Question about HP Pavilion dv4000 Notebook
When;I;use;the;spacebar;a;semicolon;apears;instead;of;a;space my;cat;spiled;some;coffee;but;i;didnt;think;it;got;into;the;keyboard; it;is;a;Toshiba;satellite;A55-5106.;the;key;next;to;it;will;not;work;either.; how;do;I;fix;it.;can;I;take;the;keyboard;out;and;clean;it;or;do;I;have;to;replace;it or;am;I;screwed. also;what;do;i;clean;it;with;if;I;can;clean;it.
  • danasweetie Dec 28, 2008
    I; ha4ve; the; same; problem; as; mike; in; addition; to; the; v; typing; 4v.; Pls; help!
  • Anonymous May 10, 2009
    i have the same problem..i didn't spilled any coffee or liquid in my laptop though..
    Problem Solver:
  • 10 Answers
Problem with HP Notebook Or Laptops? Follow the links.
For Software problems you can visit a link by just Click Here .
For Hardware problems with this Notebook you can Click Here
Posted on Jul 23, 2010
    Scholar:
  • 112 Answers
I don't know if the keyboard is salvageable or not. I do know that the keyboard can be replaced and taken out. As long as nothing else is malfunctioning, the computer is fine. Heres a link that will show you how to take the computer apart.
http://www.irisvista.com/tech/laptops/ToshibaA55/SatelliteA55_remove_keyboard.htm
Hope this helps.
Posted on Nov 13, 2008
  • 38 Answers
Your Keyboard is most likely to be screwed. A drop of coffee is enough to damage it. You will have to replace the keyboard. cleaning will work onlly if something is obstructing you from pressing the keys.
My dog knocked over my Compaq keyboard. Now the divided spacebar is opposite what it should be. Instead of spacing on the right spacebar I have to hit the left side. How do I fix this?
Pull the space bar off by using your fingers. Underneath, you'll find a metal rod. Take note on which way it is facing, and how it fits. Make sure nothing in broken under the space bar, then put the space bar back on making sure it hooks in correctly.
Mar 08, 2011 | Compaq Keyboard
My spacebar is not working correctly. It will not space at all, or leave too manyspaces.
chances are that your space bar key is faulty and not the motherboard. this usually happens if the keyboard is old or if u possibly messed cool drink/coffee etc on the keyboard and it is sticky. Some keyboard can be opened from the bottom and you can clean individual keys but unless you are qualified to do so - i wont try it. Best is to try a new keyboard - you can pick up keyboard for very cheap these days.
Feb 03, 2011 | Computers & Internet
I have a IBM WW 1500 all the keyboard works but the spacebar, is this the function or keyboard or possible homming sensor failure?
If everything wirks but the space bar you probably have a keyboard problem. If someone had the space bar off it may not be properly installed. You can pop the space bar off and look for debris under it.
DickyO
Dec 02, 2010 | IBM Office Equipment & Supplies
My spacebar key is no longer working properly. I have an acer aspire laptop 5735Z . I deliberately pulled the key off to clean underneath and then just clicked it back on, thinking it would work normally....
There is usually a metal piece under the space bar, if it isn't seated properly the space bar will teeter. Try to remove again and see if they metal bracket is seated correctly.
Oct 18, 2017 | Acer NSK8458AN Keyboard
Space bar is sticky du to liquid accident ( soft
Get a Electrical/Electronic solvent spray from RS, give it a good spray (with Power Off!) and operate it lots of times. The spray will evaporate naturally and may remove the gunk! Ian.
Sep 17, 2009 | Acer TravelMate 5530-5207 Notebook
How do I reseat the space bar on the mx 3200 . the logitech keyboard accummulates cat hair behind the keys, easily removed. But the space bar has a spring and white gunk and does not reseat easily. Mine...
Use a credit card or plastic Id, insert it and bend it gently. If it fails, you can use 2 cards, one on each side of the spacebar.
If after all you are unable to remove the spacebar, try removing the keys around it, just remember their distribution.
Beware, the spacebar is a little more complicated to put back in place compared to the other keys, as you said, there is a spring.
Sep 04, 2009 | Computers & Internet
Media.center.keyboard.spacebar.does.not.work.after.cleaning
i have already posted the solution to my problem.....but i will tell you in more specifics what transpired.........after removing my spacebar.....i used electric pre-shave (an alcohol based solutions with a slight amount of lubrication).......with a few drops of that and a q-tip i cleaned the black tarry mass that had accumulated underneath the space bar most likely from spilled pop,coffee,pancake syrup,cat hairs,and only god knows what else...........after replacing it it worked fine mechanically and physically but did not work on the screen......after a day or two it started working .....i guess the alcohol needed to dry out .....i did put two drops down the tube that had a pad at the bottom (contacts underneath it ).........everything working better than new now .......thanks for being here to help.........
Feb 18, 2009 | Sony VAIO RA710G...
Mx3200 First the spacebar won't work andthenitworkstoowell.
did you check to make sure that the springs and bar under the spacebar are seated correclty?
Sep 30, 2008 | Logitech 967437-0403 Keyboard
My keyboard is inserting spaces where they don't belong.  it is usually around R's, N's and spaces (I  press the   spacebar once it it inserts 2 or three spaces, the  faster I type the   worse it gets.)...
You should open the key board.and clean space key and change rubber cap.
Hope this be of initial help/idea. Pls post back as requested, how things turned up or should you need additional information.
Good luck and kind regards.
Oct 25, 2007 | Logitech 967437-0403 Keyboard
HP Pavilion dv4000 Notebook Logo
596 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
