Question about Nikon Coolpix 3200 Digital Camera
How do i auto focus?
Cant find how to make auto focus work - help!
0 characters
1 Points
Pentax k200D auto focus manual focus button not working
Discover the location of the problem by elimination if you have a spare lens. If the second lens does not auto focus the problem is on the camera or connections to the lens. If the second lens works correctly then the first lens is faulty in the focus area. I hope this helps to target the source of the problem.
Apr 03, 2014 | Pentax Digital Cameras
check your lens and there will be a switch for Autofocus and Manual Focus if it is on manual focus just switch it to Auto
May 10, 2013 | Canon EOS 1100D / Rebel T3 Digital Camera
I have a pentax x90 and cant get the focus dial to work
Is the camera mode on MF:manual focus or is it on auto?
Aug 07, 2012 | Pentax X90 Digital Camera
Auto focus for an for digital cameras have a nasty habit of that, do what I do, and my Auto Focus works too, but I use Manuel focus all the time, and I shoot professional golf....I never auto focus eye is faster and better than the lens.
Mar 22, 2010 | Nikon D60 Digital Camera
Iso to auto
On the back of the camera to the Right of the LCD there is a up-down-left-right-center switch. push the up one. (Labeled ISO) then use the same selector switch to select the ISO you want and then press the shutter half way down. If you are shooting in a low light situation, the auto focus sometimes will not work. Change the switch on the lens from AF to MF and focus manually.
Sep 26, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
Nikon D40 help?!
I assume the lens had the impact. The 18-55 lens has the built-in motors for auto-focus.
Try switching to manual focus (on the lens). If this works, the lens may not auto-focus anymore.
Try it and let me know.
Sep 01, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
Nikon D40X stopped auto-focusing yesterday
I had the same problem. My issue was with all my lenses. I solved it by going to the menu and selecting the custom setting menu (pencil icon). Then from the right menu select the AE-L/AF-L and press OK. Then make sure it is set on AE/AF Lock. Presto...all my lenses worked on auto-focus.
Feb 24, 2008 | Nikon D40x Digital Camera
Focusing please help
I have a Sanyo VPC-S3 camera old now I know, but my main problem is with focusing, all the pictures come out very blury, you cant easily tell what the subject is.
I have tried all the setting Both Manyal, and full auto, and the focus does not seam to make any differance noi matter what I do.
Please help.
All the best.
Nov 06, 2007 | Sanyo Xacti DSC-S3 / VPC-S3 Digital Camera
Focus Problem
Low light focus lock can be a problem with this camera. But in normal or bright light there should be no problem with auto focus lock. If this is a new problem, you should check to see if a setting has been changed. With so many options, it is easy to accidently set something that causes unusual results (been there, done that). First ... Go to the Setup Menu and see that the "All Reset" option is selected. This will cause everything to be reset to factory default each time you power-on the camera. Turn the camera off and then turn the camera on. Then take some test photos to see if your auto-focus-lock is improved. If that works, there is no need to check the items below. If that does not work, here are some control changes to try. Remember if you turn off the camera everything gets reset. That camera uses contrast detection for auto focus and it is normally set to "Multi-Area Auto Focus". Try changing it to "Spot Auto Focus" and do some tests, including with the camera set to one of the programs or manual mode. There is another setting called "Autofocus Area", you should investigate. Check your manual to determine what you can do with this control. There is another control called something like "continuous auto focus". Check the manual for further information. If none of the above help, it is time to see about some camera repairs.
Sep 06, 2005 | Olympus Camedia C-740 Ultra Zoom Digital...
Nikon Coolpix 3200 Digital Camera Logo
Top Nikon Digital Cameras Experts
Are you a Nikon Digital Camera Expert? Answer questions, earn points and help others
