Question about Hotpoint WMA46 Front Load Washer
Washing still wet - door won't open.
Hello Hope you can advise me. I have an Hotpoint Aquarius Extra WMA46. When I put the washing on a cycle, it goes through all its bits, then when it reaches "Final Spin" it falls asleep. The door won't open because it has not finished. I have tried just putting it on "Fast Spin", but it still leaves the clothes wet. The washing machine has been moved recently. The cycle works if I stand with the drainage pipe and hold the pipe up when the machine is filling (or the clean water just drains out) and down when I know it is spinning. Please help, this is driving me insane, my washing takes hours to wash, and if I have to take them out wet, hours to dry, plus I don't think putting very wet washing in my tumble dryer is doing it much good!! Please help me!!!! Thanks, Carol.
    President:
  • 1,462 Answers
Not a fault with washer. i guess you are plumbed into trap under sink. the spigot you fastened drain hose to is blanked off - there are various methods of doing this including have to saw off the end of the spigot with the bread knife. possible also a fault with pump or filter
Posted on Mar 19, 2007
SOURCE:
Hotpoint aquarius WF541 won't finish a cycle
What is the model number? Look inside the door area.
Oct 18, 2012 | Hotpoint Aquarius WMA42 Front Load Washer
Hi we have a hotpoint aquarius extar 1300 spin wma46 that wont spin at all even with no clothes in ?
hello is it pumping out water if not check the pump for blockages it has to pump water out first then it should go into spin cycle. if does pump water out and still not spinning then there could be a problem with the module board this control the motor speeds hope it helps
regards
shaun
Mar 05, 2011 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint fault?
Check the drain and circulation hoses for partial blockages as usually this causes such problems. Also make sure you using program with full speed spin cycle (solid spiral sign just before the dot pointing the end of chosen programme)
Mar 01, 2009 | Hotpoint WMA30 Front Load Washer
Clothes still wet after fast spin cycle
Belt loose or motor / motor control board possibly defective
Sep 13, 2017 | Hotpoint Aquarius WF000 Front Load Washer
Door Lock Light - flashing
does the door still lock? becasue it sounds like a faulty lock. It may need to be replaced.
Aug 25, 2008 | Hotpoint WMA46 Front Load Washer
Hotpoint Aquarius WMA46 front loader
I 've had this problem a few times with these machines.
Some solutions that have worked for me are.
1 change the motor.
2 change the wiring loom
3 change the board.
The most common one is the motor even when the it has decent brushes the motor just will not pick up speed on the spin cycle.
hope this helps.
Dec 14, 2007 | Hotpoint WMA46 Front Load Washer
WMA46 stopped woking power off mid cycle
hi there the problem you have sounds like the motor has shorted out causing the pcb to blow, sadly this is a costly repair and is usualy not worth repairing as you will need a new motor and pcb
murdozzz
Dec 09, 2007 | Hotpoint WMA46 Front Load Washer
Hotpoint WMA46 Front Load Washer Logo
282 people viewed this question
Top Hotpoint Washing Machines Experts
vince
gbob59
James Hehling
James Hehling
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
