00.
Jul 14, 2009 | Sony Betacam SP Small Videocassette 30...
Tape stuck in sony uvw-1800
02-874 error code signifies a defective takeup reel. The reel is not winding the tape in, so the deck won't go through the eject procedure. Check the connection to the takeup reel motor; if that's OK, the motor itself may be bad. Rarely, the takeup reel motor assembly will need to be replaced; usually it's a connection problem.
Jul 02, 2009 | Sony UVW1800 VCR
Sony UVW-1800 Error Code
I just found this post on another site :
tsvservice- 29th Jun 2007 14:0109-221 is "failure to complete threading within the specified time". in plain talk, the mechanism in the deck that threads the tape around the heads is not working. this could be a bad motor, bad gear, or even a bad tape.
Feb 15, 2009 | Fuji M321SP Betacam Tape
The machine is a SONY VIDEO CASSETTE RECORDER UVR 1400 AR
uvw-1400 error 02-803 is "tape tension error when threading". possible bad threading motor or threading mechanism.
Feb 11, 2009 | Sony Betacam SP Small Videocassette 30...
Digital betacam tape stuck in Sony UVW-1800 deck
Digital tapes should still eject normally (they are the same size and shape) which indicates that it has jammed somewhere inside.
If you want to fix it yourself you will have to remove the cover and check the tape.
If the cassette hasn't spooled up and all the tape is inside the cassette you should be able to unscrew the carriage (the cradle that takes the tape in and down) and remove it that way.
If the tape has spooled around the heads there is a cog (can't remember the exact position of it) arranged vertically near the side of the machine that you can manually wind the spooling arms back into the cassette.
Good luck
Dec 29, 2008 | Sony Betacam SP Small Videocassette 30...
Error code 02-694
The probem as told on another site (sorry, can't remember to give proper credit) is that the pinch roller is not making contact with the capstan. THis is exacly what happened to my 1800 after sitting for a long time with no use. THe solution was to manually excersize the lever going to the solenoid to unstick the mechanism. Then, voila, pinch roller pinches, tape moves, UVW1800 happy again.
Apr 13, 2008 | Sony Betacam SP Small Videocassette 30...
No Instruction Manual
1. Insert a blank DVD disc in the DVD deck and
close the disc tray.
2. Insert the VHS video tape you wish to copy into
the VCR deck.
3. Find the place on the VHS tape from which you
want to start dubbing using the PLAY, FF, REW
and PAUSE functions. For best results, pause
playback at the point from which you want to
record.
4. Press the DUBBING button on the Remote
Control or DUB on the front panel.
The Dubbing menu appears.
5. Use the arrow keys to select the desired Record
Mode: EP, LP, SP or XP.
6. Select [Dubbing] then press ENTER or DUBBING
to start copying.
7. To stop dubbing at any other time, press STOP (x).
Dubbing will stop automatically when the VHS tape ends.
Mar 01, 2008 | Insignia IS-DVD1001 DVD Recorder/VCR
Electronics - Others Logo
688 people viewed this question
Top Sony Electronics - Others Experts
Sandy Moore
Sandy Moore
 Grubhead
Grubhead
Brian Sullivan
Brian Sullivan
Are you a Sony Electronics - Other Expert? Answer questions, earn points and help others
