PD-80A screen goes totaly white after momentary show.
It starts to show video then goes to white. (loss of contrast)
  • 4,806 Answers
Try a different media player and download the latest video/audio codecs
Posted on Nov 13, 2008
Why does my monitor have a white screen
First, it could be out of adjustment--turn the brightness and contrast controls up and down to see if it makes a difference.
You could have a bad video card in the computer. Do you have another monitor to try to see if the actual video output is good? This is the easiest way of troubleshooting.
When you start the computer, can you see any white printing on the screen indicating it is booting? Does the problem start once Windows starts? If so, try starting in safe mode. If you can do this, then I'd suspect video driver problems.
Dec 27, 2011 | BenQ FP791 17" LCD Monitor
I have a TI 89 but when I turn it on the screen is totaly black after waiting like 10minutes or so it started to brighten.
Try adjusting the screen contrast. Turn the calculator on. Press and hold the diamond key, then press + to darken or - to lighten the screen.
Jan 12, 2011 | Texas Instruments TI-89 Calculator
Monitor sampo PD-80A Software or driver setup for y monitor
free after free registration at drivers.com. also probably available at the manufacturer's website.
Sep 04, 2010 | Sampo PD 80A (Gray) 17 in. Flat Panel LCD...
White spots in corners
"It's referred to as 'flashlighting'. It's a common problem in LCD/led as the driving factor is lighting pushed through pixels to create the picture. What you are seeing is a spot where the lighting is passing through unscathed or overpowering around the edges since this is an edge lit tv.
Some TVs are worse than others even if they are the same model, size and even batch.
This can be caused by many reasons... You have 2 options, return and/or exchange it at your local store if still in that window. Or you can call the tv manufacturer to see if it is out of their allowable tolerance levels.
Remember some flashlighting is still within their specs so even though you may not be happy with it the manufacturer may not fix it.
Many people find some relief by turning brightness down, contrast down and some TVs allow you to adjust back light levels. If this one does then make sure it is not on high.
For more info on this I would go to hidefjunkies.com as it has tons of great info."...Also,"take it off Dynamic mode is the first step. Then put it on something like Standard or Movie. This will not fix it permanently, but will give you a better experience." (I hope this answers your question...if it was ME,I would take th darn thing back,if still within warranty period.)
May 09, 2017 | Vizio L37 Television
HCL Monitor Screen Display Problem with Contrast menu showing up.
my hcl 17inches monitor is displaying contrast,brightness etc automatically
in the middle of the screen.even if i press the menu buttons it
disappears for a sec and comes again and again.what should i do to
solve this?
Sep 13, 2009 | Computers & Internet
I was in the setup screen for the Protron PD-DVR-100 and chose progressive scan for the output. Then the screen went half black and half white. The trouble shooting in the manual send to put it back to...
If your player has the red blue green video inputs on the back plug your video cable into one of them the picture will be a bit distorted but you will be able to see enough to change it back. I did this one time with mine.
Aug 13, 2009 | Protron PD-DVR100 DVD Recorder
I have a Mitsubishi PD 5010 plasma tv. I turned it on and it now has these black rectangular boxes on its screen one in the upper right hand side that goes down almost about half way and another in the...
Post a screenshot. If you wish to get some details; visit the site linked here. Pull up older posts.
faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Jun 19, 2017 | Mitsubishi PD-5010 50 in. Plasma...
Cannon NP 6551 (Danka A50) Touch Screen Lost Brightness
SOMEONE TURNED THE CONTRAST BUTTON ON YOUR DISPLAY, YOU JUST NEED TO READJUST BY PRESSING AND TURNING TO DESIRED CONTRAST
Apr 03, 2009 | Canon NP 6551 Black and White Copier
LG 700E MONITER britghtness and flicker
trace abl from fbt to video preamp ic.
replace ic if nothing found bad.
Sep 23, 2008 | LG Studioworks 700S 17" CRT Monitor
My computer screen is white
When it turns colors that usually means one of four things. 1 cable is not set write, 2 monitor is bad, 3 settings are out of whack or 4 the video card is going bad. I would try to mess with the cables and if that does not work plug that monitor into another computer to see if it work and plug a new monitor into that one. You should be able to solve what it is then.
Good luck
Sep 19, 2008 | Computers & Internet
Computers & Internet Logo
49 people viewed this question
David Payne
David Payne
