Question about Wharfedale DVD-M3 DVD Player
No sound through channels on hdd dvd
i cant get any sound through the tv channels on my hdd dvd recorder.the scart connection on the back is broken-so i am using red/white/yellow leads and connecting via s video -still no sound.the dvd player works fine with sound-just the channels through dvd has no sound-a real pain when wanting to record-must it go through scart or should it still work via s video?
regards .john
  • johnnie_haze Nov 13, 2008
    many thanks for help,when i said hdd it is not hd but hard drive-is this still the case on what your suggesting?thanks.j
  • Anonymous Nov 28, 2008
    i have exactly the same problem i have connected up a LG LCD TV to a Wharfdale dvd HDD recorder & all ok when playing dvds but no sound when in freeview mode via dvd recorder in oder to record programmes!! but strangely sound ok on previously recorded programmes on hard disk
  • 44 Answers
If you are taking output from the Red, Green Blue connectors (Component) from your video source and plugging them into your hd dvd recorder, you need a sound channel as well. The S-video carries both audio & video but not in high-definition. Sounds like you've got the 3 channels for your video (RGB-component) connection now you need an audio signal into your HD DVD recorder. That will be 1 fibre connection or 2 cables. Let me know if you get it working & good luck!
Posted on Nov 13, 2008
How do i connect dvd recorder to tv only receiving sky channels through skybox
If you have two scart sockets on your tv,then connect a scart from av1 on the dvd into the tv,then connect a scart from the sky box into av2 on the dvd,your recording channel on the dvd will be av2.
If you only have on socket on the tv,then connect a scart from av1 on the dvd into the sky box,your recording channel will be av1,connected like this you may have to turn off the sky to watch dvd`s.
Oct 30, 2009 | Televison & Video
Connecting up Digital TV, DVD recorder and VCR
You need to hook the VCR and the DVD recorder to the scart connections on your TV.
VCR to one scart on the TV
DVD recorder to the other scart on your TV
Jan 31, 2008 | Televison & Video
Useless at setting up. No sound on playback. Blocked timer record
You won`t get round the scan without an aerial.You still can set a recording as long as you set the recording channel as av2.Make sure the scart lead is fully in on dvd and tv,this can lead to no pic but sound,or sound no pic
Oct 27, 2009 | Televison & Video
Just got logik ldvr 1608 dvd but it cant find any
You need an aerial to tune the freeview.
However, to record from satelite you can connect a scart lead from the satelite vcr out to the dvd in and it will record vie the av "channel" on the dvd.
Depending on your location, regarding signal strength, you can purchase an indoor, boosted aerial to tune the freeview.
Also, if the scart connection on the dvd is a 2 way connection( allowing a signal to the tv as well as from the tv) you can connect the tv to the satelite and the dvd to the satelite only and the dvd will play through the satelite even when the satelite is off.
Aug 26, 2009 | Televison & Video
How to record digital tv thru reocrder
You need to go into the menu and set the "av-2 out put" to DTV, that should solve the problem, remembering to connect the "in" scart on the recorder to AV-2 on the tv.If there is only 1 scart on the recorder it will be a 2 way connection, sending and recieving a signal.
May 29, 2009 | LG RH177 DVD Recorder/HDD Recorder
Connecting a dvd 250gb hard drive recorder to tv and virgin box
Right then, on the back of the virgin box there are 2 scart outlets, connect one scart from the TV scart port to the scart in on the DVD recorder, then connect one scart lead from the scart out on the DVD recorder to the TV.
Find the DVD recorder source channel on the TV and then use the DVD remote control to find the digital input on the DVD recorder, this is usually AUX channel.
Post back if you need any more help
Good luck and thanks for using Fixya!!
Feb 22, 2009 | Televison & Video
LG RH266 DVD Recorder no sound
Hi .. It sounds like the problem you have is incompatabilty I assume that you haven tried Phono connections instead of scart , as this sometimes cures this problem .. or when purcahsing a scart look for the Miirrored type this means that the inputs and outputs are reversed this also sometimes cures the problem as some scarts put output to output and input to input ect when actually it should be output from tv to input dvd and so on ie wrong scart and there are a few of the cheaper type that have this problem .. if you have no luck using the phono let me know .. Regards Vortash
Jan 07, 2009 | LG RH266 Recorder
I bought dvd hdd recorder 3 days ago from lidl it is a targa DRH-5700X seriel no. e5809000859. Imust not have it connected right as i cannot get anything from it on the television.Ihave the recorder...
i have a targa 5500x from lidl cant copy from hard drive to dvd as i have done this many times but the dvd drawer keeps opening telling me to put in blank dvd and i keep doing this but getting no where,
Apr 23, 2008 | Toshiba SD-4000
Setting up
on the back of your sky box there are two scart ports. one says tv and the other video.
from the sky box connect a scart from the tv port to the back of your tv.
from the DVD connect a scart from that to the video scart port on the back of your sky box.
now when you turn your DVD player on it will override the sky and come through on your telly without having to change the scarts around.
what i would like you to do now. is get an RF lead. ( aerial lead) plug this into the RF out socket on the back of your sky box either one will do ie RF out 1 or 2 makes no difference.
Then plug the other end into the back of your Tv if you have an aerial cable coming into your home then simply plug this straight into the aerial port on the back of your sky box.
The last thing your going to have to do now is tune your telly in. if you click on channel 6 on your telly then go to menu, setup, and manual tune.. A good tip for you put your sky on the TV GUIDE screen this will make life easier for yourself as you will know its the sky channel.
once you find it STORE.
now when you turn your dvd player on if you select channel 6 you will now have the sky channel so you can record whatever you like
Hope this sorts you out.
Little Dish Fitter
Dec 28, 2007 | Samsung DVDHR738 (250GB) DVD Recorder /...
You MUST connect the recorder to the Tv with a SCART cable that is why you are not seeing anything.
I suspect you are using only the RF or Ariel Cables
If you have it connected with the scart cable you must choose the AV channel on your TV remote.
Nov 13, 2007 | Toshiba RD-XS34 DVD Player/HDD Recorder
Wharfedale DVD-M3 DVD Player Logo
175 people viewed this question
Top Wharfedale Televison & Video Experts
Gareth Cockram
Gareth Cockram
Colin Stickland
Colin Stickland
Are you a Wharfedale Televison and Video Expert? Answer questions, earn points and help others
